I got dell latitude D610 when i connect charger it gets off. i removed power jack. i check resistance of power points its showing normal resistance but when i connect charger it gets off plz help me out
Dell Latitude D610 power issue
Tags: None
Re: Dell Latitude D610 power issue
normally a shorted mosfet or capacitor...check power in from power jack...hardly see a power connector causing the charger to short...most times it will jus cause the unit to refuse to power on....post your results/findings after as i would like to know alsoComment
by SuperJamesThis one's a weird one, and still unsolved despite it having gone back to Dell once.
Specs
i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
Backstory
I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...10-23-2023, 04:09 PM -
by dlonely94Hi everyone!
I have a Dell Latitude 5591. It has a strange problem:
First, when the WLAN card is plug in, it will not power on when press power button, even all voltage is up (19v, 3v, 5v, 3valw, 5valw)
When I remove the WLAN card, it will start nomarlly. Then I power off and re-insert the WLAN card, it still work normally.
But, if I left it for 3 or 4 days without the battery and adapter plugged in, it will not power on, and I have to repeat the above sequence.
Sometime, when it not power on, I just unplugged the battery and adapter, wait...10-13-2024, 10:29 AM -
by NADJIBHello,
I need help please
I have Dell Latitude 7390, LA-F312P 1.0
- power LED turns on a few one second or two withe power supply or battery
- the power supply indicate current 0.16 A While laptop is powered
I checked:
While laptop is powered from battery/barrel plug AND power LED is on, all voltage rails show up, except +VCC_CORE and +VCC_GT.
* COIL
PL612
- Output resistance to ground is 14.7 ohm.
PL613 AND PL610
- Output resistance to ground is 9.8 ohm.1 Photo -
by diamonI have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
Pictures of these boards:
Dell Latitude 5520 https://www.ebay.com/itm/256052956663
Dell Latitude 5530 https://www.ebay.com/itm/125844181534
Dell...4 Photos -
by TopcatA few months out of warranty and it's dead as a fart. XPS 8950 with a 12th Gen I5, 32gb DDR5 RAM and a GTX1650 GPU.....
Symptoms it's giving are really making a coin toss between bad motherboard and bad PSU....I'm leaning toward motherboard, but there are some strange irregularities with this piece of shit system.
Basic test:
Upon connecting power cord, system powers on by itself (no button push) for a second then powers down...and then powers back on again, I hear a relay trip inside the PSU, and then powers down again and that's it. It won't do anything else....-
- Loading...
