Dell Latitude D610 power issue
  • incradibles
    • Feb 2011
    • 43
    I got dell latitude D610 when i connect charger it gets off. i removed power jack. i check resistance of power points its showing normal resistance but when i connect charger it gets off plz help me out
    Silence Like Dreams
  • yyonline
    • Jul 2009
    • 692
    Re: Dell Latitude D610 power issue
    Check for shorted mosfets, a fairly common cause of a dead D610.
    • dobber
      • Jul 2008
      • 83
      Dell D610's were real common for the power switch connections causing this. I just had one last month. they will give no power, but when you tear it down and press on the connector it probably will work.
      • kev4eva
        • Mar 2012
        • 37
        • jamaica
        normally a shorted mosfet or capacitor...check power in from power jack...hardly see a power connector causing the charger to short...most times it will jus cause the unit to refuse to power on....post your results/findings after as i would like to know also
