DV9000 Power issues - Unit power on, but does nt restart until disconnnected from ac
+ More Options
Posts
  • marcellodj
    • Nov 2010
    • 99
    strange problem on HP DV9000 laptop;
    unit starts and is full working,but when powered off, it wan t restart until dc jack is unplugged and reinserted.
    Tested FDS 6679 and AO4407 and seems ok, may be a capacitor not discharging?
  • shuky
    • 49
    Re: DV9000 Power issues - Unit power on, but does nt restart until disconnnected from
    how do u test the fds6679 and ao4407 ?
    • severach
      • Aug 2007
      • 1055
      The easy test is to check for shorts on the diode scale of a DMM. Check the datasheets. Some leads are supposed to be shorted. Some leads may be shorted by the surrounding circuitry. A more conclusive test is to pull the chip and test it with a Semiconductor Analyzer like the Atlas DCA55.
      sig files are for morons
      • marcellodj
        • Nov 2010
        • 99
        @ shuky: using my meter in diod mode; i know is best to pull out the component and do measurements, but is so time consuming!!!
        so i taken another identical board (working) and measured same components, identical readings.
        solution: reflowed intel southbridge and the box back to life !!!
        thanks everyone for attention,
        regards
        • bossapplesauce
          • 7
          Marcellodj - are you aware of the nVidia GPU defects effecting all of the HP dv9000 series units? The issue is with the BGA GPU become separated from the mainboard over time, and this causes issues with the WiFi, power on, video, etc.
          They're settling a large class-action lawsuit that nVidia has agreed to replace many notebooks from Dell, HP, and Apple. Check this site for more info:
          Code:
          http://www.nvidiasettlement.com/
          • shouri
            Dell latitude e5490 auto restart
            by shouri
            Hi guys, can someone help me?
            I have an issue with laptop dell latitude e5490 that auto restart when arrive at certain point in loading windows.
            Board model is dm70 la-f401p rev:1.0 2017-09-20.
            At first, the issue is sometime ssd sata 2.5 not detected. i already try another cable, at certain point, it ok using old cable (i mean sata cable here).
            After a few days test, is seems ok.
            Days later, another issue come, that is auto restart when certain point in loading windows. i already test another ssd, another ram, another sata ribbon, still same....
            12-10-2024, 09:27 PM
          • ngml
            Repair of an LG split AC system indoor unit PCB
            by ngml
            I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
            This indicates an error in the communication between the outdoor and the indoor unit.
            The outdoor unit is fine, so the problem is the indoor PCB.
            The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
            I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
            Does anybody have the schematics of this board,...
            02-01-2025, 12:55 PM
          • Fam787
            HELP! A1398 Dead,
            by Fam787
            I bought a second hand Mid 2014 A1398 MacBook Pro when I lived in Australia. I'd bought it as a back-up machine because I had a Mid 2014 MacBook Pro, and realising it might one day fail, I wanted a backup machine because I don't like change.
            Two weeks after buying MBP2, the seller called me to check if everything was OK with the unit, which I thought was odd. At that stage I might have turned it on a couple of times, but I'd not used it when he'd called. Over the last few years I used the machine seldomly because my original mac has been pretty OK. Every 3-6 months I'd charge it...
            12-27-2024, 05:19 PM
          • carrzkiss
            Cyberpower cps1500avr not charging batteries
            by carrzkiss
            Hello, all.
            Cyberpower Battery Backup Unit.
            I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
            When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
            In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
            Checking the voltage, it was down to 22v.
            I quickly removed everything...
            06-15-2024, 02:10 PM
          • nobbnobb1
            Bose Companion 5 - Unit Powers On then Cuts Off Shortly After
            by nobbnobb1
            Hi guys,
            Trying to salvage a Bose Companion 5 computer speaker system that powers off shortly after powering on. It's got a primary USB input (built in DAC) and an aux 3.5mm input. The USB appears to be the primarily source that tells the unit to power on (control pod LED goes green) as the unit has no power switch.
            When I first connect power to the unit, plug in the USB, it will play audio nicely for a minute before it drops out and the unit appears to go into standby (control pod LED goes red). It stays in standby and I cannot seem to power it back on without physically...
            02-03-2022, 11:14 AM
