HP 17-g113dx - freeze during system installation
  • daro19862
    • Jul 2013
    • 20
    • Poland
    Laptop 17-G113DX
    Mainboard - DAX1FDMB6F0 (X1FD)
    SR2C4 (GL82HM170)
    SR2FQ (Intel Core i7-6700HQ)
    KBC - IT8987E BXS
    BIOS - 25Q64
    IMVP8 - ISL95829CIRTZ
    I have a laptop that responds to power but does not display.
    I uploaded the BIOS from the official website with the same BID 080A9, the laptop started displaying an image and booted up with the message "manufacturing program mode is in unlock mode".
    The problem is the installation of the system from a pendrive, Windows 10 from the official website, after booting, the logo appears, the wheel starts spinning, then the logo disappears and at that time there is only the backlight, no image and it hangs like that, I noticed that at this time the voltage on the CPU disappears.
    A similar situation occurs when I throw the disk with the installed system into it, after booting, the logo appears, the circle spins, then the logo disappears and the screen is dark, only the backlight remains.
    I changed RAM, power supply, tried using an external monitor via HDMI but it's the same.
    Resistances on coils:
    PL20 (3,3V) - 7k Ω
    PL22 (5V) - 10k Ω
    PL19 (1V) - 53 Ω
    PL25 (1,35V RAM) - 250 Ω
    These coils lose voltage during system installation:
    PL17 (VCCSA) - 14 Ω
    PL12 (VCCCORE) - 2,3 Ω
    PL14 (VCCCORE) - 2,3 Ω
    PL13 (VCCCORE) - 2,3 Ω
    PL15 (VCCGT) - 3,7 Ω
    PL16 (VCCGT) - 3,7 Ω
    Voltages on ISL95829HRZ when the image disappears:
    1-0V
    2-0V
    3-1,75V
    4-2,1V
    5- 0V
    6- 0V
    7- 0V
    8- 0V
    9- 0V
    10- 0V
    11- 0V
    12- 2.5V
    13-2.5V
    14-0V
    15-1,5V
    16-4,7V
    17-0V
    18-0V
    19-0V
    20-0V
    21-0V
    22-0V
    23-0V
    24-0V
    25-2.5V
    26-2,5V
    27-2.5V
    28-0V
    29-4.6V
    30-0V
    31-0V
    32-0V
    33-0V
    34-0V
    35-2.5V
    36-0V
    37-0V
    38-0V
    39-0V
    40-0V
    41-19V
    42-5V
    43-1V
    44-1V
    45-1V
    46-1V
    47-3.3V
    48-3,3V
    I have no idea anymore, maybe one of you can help me?
  • ktmmotocross
    lenovo Ideapad Z500 - freeze while copying files in win10 installation
    by ktmmotocross
    Hello.
    Have this lenovo Ideapad Z500 that freeze while copying files in win10 installation
    It was water spilled and have burned highside mosfet on GPU and shorted 330d capacitor in CPU circuit.
    after repair this faults everything looks working but i cannot install windows. allways freeze when copying files i replaced processor which looks like better because i can start it in win7 that i have on disc. windows 7 which is installed works ok, but cannot get win10 to it
    09-26-2020, 12:27 PM
  • AppleLover123
    Acer Aspire A515-52G-53PU crashing during windows installation
    by AppleLover123
    Hello Guys,
    got an Acer here with the problem that when i'm installing windows it just crashes (turns off) and not going back on as soon as i press the power button.
    I've tried it with different sticks and windows versions and also with windows 10 and 11 but it's the same problem.
    The only difference is that when i want to install windows 11 it crashes during the installation screen when "getting files ready for installation" at 25% - 30% progress and
    when i install windows 10 it goes trough until the restart and at "getting devices ready" it...
    03-08-2025, 05:05 AM
  • warsztat
    Trademi Horizon, freeze after start.
    by warsztat
    Hi, trademil Horizon freeze after start like video, i try reset (3sek push stop), remove and I put new ones capaticors 3,3V line digital and analog line.
    The device in service mode passes all tests, except for the display test, where it hangs. The display in service mode during engine testing, etc. seems to behave correctly, it shows values, the engine is working, I can adjust its speed but only in service mode, in normal operation after pressing start the machine freezes
    All the multiplexers that support the display seem to be working. It's like the processor...
    03-06-2025, 07:33 AM
  • ulysse31_revient
    dell P2412Hb logo disappears
    by ulysse31_revient
    Hi All,
    UPDATE: post was moved to new thread, so editing it ^^'
    I'm a totally new to electronic repair, I do play a bit with arduinos, 3d printers, esp32 ... but I'm generally more on the coding/software side for hobby ^^" my electronic skills do not go much further for now ^^'
    I decided to start doing some repair, just to avoid throwing things to trash ...
    Since I have a broken lcd monitor, I decided to try to get this thing to work for a start ^^"
    I have a dell P2412Hb, which seems to be similar setup than the one on this thread https:...
    09-04-2023, 07:22 AM
  • maleksa
    Yamaha MOX8 boot freeze and distorted sound
    by maleksa
    My Yamaha MOX8 synthesizer recently developed two issues.
    Firstly, after booting up, it operates as normal. However, after about 5 minutes, the sound starts to get distorted (broken up screeching sound) almost like putting it through a guitar distortion pedal. After a while, the distorted sounds will go away for a while and comes back. At times, the synthesizer will also freeze I need to power off and on again.
    Secondly, when powering off and on again, there will be times where the synthesizer will freeze during the boot sequence (freezes at the MOX8 Opening Screen),...
    11-07-2024, 03:28 AM
