Battery not Charge NM-B421
  • Inforgalaxie
    • Apr 2023
    • 39
    • Portugal
    Hello i have this circuit and my battery not charge.
    I was changed PU101, PQ103,PQ101,PQ102, the battery and the problem is the same.
    When the bactery is conected:
    PQ103:
    pin1: 19v
    pin4: 19v
    pin5: 11v
    when the bactery is not conected:
    PQ103:
    pin1: 19v
    pin4: 8v
    pin5: 19v
    Why works the opposite? EC Problem and need programing?
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Battery not Charge
    NVDC should not produce 19V on main power rail.
    • Inforgalaxie
      • Apr 2023
      • 39
      • Portugal
      Yes is true.. What can be...
      • mon2
        • Dec 2019
        • 14667
        Which model / make of unit are you repairing? Is there a full schematic in the schematic forum? Post only the links here (not the schematic).
        • Inforgalaxie
          • Apr 2023
          • 39
          • Portugal
          This is the schematic.
          BQ25700
          PIN18 -- Cell Batpres have 0.09V
          PIN 7 -- VDDA have 0.14V
          There is anything wrong...
          ALL BQ25700 Voltages with battery conected: >>lenovo e580
          1- 20v
          2- 20v
          3- 20v
          4- 3,27v
          5- 0,14v
          6- 0,28v
          7- 0,14v
          8- 0,06v
          9- 0,09v
          10- 0v
          11- 1,82v
          12- 3v
          13- 3v
          14- 0v
          15- 1,14v
          16- 0,08v
          17- 0,13v
          18- 0,09v
          19- 10v
          20- 10v
          21- 19v
          22- 19v
          23- 20v
          24- 19v
          25- 19v
          26- 0v
          27- 0v
          28- 6,8v
          29- 0v
          30- 20v
          31-20v
          33-20v
          VDDA , ILIM_HIZ, CELL BATPRES WITH 0V ITS NOT NORMAL...
          [MOD EDIT]
          Link to schematic https://www.badcaps.net/forum/showthread.php?t=85795
          Reminder: rules and organization of this section - https://www.badcaps.net/forum/showthread.php?t=117483
          • mon2
            • Dec 2019
            • 14667
            Investigate the resistance across PR112. Remove all power. Meter in lowest resistance mode.
            Check the resistance across PR112 which should be ~10 ohms. This resistor is mated with REGN and you have posted REGN (pin #28) = 6 volts. VDDA is the other side of PR112 so VDDA should be ~6 volts. If it is not, PR112 is defective.
            • Sephir0th
              • Oct 2020
              • 1289
              As piernov already highlighted, a NVDC circuit should not deliver 20Volts at B+ and especially no 20V at the BATT+ rail. The simplest reason is usually the right one. A internal shorted PQ101 (or PQ102?) or even worse: You have these Dual-Mosfets not replaced with compatible components? But since you figured also some wrong /missing voltages around the charging controller the issue could be there instead, yes.
              This would be clarified immediately as soon as you share pictures of your work with the replacements visible.
              FairRepair on YouTube
              • Inforgalaxie
                • Apr 2023
                • 39
                • Portugal
                PR112 is gone..not have This resistor in motherboard...maybe when i used hot hair was remove This resistor..
                • mon2
                  • Dec 2019
                  • 14667
                  Post a clear picture of this missing part. It is required to be onboard but a solder short will also work in its place. Want to review the pcb pads where this part was located.
                  Remove all power. Meter in resistance mode. Measure the resistance across the 2 pcb pads for this resistor. What is the resistance?
                  • Inforgalaxie
                    • Apr 2023
                    • 39
                    • Portugal
                    Ok I will test and will post results.
                    • Inforgalaxie
                      • Apr 2023
                      • 39
                      • Portugal
                      I am testing...
                      • ipatch
                        troubleshooting microsoft surface pro 4 no power no led charge light
                        by ipatch
                        hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                        10-05-2023, 11:59 AM
                      • ruletero
                        Acer a515-43 low battery charge voltage
                        by ruletero
                        Hi
                        Acer A515-43
                        LA-H801P
                        Fail: Does not charge battery, has low voltaje on connector.
                        Laptop didn't want to turn on, only charge led blinked.
                        I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                        I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                        Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                        10-24-2022, 02:31 PM
                      • Klevjetack
                        Charge a L19D3PDA battery externally from the laptop
                        by Klevjetack
                        Is there a way to externally charge a L19D3PDA battery from the laptop. I have a broken charging port on my laptop and am trying to find a way to charge the battery for it. I have been doing some research and I have found that there is a module, TP4056, that can be used to charge Li-ion batteries. It says it is used to charge single cell Li-ion batteries. The L19D3PDA battery is a three cell battery. Is it possible to use the module to charge my battery and it would just be very slow? Or would that be a bad idea. Is there a different kind of module I can use to charge my Li-ion three cell battery?...
                        03-05-2024, 07:26 AM
                      • razenxd
                        How can I charge that battery pack?
                        by razenxd
                        it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
                        At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
                        Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
                        Now, I have noticed a few things.
                        The "dead" battery, while connected to charger and NOT Charging will...
                        12-05-2024, 06:11 AM
                      • Elektronror
                        Asus GL702VS No charge, unstable GPU power
                        by Elektronror
                        First post here, second if you count the introduction thread, so don't hesitate to tell me if I'm doing something wrong.
                        Bought a used Asus GL702VS which had been sitting for a while so it arrived with a dead battery. Plugging in the charger it came back to life and I didn't notice any problems with the computer. I also used it running on battery for 1-2 hours. I then played around with undervolting the CPU with the charger connected when a 10uF MLCC shorted AC_BAT_SYS. After removing the short, battery won't charge and the GPU has power limitations. I suspect that these are 2 different...
                        02-05-2021, 10:39 AM
