MacBook Pro 820-01598 - 5v 0a - complete novice
  • LeeMacManUk
    • Oct 2023
    MacBook Pro 820-01598 - taking only 5v 0a on the meter- I'm a complete novice and new to this wonderful forum. Ive been fixing Macs for 25 years but am finding that I need to ship my boards out for cap repair more often than not and as I now share my building with somebody with all the equipment to do board level repairs I want to try to fix some of those issues in house. I am finding so many time clients bringing in their mac's with zero power. I have been trying to understand some of the forum I have searched through and am a little out of my depth but want to learn if I can from you talented lot...
    I have been trying basically trial and error taking readings from various caps around the USB controller area (I think) , some are running at 5v and some have zero coming through. Most seem fine on ohm tests but again the values could be important from I have read over the last few days on other posts.
    I am slowly getting my head around openboardview and I think I can find locations of parts that way but again very new to this (sorry)
    I have found I can locate things quite easily when there is a photo of the board too.
    So, I have 2 of these 13" MBPros with the same 5v 0a input on the board with zero boot. Tried DFU mode, no beans...
    What would you folks suggest as the best step through guide to start to locate where the issue could be (I'm edging towards Usb controller end to be honest) but need to be guided by the pros...)
    Anything you could offer would be amazing as I'm sure with some time, energy and your input I can crack this...
    Cheers in advance for anything...
  • reformatt
    • Feb 2020
    • 1494
    Re: MacBook Pro 820-01598 - 5v 0a - complete novice
    Not to discourage you, but probably not the best machine to start out on. The A1466 Macbook Air is hands down the best to learn from, and the power sequencing is pretty well documented on logi.wiki. For the most part, these boards are very easy to fix.
    T2 machines are a bit more complex and you need to understand how they differentiate from the older machines and how that affects the boot process. Just because you have no 20V doesn't mean you have an issue with the USB-C controllers. It's usually because PPBUS_G3H is shorted or an absent PP3V3_G3H.
    The air intakes were moved on the 2018 chassis directly adjacent to the board and you often get shorted caps in these areas due to corrosion etc. Check the repair wiki for this model for common stock faults. Check all your rails for shorts first.
    • LeeMacManUk
      • Oct 2023
      "The air intakes were moved on the 2018 chassis directly adjacent to the board and you often get shorted caps in these areas due to corrosion etc. Check the repair wiki for this model for common stock faults. Check all your rails for shorts first." - will check these out as I am eager to learn. But falling at first hurdle...how do I find the repair wiki?
      • reformatt
        • Feb 2020
        • 1494
        https://repair.wiki/w/A2159_2019_13%22_MacBook_Pro
        Check out a few of Louis Rossman's video's. You do not need to immerse the board in copious amounts of flux like Louis does, Paul's amounts are more suitable.
        • envym
          by envym
          Hi everyone!
          06-27-2025, 08:54 AM
        • Flasman90
          Macbook Pro DFU Restore Issues
          by Flasman90
          I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
          - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
          - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
          08-30-2025, 10:27 AM
        • tobeend
          Bypass mdm macbook m2 ventura
          by tobeend
          1. RESET MACOS WITH IPSW
          a. Power off MacBook, press and hold the power button to enter Recovery
          b. Open Disk Utility, remove Macintosh HD
          c. Reboot, connect to the network to Activate Mac.
          d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
          d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
          e. Release the other keys, but keep holding the Power key for another 10 seconds
          f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
          05-26-2023, 07:18 AM
        • SarcasticOP
          General question about MacBook power rails for repair.
          by SarcasticOP
          I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
          • PPBUS_G3H (12.6V-12.8V)
            • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
          • PP3V42_G3H (3.42V)
            • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
          • PPVRTC_G3H (3.3V)
            • This
          12-12-2024, 05:50 PM
        • obelix24
          A2941 Macbook air 15” - 5V 0a
          by obelix24
          I’m working on one macbook air 15” m2 that was water damaged.
          keyboard, lcd, microphone connectors were damaged so i’ve replaced all of them and without screen connected macbook worked fine. Keyboard &trackpad and also lid sensor was working fine.
          i’ve put macbook in shelf and order new screen so i can fully repair it.
          Now i got the screen and macbook stays at 5v 0a.
          i’ve tried if it’s not in DFU with another macbook but it’s not detected at all.
          i don’t have schematics so i don’t know where to start can someone help me?...
          03-27-2025, 01:19 PM
