Hi everyone, I have a Dell I thought it might be the bios being damaged but I would like to ask if this has happened to any of you before. Thank you
Dell XPS 13 9343 (No Power)
Tags: None
Re: Dell XPS 13 9343 (No Power)
Yes Led Adapter is Function, press to power, led power is on for 2 second and turn Off. Uhmm ok, i'm remove motherboard on chassis ad remove eeprom and post reading eeprom. It's ok? Sorry for my bad englishComment
Remove all power. Measure the resistance to ground of each coil. A low reading can mean a shorted capacitor that will draw too much current and power down the board.
Original power adapter for this model? The dell adapters must communicate the adapter parameters using single wire protocol (Dallas / Maxim semiconductor). If this fails, motherboard will power off.
Often a mosfet in the adap_id line gets damaged. This will raise this issue as well.Comment
Assuming...7 Photos -
by PantherDaveHi all!
I'm trying to troubleshoot a Microsoft Surface Pro (5th gen) model 1796 that won't power on. Motherboard model is M1007506-015. My priority is retrieving data, but the SSD is integrated so it looks like if I can't repair it it'll need to go to a data recovery company. I've done a little basic board repair before, but nothing this advanced until now. So please forgive my ignorance in advance. ๐
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by Mark01Hi guys,
This is my first post! ๐
I have no idea what Iโm doing, but Iโm learning by trial and error.
Iโm currently working on a Dell Optiplex AIO 7490โone of a bunch of AIOs that mysteriously failed to POST just a few days after the warranty expired. The original issue was that the PC worked fine until it was rebooted, after which it got stuck on a black screen (no backlight), with fans spinning at normal speed and a solid white power LED. Forcing it off by holding the power button would just cause it to switch on automatically and get stuck again on...07-04-2025, 12:54 PM -
by zlr8rhey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
Ill try and give as much info as I can.
Dell Inspiron 17 (7786) Laptop
Service Tag: 5J0NHT2
Bios: 1.9.0
When I received this , it would only flicker on the KB backlight for a second, then off and on.
Then it started getting weirder!
Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has... -
by LimesKeyHi everyone, I have an Inspiron 7506 laptop I've had for a few years, and it'd occasionally have a problem where after I'd power it off, it wouldn't turn on again unless I disconnected, drained residual voltage by pressing the power button, and reconnected the battery. It now seems to be occurring every single time I shut down the laptop and attempt to turn it back on again. I have done all the common troubleshooting steps, such as completely disconnecting the battery & CMOS battery and draining the voltage and leaving it for an hour, and I've even replaced the battery. This is definitely...10-17-2025, 05:33 PM
- Loading...
