Asus X512F No Power
  • Ado02
    • Jul 2021
    • 100
    Asus X512F No Power
    I'm working on an Asus X512F laptop that wouldn't turn on initially. It did power up when I disconnected the keyboard, but it shut down soon after.
    I think the problem might be around the keyboard connector area, where the battery connector and Charging IC (BQ24780s) are also located.
    When the laptop doesn't charge or power on, the battery positive measures only 0.22v. When it does charge, it reads 6v. The ACDRV on the charging IC shows 3.15v, but it should be around 25v.
    Any ideas on what else I should check, or if I'm on the right track?
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: Asus X512F No Power
    What supply do you get to the first two N-FETs (Source, Drain, Gate), and for the BQ24780 (ACN, ACP, CMSRC, ACOK, ACDET, REGN, VCC), supply?
    • Ado02
      • Jul 2021
      • 100
      ANC: 3.18v
      ACP: 3.18v
      CMSRC: 3.18v
      ACOK: 6V
      ACDET: 2.62v
      REGN: 6v
      VCC: 19.8v
      • Techtiger
        • Oct 2014
        • 1602
        • france
        According to the measurements provided, two FETs are not switching. It seems that you haven't supplied the voltage readings for the first two N-FETs (Source, Drain, Gate). test them using a multimeter without power, in diode mode, on Source, Drain, and Gate. It's possible that one of the FETs or components connected to this line is faulty.
        • mon2
          • 14247
          With great care, flux and remove the ~4K resistor in series of the acdrv pin to the dcin mosfets. Do not lose this part. Then check if the acdrv pin outputs the ~25v without the 4K part. As noted a leaky dcin mosfet will cause this issue.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Better to check both fets in resistance mode(meter set to 200K or higher sclae).
            • GLISIT
              by GLISIT
              01-16-2025, 02:29 PM
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • PantherDave
              by PantherDave
              Hi all!
              05-29-2024, 02:01 PM
            • ShadowAi
              ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
              by ShadowAi
              Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
              Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
              After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
              03-15-2024, 10:46 AM
            • meraklinetx
              Asus Z97-a power cycle, no boot no cpu voltage
              by meraklinetx
              Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
              05-10-2023, 06:08 AM
