Are Laptops LCD panels swappable?
  • marcellodj
    • Nov 2010
    • 99
    Yes, i know, the question sounds stupid, but i mean using a spare lcd panel with standard 30 pin lvds connector to test on the fly laptops mobos.
    Just connecting the screen, turn power on the mobo and see if the magic happens, then turn off, thats all.
    Can i damage the motherboard?
    Thanks.
  • Wizard
    • Mar 2008
    • 2296
    Re: Are Laptops LCD panels swappable?
    Incorrect.
    Do research on LCD panel to make sure pinouts is same. I have seen very different pinouts even the connector is *same*.
    Cheers, Wizard
    • yyonline
      • Jul 2009
      • 692
      In my experience...they're swappable - to a point.
      I've replaced higher resolution screens with lower resolution screens, no problem.
      Lower resolution upgrading to higher resolution doesn't always work. Sometimes the data cable doesn't have enough pins to send the entire resolution. Sometimes it does.
      And as Wizard said, sometimes you run into one that uses some completely different standard. That said, I'm seeing less and less of this. It seems most of the newer laptops are mostly standardized. Older laptops are hit and miss.
      I've only done this with laptop LCDs. I've never tried it with a panel out of a standalone monitor or anything. Personally, I've never damaged anything, but I wouldn't say I have enough experience to say it's safe to do all the time.
      • marcellodj
        • Nov 2010
        • 99
        Thanks friends for quick replies;
        it was clear to me that low-res panel might work bad if attached to an hi-res video out eg svga vs sxga+.
        As stated by me, i want only use a spare lcd panel to TEST if mobo are WORKING.
        Thanks again,
        M
        • yyonline
          • Jul 2009
          • 692
          It's the opposite, actually.
          It's important to note that for a laptop, or any LCD, the image is scaled (resized) to the native resolution of the LCD screen. So, in a sense, the LCD is always getting a signal in its native resolution, even if it has to be resized on the way to getting there.
          A lower resolution panel is actually more compatible. The video card will usually detect the lower resolution, and drive the panel at that resolution.
          The problem comes when it detects a higher resolution panel, and tries to drive the panel at a higher resolution, but the data cable doesn't have enough wires, and it can't send all the data. I've seen varying results including no picture, garbled picture, and one case a striped picture where every other line worked.
          I work on a lot of laptops, and replacing screens is something I do on a about a weekly basis due to drops, etc. Customers often ask if it's possible to upgrade resolutions, change to glossy, change to matte, etc. Whenever I upgrade resolutions, I almost always have to change the data cable that goes between the panel and the video card to one with more wires. This isn't always doable, as some model laptops simply don't have such a data cable. For laptops where there was an option of a higher resolution panel from the factory, it's just a matter of finding the right cable.
          If I had to venture a guess, I'd say that a non-widescreen panel will have higher compatibility. Some older laptops might not know what to do if you hook up a widescreen panel.
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            i have noticed that most 15" wxga panels are swapable.
            diffrerent surface treatments,brands,ect but drop in compatible.
            • Wizard
              • Mar 2008
              • 2296
              That's interesting. But prudent to check the PDF papers.
              Cheers, Wizard
              • eccerr0r
                Sell or Shim Solar panels?
                by eccerr0r
                Well, due to my grid tie inverter not accepting high voltages, and the fact that the lions in my solar panels are 36V (72-cell) I think I need to stick with 72-cell.
                However I have a few smaller panels that are 36, 32, and two 30-cell. The 36 and 32 together run at 75% efficiency (and subtract more with additional inefficiencies) when running in parallel with the 72-cell panels. The kicker is that the two 30s... generate 0% power when connected in parallel(!)
                So now what to do with these small panels?
                I could sell them...
                Or I could shim them....
                03-29-2025, 01:07 AM
              • NanoTesting
                Anyone else been having problems with chinese laptops using ESSX8336 / ES8336 audio?
                by NanoTesting
                This audio chipset has been a pain to deal with, most of the time its impossible to find drivers for chinese laptops that have no name/brand, or generic rebranded laptops.
                Huawei also started to use it BUT they no longer host drivers on their website since they want you to force their PC manager app that often refuses to install after bios flashing and apparently the generic drivers around wont work on some intel systems and others wont work on amd systems, the generic ones have worked only once and i think i have had this problem on 30+ laptops so far in the last year.
                02-21-2025, 12:33 AM
              • dr.thodt
                Lenovo laptops unstable with sodimm ram
                by dr.thodt
                For the second time this week I received a Lenovo laptop with onboard ram and one sodimm slot. Both laptops run stable from their onboard 4GB RAM, but turn out to be very unstable when there's a sodimm inserted in the slot.
                Both times it was a GS44D/GS54D NM-C711 rev 1.0 board.
                Both times there were no loose pins on the slot and it did not matter what sodimm I put in. It just artefacts and crashes randomly when there's extra ram.
                What I did notice is that almost all coils have very dirty phases one the mosfet side when checked with an oscilloscope. Not something I see very often....
                06-07-2024, 09:16 AM
              • dsmartbox
                Any 11th gen Intel schematics of modern laptops
                by dsmartbox
                Hello Everyone,
                I am looking for schematics of good quality laptops and tablet with 11th gen CPU.
                I'm an engineer and I'd like to study them.
                I can find:
                - Macbooks
                - Surface laptops
                Does anyone have any schematics of 11th gen Dell XPS laptops, or other good-quality premium laptops and tablets?
                it would be much appreciated!
                02-08-2022, 07:28 AM
              • zungu
                Legacy CSM on new laptops?
                by zungu
                Since 2020, Intel provides UEFI 3.0 bioses without legacy CSM support. It means that for example, Dell does not provide anymore laptops since the xx80 series with Bioses including full legacy CSM support, but only with UEFI (some still provide legacy for USB only). It's true since 2019/2020 with Dell.
                I REALLY want full legacy support CSM (not with limited usb only), so I wonder if new dell bioses of laptops sold in 2021/2022 can be modded to get full legacy support.
                If it's not possible with dell, do you know if there is still a brand providing new laptops...
                12-16-2022, 08:01 AM
