Lenovo V330-15IKB - no picture
  • YellowJacket
    • Dec 2020
    • 105
    • Slovakia
    Greetings badcaps community,
    I would ask for little help with diagnosing Lenovo V330-15IKB, which I got as dead - after pressing the power button there was no reaction, just dead.
    Model: V330-15IKB
    Board number: LV315KB ; 17807-3 ; 448.0DC04.0031
    Serial number: R90Q6BW3
    (Schematic, boardview and resistances/voltages attached)
    When I got it, battery had 0V, so I am diagnosing it without battery, with original lenovo charger. After some searching, I managed to make it run by reflashing the bios - but I have no picture ( even on attached monitor ) and no reaction to caps lock/num lock on external keyboard. On the laptop keyboard, there is capslock diode ON all the time. I tried many bios dumps, but the result was still the same. I am using this one at the moment --> https://www.badcaps.net/forum/showth...p+%28Lenovo%29 ( post #2 ).
    Next, I tried to disable onboard RAM, by moving resistor R2010 to position R2009 - datasheet page 20, and this post helped me too --> https://www.badcaps.net/forum/showthread.php?t=100557 ( post #8 ). Still same result.
    So I am out of ideas, and I would like to ask you guys, with more experience, how can I figure out, why it is stuck? Is there anything, I can try? Or it is dead cpu/pch ( bad solder joint maybe )? If it helps, I was able to measure these signals:
    PLTRST# = 3.5V
    DDR4_DRAMRST# = 1.2V
    THERMTRIP# = 1V
    There is no voltage at one coil ( PL4803 ), with power rail 1V_VCCGT, I believe, its not necessary, since its igpu, right?
    Thank you very much for any hint.
    MOD Edit:
    Link to schematic - https://www.badcaps.net/forum/showthread.php?t=88250
    Reminder: rules and organization of this section - https://www.badcaps.net/forum/showthread.php?t=117483
  • reformatt
    • Feb 2020
    • 1418
    Re: Lenovo V330-15IKB - no picture
    Check input current with and without RAM. Check RAM connector pins are all solid to the PCB and free of debris etc.
    • YellowJacket
      • Dec 2020
      • 105
      • Slovakia
      CORRECTION in the picture: the coil for main power rail is not 4.5V, but 9.6V ( 4.5V was before flashing bios, when the laptop was dead ).
      Still, is it enough to be 9.6V at 19V_DCBATOUT power rail? I mean yeah, if there is battery connected without charger, there will be only ~8.7V here, but still, I am not sure ( datasheet, page 44 ).
      @reformatt - sadly, I am not able to measure current. I was trying to do it with an oscilloscope, across current sensing resistor PR4401, but I can't read any value. RAM connector is indeed clean and intact.
      • reformatt
        • Feb 2020
        • 1418
        Charger in this is a buck-boost converter so you won't see 19V there, it will be roughly the max voltage of the battery. You have Vcore on the CPU, so this proves that all the supplies are ok. CPU should at least be warm even if it's not booting.
        It's an Intel platform so your donor BIOS needs to have a clean ME region. I would suggest you upload your original BIOS to the BIOS group for repair and try that first, rather than using random donors.
        Monitoring input current during power on gives you an indication as to whether the CPU is actually running (as you will see the current varying up and down as it's begins to boot). This is why you need to try that with and without RAM to at least see if the system is recognising the RAM.
        • YellowJacket
          • Dec 2020
          • 105
          • Slovakia
          CPU is warm - the longer is board running, the more is temperature rising ( until some point of course ).
          Sadly, I was unable to read original bios ( either I did something wrong, or bios chip was damaged ), so I have no original dump. I wrote here before - https://www.badcaps.net/forum/showth...67#post1281467 ( post 56# ), that's why I used that bios dump. I don't know what else I can try without original dump.
          About current monitoring - I fully understand, and I always make this procedure during diagnosing, but not in lenovo case, where is middle pin ( rectangle charger connector ). Do you suggest me to inject 20V into the charger port? Would it work without using middle pin?
          Thank you for your suggestions, appreciate it.
          • YellowJacket
            • Dec 2020
            • 105
            • Slovakia
            Ok, I tried to inject 20V, during start with RAM current fluctuated between 370 - 440 mA, then it stayed at 380 mA.
            Without RAM it stayed at 300 mA.
            Note, onboard ram is disabled, as I mentioned before.
            • rddube
              Aspiring Expert
              • Jun 2013
              • 944
              Could you post a picture without heat sink please.
              • YellowJacket
                • Dec 2020
                • 105
                • Slovakia
                Attached. ( I was trying another stuff, so I decided to allow onboard RAM again, since it behaved the same. Just saying that, because on the photo you can see resistor strap on that place ).
                • minaedward
                  Lenovo Thinkbook 14 G2 no picture
                  by minaedward
                  Hi all
                  I have an Lenovo Thinkbook 14 G2 laptop with no picture
                  when pressing the power bottom the ESC and Caps lock led are on then the Caps lock goes off and ESC stays on but with no picture
                  earlier it startup but freeze at Lenovo logo
                  All voltages are present so I suspect the onboard ram
                  I flashed a disabled onboard ram Bios but with no success
                  There is a memid section on the schematic which I believe it concerns about the onboard ram
                  but I don't understand it
                  Anyone could help me with this issue is appreciated
                  (attached the memid part)...
                  05-14-2025, 12:50 AM
                • Nagyesz
                  Lenovo ideapad 330ICH - Dead, no volts on coils
                  by Nagyesz
                  Hi everyone, I replaced this motherboard because it was important to get it working, but it's been with me for a very long time. Now I finally have time to figure out what the problem is,
                  I've never encountered something like this before;
                  No charging light, full dead
                  Lenovo Ideapad 330-17ICH
                  • PL3102: 5 ohms
                  • PL3001: 3.2 ohms
                  • PL3101: 2 ohms
                  • PL5801: 3.5 ohms
                  • PL5501: 270 ohms
                  • PL701: 35 ohms
                  • PL501: 146 ohms
                  • PL503: 390 ohms
                  • PL402: OL (0.27V) +5VALW_P
                  • PL301: OL
                  • PL401: OL (0.03V) +3VALW_P
                  + Dc-in mosfet @PQ311 pin 5 20v, pin 1-4 0V , @PQ312 no volts...
                  10-11-2024, 10:12 AM
                • Zmay2509
                  Lenovo T14 nm-c931 1th gen intel 10th DEAD
                  by Zmay2509
                  Hi, I have dead t14 gen1 with nm-c931 motherboard.
                  Laptop doesn't turn on and does not show any sings of life.(battery is completely flat, do I need it for power on??)
                  When I connect usb c power adapter it draws 0.02A at 20v, I get voltage 20.5V up to 2nd mosfet and nothing out (PQ0006 before current resistor and buck-boost) when I touch gate pin of PQ0006 with tweezers it opens and I get 20.5v on current resistor;
                  But even with that "trick" I cant get laptop to turn on, that's probably because BQ25700ARSNR is not happy and not making VSYS15 rail.
                  03-25-2025, 02:44 PM
                • madan1
                  Lenovo Ideapad S130 is the CPU dead?
                  by madan1
                  Good day.
                  I'm trying to figure out what's wrong with a Lenovo Ideapad S130 motherboard. When I connect it to the bench PSU and limit the supply to ~2.2A (about the limit of the lenovo stock PSU), the board absorbs all the amperage and the voltage on the PSU drops down to about 4-5V.
                  The components on the board that get hot are the two mosfets ( 1 and 2 on the photo ) and the CPU. The resistance to ground measured on the power rail coils can be seen on the image (~17 and ~50 ohms). On the top of the CPU there are few caps which measure dead short. I checked all caps on the top side...
                  03-14-2024, 09:14 AM
                • reformatt
                  Lenovo NM-A921 (Yoga 900-13ISK2) dead
                  by reformatt
                  This machine has been in a few times with an intermittent fault of not charging. Motherboard is NM-A921 (https://www.badcaps.net/filedata/fetch?id=2051581)
                  So back again now, not working at all. Previously the adaptor had been replaced along with the DC charge port. This is one of these trapezoid shaped orange USB ports that Lenovo were using prior to going USB-C. It has 4 pins, but the DC connector jack on the PCB has 5 pins.
                  Fault presentation was the adaptor is only producing 5.2V, not 20V and this isn't reaching the input of the NVDC charger (PQ5/PQ6). There are 5...
                  02-05-2025, 05:24 PM
