a2337 PP5V_S2 missing no short.
  • khj
    • Jun 2023
    • 14
    • korea
    I have a a2337 m1 MacBook Air that has no power.
    PP5V_BSTLQ_SPMU is shorted so I fix it by change cap, coil, u7700. now normal voltage.
    when I didn't connect battery , plugged in power, there is only 5V 0.25a.
    so I checked every power rails , I finally founded PP5v_s2 is 0v, but there is no short.
    PPBUS_5VS2_VIN = 12V normal
    P5VS2_EN from U8100 = 0.6V maybe normal
    P5VS2_FB,PGOOD,VC,SS,BIAS,INTVCC = very low voltage maybe abnormal.
    what should I do ?? do I need to change uc300?
  • mon2
    • 14631
    The enable voltage may be too low. Check the resistance to ground of this enable signal line (without any power to the board).
    Also, review this video:
    https://academy.chinafix.tech/shipin...JoiBo7o_dMvDQQ
    • Guest
      A noob needs help for Apple Macbook Air M1 2020 A2337 - logic board short circuit
      by Guest
      Hello all!
      Recently I've got a broken Macbook Air M1 2020 A2337 of eBay with a broken screen and not turning on issue.
      After some tinkering I've found C5201 capacitor to be blown. This is where I hit a wall since I am a total noob in this area and have no idea what else to look for. C5201 is on one line with 3 more capacitors which visually seem ok, but beep on continuity mode and also both sides of all capacitors beep when tested with ground from the board. This to me sounds like a short, but I am not able to find what component is before the capacitors to test it....
      09-26-2024, 03:31 AM
    • Comp_Pro
      No short but PPBUS_G3H missing 820-01700
      by Comp_Pro
      Hello all,
      I have this 820-01700 board which came in with 5V 0.015A on the ammeter. Ammeter cycles every 5 seconds or so. Upon inspection I found PPBUS_G3H is reading around 0.6V. There is no short to ground. Diode mode reading is about 0.420V. When I remove fuses F7000 and F7001 the U700 side of the circuit produces 12.3V and the cycling goes away on the ammeter but still stays at 5V and now reads 0A. This goes away as soon as I put back the fuses. I tried injecting voltage onto the system side of the fuse pads but I do not get any current draw at all. I tried seeing if the voltage...
      09-17-2024, 05:04 PM
    • Instafixx
      Macbook A2179 820-01958
      by Instafixx
      Have a Macbook A2179 with liquid damage. Customer showed it some shop which has done an ultrasonic cleaning of the board.
      The board pulls 0V but doesnt turn on. No Fan SPIN. NOT IN DFU.
      I checked the Power Sequences below and found this -
      Once a valid external power source (Charger or battery) is connected, the following rails will come online.
      PPBUS_G3H: Normal voltage is ~12.6v on the charger with the battery disconnected. Produced from the ISL9240 (U7000, which uses PPDCIN_G3H as its VIN.
      PP3v3_G3H_RTC: Normal voltage is ~3.3v. Produced...
      05-20-2023, 05:19 AM
    • Arshad alam4659
      Macbook air a2337 wifi/Bt chip short
      by Arshad alam4659
      Macbook air a2337 part no 820-02016 wifi/bt chip is burned mark can I replace this chip will work I have same donor board...
      02-09-2025, 08:23 AM
    • Stephen
      MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
      by Stephen
      I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
      02-06-2025, 12:03 PM
