Good day folks. It's been a while since I repaired a laptop, so here's a challenge: a friend of mine asked me to take a look at an Asus G512LI killed by the liquid metal that got smeared all over the board when someone tried to clean it (I'm not blaming it on him - could have been someone before him). I was able to clean it enough to get it going on my own, without any help and thought I was all done, but then I ended up breaking it again
See, the battery wasn't charging and the laptop wouldn't start on battery either. If you were to start it on AC and THEN unplug the charger, it would still run on battery until it ran out, but it wouldn't charge the battery back. I figured the problem lies with the IC responsible for charging, the BQ24780S, on page 77 of the schematic, so I ordered one, replaced it.....and now the laptop doesn't turn on at all
Worth mentioning the chip gave me a lot of trouble to replace - either my technique or my tools suck - I HATE soldering QFNs, as it never seems to work the way others make it look. The solder didn't seem to want to stick to the pads of the chip - I could still see some gaps between the board and the pads when inspecting it sideways as close as I could with a regular magnifier, as I don't have a microscope. I pushed on for, I'd say, a few hours (!), even knocking some components around it off the board, until I got it looking "good enough". I replaced the supporting components as best I could and tried plugging in the adapter. Nothing happens now: I no longer get AC_BAT_SYS and subsequently, no other power rails. The only light at the end of the tunnel is that nothing dramatic happened either, like sparks or shorted components.
What happens is the first and second FETs (PQ8901 and 2) do not open to let 20v through to AC_BAT_SYS.
On the IC itself (adapter, no battery):
- VCC is 20v (good)
- ACDET is 2.7v (good)
- REGN is 0v (first bad sign right there, as it should be 6v)
- anything else: don't care at this stage or don't remember
With JUST the battery (11v at pack's output):
- VCC is 11v (good)
- BATSRC is 10.8v (good)
- BATDRV is 11v (bad) - PQ8903 is not open (Interesting that I get 3v at keyboard connector, but only because power from the battery goes through body diode of PQ8903. Pressing the power button, nothing happens)
- REGN is 0v (?) The datasheet says it should be 6v even in battery mode - paragraph 7.3.1.1 on page 17 says this. In my case, I was getting 6v on the OLD IC but only in AC mode, which might explain why it wasn't starting on the battery alone.
No shorts on REGN as far as I know. All resistors are in spec, even those that I accidentally knocked off. The 5 FETs have high resistance on all pins. I think I somehow killed the IC or didn't solder it properly. I now ordered a new one and will try lower heat and better flux. I wasn't pleased with how the joints ended up looking from the beginning...maybe this was it.
Link to schematic - https://www.badcaps.net/forum/showthread.php?t=119245
Reminder: rules and organization of this section - https://www.badcaps.net/forum/showthread.php?t=117483
- VCC is 20v (good)
- VCC is 11v (good)
