Lenovo E580 no power
  • Inforgalaxie
    • Apr 2023
    • 39
    • Portugal
    Hello I have this Lenovo E580 and i change the pwm and also pq102 but i have no valid gate power to arm the pq102 mosfet...just have 2.2v and must be more then 20v...
    PWM have 20V ACIN, and 6V REG
    What you think can be?
  • mon2
    • Dec 2019
    • 14329
    Re: Lenovo E580 no power
    This charger IC will be switching the mosfets @ PQ102 & PQ101 on/off to 'dial' up the voltage required for the operation of the logic board.
    The target voltage should appear @ B+ = VSYS pin # 22 on the charger IC.
    What is the final voltage to ground of B+ ?
    The gate voltages for each of these mosfets will be switching at high speeds so a standard multimeter will not be able to monitor the voltage. You will need an oscilloscope to view the switching action of the gate pins.
    If B+ is too low, remove all power and measure the RESISTANCE to ground of B+ pin.
    What is the measurement? If the resistance is too low then there is a shorted component on this main power rail.
    • Inforgalaxie
      • Apr 2023
      • 39
      • Portugal
      PIN 22 have 1.96V
      • mon2
        • Dec 2019
        • 14329
        Remove all power. Meter in resistance mode.
        Measure the resistance to ground of B+.
        • Inforgalaxie
          • Apr 2023
          • 39
          • Portugal
          20M ohms
          • mon2
            • Dec 2019
            • 14329
            If the battery is attached, remove it and test this power rail again.
            Suggest to remove all power, meter in resistance mode.
            Check the resistance of all mated mosfets in this region as follows:
            source & drain
            source & gate
            gate & drain
            Check PQ101, PQ102 and PQ103.
            Post each measurement. Checking for a low resistance = defective mosfet.
            • Inforgalaxie
              • Apr 2023
              • 39
              • Portugal
              PQ101 was the problem, 1.8 ohms resistance to ground. We found the problem.
              • PantherDave
                by PantherDave
                Hi all!
                05-29-2024, 02:01 PM
              • GLISIT
                by GLISIT
                01-16-2025, 02:29 PM
              • Mita99
                Lenovo Thinkpad P72 EP720 NM-B723 MB - Power disabled within 2 seconds after plugging the charger
                by Mita99
                Try to repair a Thinkpad P72 EP720 NM-B723 MB with I7-8850H processor and N18E-Q1-KB-A1 (P3200) GPU with 6GB memory. Unfortunately there is noinfo what happened to the laptop. I got it disassembled with parts missing, like keyboard, battery.
                Unfortunately I have no schematic available for me (requested in the sub porum) but got the boardview file.
                Symptom: after connecting to the charger the power led light up for one-two second and switch off. After a couple secons the power led light up for half a second and switch off. No battery, no IO board, no...
                04-27-2025, 07:20 PM
              • Dr.d
                Help please..Lenovo ideapad 5 14itl05 power and charging problem
                by Dr.d
                I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
                Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
                04-05-2024, 11:48 AM
