Surface Pro 7 - stuck on black screen, no USB power
  • Prott
    • May 2022
    • 154
    • Czechia
    Hello fellow badcappers!
    I have a question regarding startup sequence of Surface Pro 7 (but possibly it's similar to lot of newer laptops).
    The Surface 7 starts, all rails are present (the powerup sequence is done), CPU starts to heat up and I can hear activity (varying coil whine), but it never goes furter. No picture, no response to keyboard and I can't even get any power to USB ports.
    Can a bad memory cause this behaviour (CPU warming up but not enabling power to the USB ports) or is the CPU a goner? Or is there another possible culprit?
    I doublechecked and the BIOS should be fine (it's working on another S7 Pro).
    Thank you!
  • Prott
    • May 2022
    • 154
    • Czechia
    For anybody wondering - it was a faulty ram module (resistance under 6 ohms on the rail).
    • HTR-Informatique
      Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
      by HTR-Informatique
      YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
      I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
      On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
      I also changed the screen because the PC fell and the screen was broken.
      I changed the battery with a new and original battery.
      I also had corrosion/oxidation on the...
      02-09-2025, 06:51 AM
    • VcemPzd
      Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
      by VcemPzd
      Hello everyone !
      My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
      04-28-2025, 10:14 AM
    • howardc64
      by howardc64
      Problem
      08-04-2024, 10:36 PM
    • mgrharry
      Surface Laptop 2 Black Screen, Need Data
      by mgrharry
      Working on a Microsoft Surface Laptop 2 model 1769. The system powers on to a black screen with backlight which cycles on / off 3 or 4 times then it stays off. Prior to this it would stay powered on but with a black backlit screen -- in those instances the caps lock light would respond but there would be no video output despite trying both a MiniDP to VGA and miniDP to HDMI adapter that is supposed to be compatible with the Surface Laptop 2.
      Data is important so I'm hoping to salvage it. This issue is very similar to the earlier thread posted here but the Youtube video recommended...
      07-17-2023, 02:29 PM
    • Stunt
      Hp Laptop Stuck on Hp protected by hp sure start screen
      by Stunt
      Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
      I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
      I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
      Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
      screen that's it and stuck there. I left it until the following day and i still...
      09-02-2025, 01:51 PM
