HP OMEN-X 17T-AP000 not turning on
  • questore
    • Dec 2015
    • 564
    • csongrád
    Hello Everyone
    I have the laptop mentioned in the title that is turning on then turning off after a few seconds. (fan spinning)
    Board number is:
    DA0G3CMBCH0 Rev H
    I have not found any boardview or schematic.
    I have found that GPU line is 0.0 Ohm shorted, but the VRM mosfets are not shorted.
    YES indeed the short is 0.0 Ohm in resistance mode.
    I have lifted all the four GPU coils and found that the GPU line is 0.0 Ohm shorted.
    After this I have injected 0.9V and the board drawes 0.56A
    The problem is That no matter how much time I inject voltage, nothing gets got.
    I would guess the problem is one of the GPU capacitors but since nothing gets hot i do not want to remove all of them one-by-one.
    Do you have any idea How could i found the source of the problem?
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: HP OMEN-X 17T-AP000 not turning on
    First short your multimeter probes and see the readings. Then put black to GND and red on GPU coils-What is the exact resistance?(meter should be in 200 Ohms scale). GPU coils may show resistance as low as 0.2 Ohms depending on the GPU. So are you sure your GPU is shorted?
    • questore
      • Dec 2015
      • 564
      • csongrád
      Thank you for your time to answer.
      + My Probes are premium kind so it has 0 Ohms resistance when I short them together
      + Multimeter shows 0.0 Ohms when touched to GPU coil end. Sometimes it goes up to 0.1Ohms for a second. (nvidia 1070m)
      Also some more info:
      After lifting the GPU coils the laptop still starts when power button pressed and after 3 second the latop shuts down.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        With an nvidea 1070 chip, you can expect 0.1 ohms as not shorted. Take your pick.
        • questore
          • Dec 2015
          • 564
          • csongrád
          Ok thanks that explains the amperage draw not going higher.
          Then I start from the beginning.
          + No more coils that are low on ohms so I start by measuring the coils before and after power button pressed and POST you the result.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            These new gen GPU's are confusing many technicians. people who are working in this field for a couple of years, usually has an idea that 0.1-.03 ohms resistance is short as that used to be the norm earlier. But now things are really way different. yesterday had an asus amd ryzen gaming laptop with GTX1060 and gpu resistance was 0.1 ohms. I fixed the board and gpu was fine. So thumbs up from me for post#5
            • questore
              • Dec 2015
              • 564
              • csongrád
              I think I have to by a new multimeter that is more accurate and can show resistance until decimal characters of 3.
              • questore
                • Dec 2015
                • 564
                • csongrád
                When Plugged in the following voltages are present on coils:
                3.3v and 5V
                When power button pressed, one more 3.3v, 1.0v and a 1.25v is present on more coils.
                - I found that as soon as I plug in the charger (no button pressed), the GPU coils has 0.3V. Is that normal?
                G1 is 0.3v on the mosfet.
                GPU Mosfets are:
                E6930 dual mosfets
                https://datasheetspdf.com/pdf-file/1...tors/AOE6930/1
                If i understand N channel mosfets datasheet right then G1-D2=0.3V-20.1V should be between 1.3 and 2.1V but it is minus 19,8V so it should be turned off right? (G1=0.3, D2=20.1V)
                • mon2
                  • 14662
                  For N-channel mosfets, the GATE voltage to ground should be higher (boosted) than the voltage being passed between source & drain pins.
                  Often used for DCin mosfets where the adapter voltage is ~19 volts and the boosted voltage as applied by the BQ (BenchMarq / TI brand) charger ICs is:
                  ACDRV = adapter voltage + REGN voltage = 19v + 6v = 25 volts to enable the N-channel mosfet via the GATE pin.
                  If you suspected a defective mosfet, check its resistance.
                  Remove all power -> meter in resistance mode.
                  Check the resistance across:
                  source (1-2-3) & drain (5-6-7-8)
                  source (1-2-3) & gate (4)
                  gate (4) & drain (5-6-7-8)
                  * above pin #s are for a typical 8 pin mosfet.
                  Post each measurement. If the measurement is too low, the mosfet is most likely defective. Do flux and remove with care - be patient. Then test the removed mosfet after it has cooled down to see if the results remain similar or not.
                  • questore
                    • Dec 2015
                    • 564
                    • csongrád
                    I'm still just collecting informations, so please correct me if I'm wrong, but since alll GPU coils are driven by individual gates, and all of them have 0.37v on the coil and on all high side gates , thats shouts for a problem elsewere so I thought maybe the driver chip is the one to blame. So after searching a while i found a Up9511P Datasheet:
                    https://pdf1.alldatasheet.com/datash...I/UP9511P.html
                    After poking the pins I found that Ref voltages and 5VCC are present, but Enable and PGOOD are 0v and still the PWM1,PWM2,PWM3,PWM4 outputs are 0.37v.
                    It seems to me that this chip is need to be replaced. (Chip is not heating or anything)
                    Please confirm my theory.
                    • Sephir0th
                      • Oct 2020
                      • 1289
                      Personally i see no reason to dig somewhere in as long as it wasn't clarified whether all the other buck converters are enabled, have the correct voltages and healthy resistances to GND.
                      For example: The CPU needs to be fully powered before concluding any issue with the GPU
                      FairRepair on YouTube
                      • questore
                        • Dec 2015
                        • 564
                        • csongrád
                        I would agree if i would search for the power up sequence. But the values above are present as soon as i plug the charger. No power buttom pressed yet.
                        Also when i press power button, no voltages on CPU so you are right on that one.
                        • questore
                          • Dec 2015
                          • 564
                          • csongrád
                          Checked CPU PWM mosfets, there is 3 type of it (someone changed it multiple times maybe) marked TYPES on the top:
                          PMHE86903917c
                          PMKP86903112C
                          MPGP86901733B
                          Top view schematic and layout from this forum:
                          thread was:
                          https://www.badcaps.net/forum/showthread.php?p=1063196
                          All Mosfet gets:
                          + 1.45V on the PWM pin (ON PWR BUTN PRESS)
                          + 3.3V on VCC pin (ON PWR BUTN PRESS)
                          + 20v on VIN pin
                          + 2.8V on BST pin (ON PWR BUTN PRESS)
                          + 1.23v on CS pin (ON PWR BUTN PRESS)
                          + 0212v on VTEMP/FLT (ON PWR BUTN PRESS)
                          + 3.3v on SYNC (ON PWR BUTN PRESS)
                          BUT no voltage on the sw coils.
                          Coils have 1.8 Ohm resistance by default
                          • Sephir0th
                            • Oct 2020
                            • 1289
                            Resistance to GND could be fine for 7th gen i7...
                            however, you have again digged way to deep. i mean i have no problem with that, but it is basically waste of time. Ist the System Agent powered at least (+VCC_SA)?
                            • questore
                              • Dec 2015
                              • 564
                              • csongrád
                              Where should I check VCC_SA? no schematic or boardview.
                              CPU PWM manager is an MP2949A
                              (MP2949A datasheet)
                              • questore
                                • Dec 2015
                                • 564
                                • csongrád
                                Where to check next? Where is VCC_SA? Should I post pictures of the board 2 side?
                                • questore
                                  • Dec 2015
                                  • 564
                                  • csongrád
                                  Can Anyone help me where to go next?
                                  • questore
                                    • Dec 2015
                                    • 564
                                    • csongrád
                                    Looking closer on the board on MP2949A i have noticed that on ADDR_P pin there is two missing resistor. These two controls the PMBus addressing and the default is a 0Ohm resistor to ground, and no stuf on the 1.8v line, but as i see pictures of the motherboard on the internet, they both present. There is a table for the values but what values should i use for the correct address?
                                    • questore
                                      • Dec 2015
                                      • 564
                                      • csongrád
                                      MP2949A Controller voltages after power button press:
                                      1-12 CS: 1,2v
                                      13-23...not measured since the PWM-s are still in tri-state
                                      24 IREF: 1,2v
                                      25 ADDR_P: 0v
                                      26 VDD18: 1,81v
                                      27 SCLK: 1,02v
                                      28 SDIO: 1,02v
                                      29 ALT#: 126mv-> 1,02v
                                      30 VRRDY: 3,37v
                                      31 VRHOT#: 1v
                                      32 SDA_P: 3,36v
                                      33 SCL_P: 3,36v
                                      34 STB: 3,28v
                                      35 SLP_S0#: 3,36v
                                      36 PE: 0v
                                      37 EN: 3,28v
                                      38-43: 1.41V
                                      44 VDD33: 3,29v
                                      45 TEMP: 213mv
                                      46 PSYS: 0v
                                      47 VIN_SEN: 1,2v
                                      48 CS6: 1,2v
                                      • questore
                                        • Dec 2015
                                        • 564
                                        • csongrád
                                        Should I change the MP2949A Controller ??
                                        • reessi
                                          Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
                                          by reessi
                                          Hello:
                                          I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
                                          I started on the ACER:
                                          Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
                                          All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
                                          I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
                                          10-29-2024, 11:31 AM
                                        • Yanleb
                                          Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
                                          by Yanleb
                                          Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
                                          I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
                                          D608, good
                                          D618 RF101L4S, good (See warning 1 below)
                                          D619 RF101L4S, good (See warning 1 below)
                                          D865 RF101L4S, shorted (See warning 1 below)
                                          IC464 Inverter HA MC74HC1G14, shorted...
                                          03-09-2020, 12:00 AM
                                        • modtool
                                          HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
                                          by modtool
                                          Hi to all,
                                          the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
                                          I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
                                          I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
                                          04-01-2025, 08:22 AM
                                        • M1ch4L
                                          Lenovo Ideapad S145-15IWL Model 81MV Water damage.
                                          by M1ch4L
                                          Hello.
                                          First, I would like to extend my wishes for a Happy New Year to everyone.
                                          ... so I got this notebook for repair. The ntb is not turning on. A small amount of water was spilled on the keyboard and I found only 2 dried spots, patches on the motherboard. One around Mosfet PQ5302 but is not damaged and the second on JEDP1 connector.
                                          I measured:
                                          Mosfets:
                                          PQ5301 PIN:4 25,35V
                                          PQ5908 PIN:5 GT_PH shorted to the ground
                                          PQ5902 PINs 1-4 shorted to the ground
                                          Coils:
                                          PL5901 shorted to the ground
                                          PL5902 shorted...
                                          01-05-2025, 01:43 PM
                                        • barry101
                                          Apple 820-3662 VCore shorted to ground.
                                          by barry101
                                          Hi, Would appreciate some help.
                                          I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
                                          Get charger light but no fan spin or chime. No liquid damage.
                                          Found PPBUS and VCORE both shorted to ground. Other rails were ok.
                                          Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
                                          With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
                                          Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
                                          06-24-2025, 07:34 AM
