Is someone know about this problem, when laptop turn off and plug in charger then indicator will on and status charging, but when i turn on the laptop the indicator will change white like status full charging, but in the windows status charging but the battery percentase not up
hp 14 6050a3063701-mb-A01 ASHMORE
by dqtechearly problem this laptop is short 19v...after replace short capacitor (PC6005), this laptop does running okay...but the problem is battery percentage not increase...charging orange light is normal when insert adapter...
i have try replace 2pcs new battery but also same result...on status it saying "charging" but percentage not increase...this laptop also running okay with only battery (got 27% left)....
schematic/boardview link - https://www.badcaps.net/forum/troubl...ets-and-mobile... -
by coasterghostFor Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
System Hardware:
Processor: AMD Ryzen 7 PRO 5850U
Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...09-08-2025, 10:46 PM -
by PatriarxisHello.
i have this problem with a lenovo ideapade s145-15api.
The charging led stays on even when the charger is unplugged. Also in windows it shows that is charging.
Do you have any idea? -
by bembenoHP 15-e98se No power and The charging indicator LED is dim and flickering in white when i checked pl9,pl10 i found 2.8 volt when i checked pq35 i found that Drain = 19 v source = 2.8 and the gate = 2.6...10-12-2025, 09:18 AM
by KemerHello, the LED status indicators on my Lenovo Z580 are not working. Actually the motherboard LEDs are working but the light doesn''t coming to the front view. The plastic part is which you can see in photo must transfer the light to the frontview but just half of the plastic is illuminating.
There are three status indicators on the front (power, battery, caps lock), and none of them are illuminated.
The plastic piece doesn't appear to be broken.
1. What are your suggestions for resolving this issue?
2. Is the plastic piece made of special ma... - Loading...
