Bios flashing, protected IC regions
  • traveler0091
    • Aug 2023
    • 10
    • Armenia
    Guys, need a quick help.
    I'm trying to flash my laptop's bios with Clean ME.
    Laptop: DELL LATITIDE 5480,
    Motherboard: LA-E142P,
    BIOS IC: GD25B128C
    __
    Please see attached image.
    The programmer shows the IC has protected regions in SREG1, SREG2, SREG3.. The only one that I can unprotect is the SREG3...
    So, is this a problem? Can I flash the BIOS without unlocking the SREGs.
    Is this safe to do?
    My programmer is CH341.
  • mon2
    • Dec 2019
    • 14672
    Re: Bios flashing, protected IC
    I think there may be a misunderstanding.
    The WEL is greyed out because you DO want to be able to write to the device. This is write-enable-latch.
    If this flag is removed or off, the device will be read-only.
    QE = quad mode enabled. If the original is with QE bit set, leave it alone here.
    • traveler0091
      • Aug 2023
      • 10
      • Armenia
      Thank you very much for your reply and clarifications.
      I apologize for my naive questions. I'm doing this for the first time.
      I thought that if I flash it in this state, it might damage the chip.
      So, should I leave it as is (selected) and try to flash the IC?
      • mon2
        • Dec 2019
        • 14672
        Re: Bios flashing, protected IC regions
        You will not damage the ic but if the QE flag is off and the motherboard expects to operate in quad mode then the motherboard will not boot. To me, that is the only variable here. Then you will have to desolder the ic and enable the QE flag to test again.
        By default, all SPI bus flash devices operate in single bit or QE=off mode. To gain speed, QUAD mode and even faster modes were introduced to extract the contents faster but both sides of the circuit need to handshake to function.
        Suggest to leave QE flag checked. If the motherboard does not use the QUAD mode opcodes, no issue. If the motherboard does use them, this flash chip will respond correctly.
        • traveler0091
          • Aug 2023
          • 10
          • Armenia
          I highly appreciate your help and recommendations.
          The flashing process was successful!
          • James Jackson
            Panasonic CF-20G0247VM BIOS Bad Flash Help
            by James Jackson
            I usually try to figure these things out on my own but am asking for help now as I have been beating my head against a wall.
            Backstory, I initially ended up with a CF20 Mk2 with a locked BIOS. I used aptio to read the BIOS and made the adjustments to the .rom file and attempted to write it back with aptio before reading other users problems with that setup. Well it bricked the BIOS go figure. Computer no longer boots, black screen. I found a clean BIOS on this forum but now I am having ME issues. So I would rather hand over the aptio dump(pre BIOS brick) and a hardware reader dump(post...
            05-01-2025, 11:28 AM
          • spmetroil
            Request: SPI Flash BIOS Dump (Winbond 25Q128) for Dahua NVR4216-4KS2
            by spmetroil
            I am trying to repair a Dahua NVR4216-4KS2 that is not booting.
            The main BIOS/firmware is stored in an SPI flash EEPROM (Winbond 25Q128, labeled as U130 on the PCB).
            I have a CH341A programmer and I already attempted the following steps:
            1. Identified the correct chip (W25Q128, 3.3V SPI flash).
            2. Tried to read the contents with CH341A Programmer software. The dump seems corrupted and I often get the error: “Chip with the contents are in disagreement.”
            3. Compared several chip type selections (24Cxx and 25Qxx families) to confirm it is indeed a 25 series SPI
            08-19-2025, 09:23 AM
          • what_1282105
            Thinkpad t480s, completely dead after BIOS flash using CH341A programmer
            by what_1282105
            Following this guide (https://www.reddit.com/r/thinkpad/co...g_and_flashing) i re-flashed my t480s BIOS using an external (CH341A) programmer. The flash didnt work, so i reverted back to my BIOS backup successfully. The BIOS in the chip and the BIOS backup file are identical according to windows' file compare. The revert, however, didnt work: the only thing the computer does is flash the power button 3 times when AC power is connected. I've tried unplugging the CMOS battery, holding the reset button and holding down the power button- no signs of life....
            02-14-2025, 07:27 PM
          • garretofriviaaaaa
            ASUS GL702V Bios flash
            by garretofriviaaaaa
            Hello all, so basically I have a bricked GL702V with no power except a single LED flash on the power button when it is pressed. Customer had tried to flash his bios with a USB and the GL702VM310 version of this laptop's bios. I've been scouring the web for a correct version of his bios but all the ones on the ASUS website are for GL702VM, GL702VT, GL702VS, or GL702VI with versions varying from 300-310. This specific laptop has nothing other than just the GL702V so I don't know which bios is compatible with it. I was planning on programming it with the CH341A programmer as soon as I found the correct...
            03-28-2024, 04:58 PM
          • survivalbloke
            If I flash this bios file, will it just work, or does it need the ME cleaning?
            by survivalbloke
            I'm not a super pro like some here, when it comes to firmware. I have a machine with the following specs:
            ENVY X360
            15-ew0013dx
            SN: CND2261KS3
            Prod: 698V0UA
            Board: LA-M021P Rev 1A
            Chip# Winbond 25R128JVSN​
            Basically, when I power it up, I get no video, and the fans run hard - nothing else. Seems like a BIOS issue to me, so I posted a request in the BIOS request section. I haven't heard anything back(and that's fine) So I tried downloading the BIOS from HP, then I extracted it and flashed it onto the chip. Unfortunately, all I get is the power...
            10-09-2024, 08:40 AM
