A1466 PPBUS_Shorted
  • Instafixx
    • Jul 2022
    • 374
    • India
    A1466 PPBUS_Shorted
    Namaste!
    I have a Macbook A1466 820-00165 with a PPBUS_G3H shorted to ground.
    Removed the Fuse and i checked all the tantalum capacitors.
    Found the shorted one. Removed it.
    Now no Short.
    Replaced the capacitor. Replaced the Fuse, but still getting only 1V on PPBUS_G3H.
    I thought maybe the fuse was bad. Hence replaced it as well. But as soon as i plugged in the charger, the fuse burned.
    What can be the issue here ?
  • mon2
    • 14662
    Re: A1466 PPBUS_Shorted
    If the fuse is burning, then there is an excessive current draw on the rail.
    Remove the fuse and power up again. Check the voltage of ppbus_g3h to ground. Is it normal? If not, then ISL side needs to be reviewed.
    Do not apply the fuse till the downside rail is with a high resistance to ground. Had the same fault last week and fault was a single shorted cap. Perhaps you have more than one on the board with a short.
    Be sure the fuse you are using is the proper rating of 8A - fast blow in 1206 package.
    • Instafixx
      • Jul 2022
      • 374
      • India
      Without the Fuse.
      Voltage on Pin#2 is 0.7V
      Voltage on Pin#1 in 8.6V
      • mon2
        • 14662
        Measure the resistance to ground on pin # 2 (no fuse installed).
        • Instafixx
          • Jul 2022
          • 374
          • India
          Diode Mode Reading of Pin#2 (Meter Set to 2k Scale)
          Red to Ground .423
          Black to Ground 1.302 .
          • Instafixx
            • Jul 2022
            • 374
            • India
            Found another Capacitor Shorted. Replaced. Resolved
