820-00165 SMC Issue
  • Instafixx
    • Jul 2022
    • 374
    • India
    820-00165 SMC Issue
    Namaste!
    I had a Macbook A14666 come in for not getting on.
    PPBUS_G3H was at 8.15V. Did a SMC Reball and the board started working.
    After 3-4 days it again went on.
    Again SMC reball and again it starts working but goes off again in 2 days.
    I assumed that the SMC is bad. Didnt have a donor board so i ordered SMCs from china. The chip number is the same. After installing the new chip i only get Fan Spin at Max and No Light.
    Do these require any programming? Anyone has any experience in this?
    Also i reballed the OLD SMC and installed it. The machine boots with Max Fan Spin.
    ASD shows PPF004 and PPF003. I changed the Fan too but its still the same.
  • mon2
    • Dec 2019
    • 14006
    Re: 820-00165 SMC Issue
    What is the current draw?
    • reformatt
      • Feb 2020
      • 1400
      SMC's can't be programmed from blank, so must come from a donor board. This should be the case from Aliexpress, however I wouldn't trust them. In the times I've bought SMC's, they were corroded and wouldn't reball properly. I buy boards off eBay etc mainly for parts rather than going via China. You don't know what you are getting.
      You are able to reprogram them using a bootable USB that Paul Daniels and others came up with some time back. But the board must first be able to boot in order to do that. You can use a 820-3437 SMC on a 820-00165 board for example, and re-program using the tool.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        SMC's ordered on aliexpress never works. Thats my experience so far.
        • Instafixx
          • Jul 2022
          • 374
          • India
          Where else can i get these chips that will work?
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Only from scrap board of same model. Wherever you buy from,its all garbage.No point wasting money. has to return many logic boards for want of genuine SMC.
            • reformatt
              • Feb 2020
              • 1400
              If you are going to repair MAC's, you try to amass donor boards for parts like SMC's. You strike a deal with customers with machines that are beyond economic repair, or keep a lookout on eBay etc for non-working boards. Some can be fixed, some have been butchered.
              Even the boards from Aliexpress have their uses for donor connectors or masse swapping of components in cases of liquid damage.
              • rounin
                MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                by rounin
                🛠 Original Issue
                ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                04-19-2025, 01:18 AM
              • ugamazing
                by ugamazing
                12-17-2024, 07:05 PM
              • elmark
                HP 15-cw1002ua strange keyboard issue
                by elmark
                HP Pavilion 15-CW1002UA
                S/N 5CD0251CBC
                P/N 7KE54EA
                Hello guys!
                I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
                It powers on OK and has no other issues except the following:
                • CAPS LOCK does not work at all
                • Fn button toggles Flight Mode
                • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
                • (with SHIFT pressed: 't%' and 'y^' respectively)
                I initially thought it was a keyboard malfunction (internal short, etc.),
                but when I press and hold...
                06-27-2025, 01:10 AM
              • Simone Vergani
                Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
                by Simone Vergani
                I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
                To assist with troubleshooting, I'm attaching two power circuit schematics:
                • Power
                03-05-2025, 02:25 PM
              • wizard13
                Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
                by wizard13
                I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
                I have checked the forum and the available documentation but could not find a solution specific to my issue.
                • Brand & Model: Dynabook Satellite Pro C50D-B-100
                • Part Number (P/N): PYU13E-00C00PFR
                • Serial Number (S/N): 22028896H
                • System Configuration (SC): A1PYU13E1127
                • Motherboard Model: IP3_ACN16_MB_V21_20211222A
                • Power Input: DC 19V –
                02-28-2025, 02:43 AM
