820-00165 SMC Issue
  • Instafixx
    • Jul 2022
    • 374
    • India
    820-00165 SMC Issue
    Namaste!
    I had a Macbook A14666 come in for not getting on.
    PPBUS_G3H was at 8.15V. Did a SMC Reball and the board started working.
    After 3-4 days it again went on.
    Again SMC reball and again it starts working but goes off again in 2 days.
    I assumed that the SMC is bad. Didnt have a donor board so i ordered SMCs from china. The chip number is the same. After installing the new chip i only get Fan Spin at Max and No Light.
    Do these require any programming? Anyone has any experience in this?
    Also i reballed the OLD SMC and installed it. The machine boots with Max Fan Spin.
    ASD shows PPF004 and PPF003. I changed the Fan too but its still the same.
  • mon2
    • 14664
    Re: 820-00165 SMC Issue
    What is the current draw?
    • reformatt
      • Feb 2020
      • 1497
      SMC's can't be programmed from blank, so must come from a donor board. This should be the case from Aliexpress, however I wouldn't trust them. In the times I've bought SMC's, they were corroded and wouldn't reball properly. I buy boards off eBay etc mainly for parts rather than going via China. You don't know what you are getting.
      You are able to reprogram them using a bootable USB that Paul Daniels and others came up with some time back. But the board must first be able to boot in order to do that. You can use a 820-3437 SMC on a 820-00165 board for example, and re-program using the tool.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        SMC's ordered on aliexpress never works. Thats my experience so far.
        • Instafixx
          • Jul 2022
          • 374
          • India
          Where else can i get these chips that will work?
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Only from scrap board of same model. Wherever you buy from,its all garbage.No point wasting money. has to return many logic boards for want of genuine SMC.
            • reformatt
              • Feb 2020
              • 1497
              If you are going to repair MAC's, you try to amass donor boards for parts like SMC's. You strike a deal with customers with machines that are beyond economic repair, or keep a lookout on eBay etc for non-working boards. Some can be fixed, some have been butchered.
              Even the boards from Aliexpress have their uses for donor connectors or masse swapping of components in cases of liquid damage.
              • rounin
                MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                by rounin
                I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                🛠 Original Issue
                The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                04-19-2025, 01:18 AM
              • ugamazing
                Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                by ugamazing
                I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                12-17-2024, 07:05 PM
              • shahnld
                Lenovo legion 5 pro startup issue
                by shahnld
                Good day Experts
                I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
                A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
                And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
                08-24-2025, 12:31 PM
              • ahmarzo
                Acer laptop battery draining issue
                by ahmarzo
                Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
                Help me to diagnose this issue as there is no shortage in the inputs MOSFET
                08-02-2025, 06:39 AM
              • elmark
                HP 15-cw1002ua strange keyboard issue
                by elmark
                HP Pavilion 15-CW1002UA
                S/N 5CD0251CBC
                P/N 7KE54EA
                Hello guys!
                I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
                It powers on OK and has no other issues except the following:
                • CAPS LOCK does not work at all
                • Fn button toggles Flight Mode
                • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
                • (with SHIFT pressed: 't%' and 'y^' respectively)
                I initially thought it was a keyboard malfunction (internal short, etc.),
                but when I press and hold...
                06-27-2025, 01:10 AM
