hp 15 dar62cmb6a0 usb 3.0 not working
  • mo000
    • Nov 2017
    • 285
    • algeria
    hi
    i have hp 15 dar62cmb6a0 both usb 3.0 not worknig but usb 2.0 works fine
    one usb3 port USBP0+ (D+) gives me short to the ground according to the schematic and boardview this lines goes directly to the PCH
    other usb 3 port i have 5v and d+,d- 3.3v but not working
    when i try usb keyboard all led in keyboard on but not working
    is that means pch is defective
    can i remove L37 and L36 of each usb 3.0 port and take d+d- lines from usb 2.0
    without any risk ?
    i notice D13 becomes very hot other side of the diod gives low amps reading 0.15amps
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: hp 15 usb 3.0 not working
    USB3.0 port wont work if you take data +/- from usb 2.0 line. Going by the readings, its seems PCH's usb3.0 section is shorted. You can try disconnecting the coil for the port which shows d+ short to GND and see if the other usb3.0 port works.
    • mon2
      • Dec 2019
      • 14662
      A usb3.0 widget operating in USB 3.0 SS (superspeed) mode does not need USB 2.0 D+ / D- lines to function.
      Reference:
      https://electronics.stackexchange.co...ss-enumeration
      Respectively, the USB 2.0 D+ / D- lines can be removed from the USB 3.0 connector but that port will lose the ability to support USB 2.0 and slower devices (ie. Only USB 3.0 SS devices will function on this port).
      Do check if the non-working ports are fitted with USB 3.0 and USB 2.0 esd tvs diodes. These parts may be damaged and causing the short circuit status. If present, remove each and check if the short is gone or not.
      • mo000
        • Nov 2017
        • 285
        • algeria
        Reference:
        no esd diode i check the schemetic only coil , even the clamp diod and caps not found on motherboard .
        • mo000
          • Nov 2017
          • 285
          • algeria
          yes i already disconnect the coil but the other usb 3 port still not working
          i think i will disconnecting both usb 3 coils and use uab3.0 to usb2.0 hub maybe this working .
          • mon2
            • Dec 2019
            • 14662
            Re: hp 15 dar62cmb6a0 usb 3.0 not working
            If you disconnect the USB 3.0 signals then you only need a USB 2.0 hub. Suggest to test USB 2.0 HS hub. They are dirt cheap. A powered hub is recommended.
            • Stanley1843
              by Stanley1843
              06-29-2024, 11:54 AM
            • MMH3
              Dell Optiplex 5050 SFF - strange behavior and service_mode jumper not working anymore
              by MMH3
              i have many 5050sff. all of them, and how i experienced over many years for all about 250 DELLs goin through my hands, are fully flashable and can be serviced in any way when the service_mode jumper is set.
              Never ever i experienced problems with that.
              Now i have one 5050sff machine, where this jumper isnt working at all.
              I do not get the normal messge that the jumper is set when booting and a short test with FPT just confirms this. Everything is locked -->> EVEN for reading !?
              The history of the machine is that i used it in my office...
              03-23-2025, 09:28 PM
            • DynaxSC
              GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
              by DynaxSC
              I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
              There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
              The board is generally working now, all PCIe ports are working, Windows installs normally.
              However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
              The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
              03-10-2025, 12:27 PM
            • obelix24
              Macbook Air 2020 (a2179) - touch id not working
              by obelix24
              Hi i have one Macbook Air 2020 where touch ID is not working (it's not scanning fingerprints). Touch ID was working before, there is no error message during scanning fingerprint it's just not scanning on screen you can see only fingerprint but there are no red updates as when it's working. Power button is working fine.
              I've checked boardview and also schematics but i'm not able to find anything related to TouchID ... i have similar issue on a2338 where there was problem with PP3V0_TOUCHID​ and after replacing UT610 it was working but here i'm not able to find anything related to...
              02-09-2025, 12:57 PM
            • howardc64
              by howardc64
              07-24-2025, 05:17 PM
