Dell battery not charging
  • inkman
    • Sep 2019
    • 55
    Dell battery.
    7.4v
    Genuine dell charger.
    I have this dell battery thats been left on storage for long time
    and its not charging anymore inside laptop.
    Software aida 64 indicates battery has zero wear level,voltage at 2.8v.
    I am using it in dell computer it came with.
    When laptop is running, aida 64 indicates battery is not charging.
    I think battery is locked.Please help me revive this battery, it is in really
    nice condition.Any question please ask.
    • 21446
    Re: Dell battery not charging
    Does this laptop have a model number, does the battery have a model number
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Check whether adapter is recognised in bios setup or not?
      • inkman
        • Sep 2019
        • 55
        Thank you SMDFlea.
        The laptop is Dell latitude E5450.
        The battery is genuine Dell, 51wh, GSM10,7.4v.
        I have another GSM10 battery which charges fine on this laptop.
        When i replace this faulty battery it does not charge.
        • inkman
          • Sep 2019
          • 55
          Thank you mcplslg123.
          Adapter is recognised as 90w.
          With faulty battery communication error is displayed in dell bios.
          • Vesko356
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria 🇧🇬
            Thank you SMDFlea.
            It's G5M10 battery. It's over-discharged and probably (99%) the controller locked the battery and cut the main battery power line by sending the signal to controlled battery fuse. This battery can not be dissembled easily or at least without damaging the battery housing by the inexperienced person. But if you want to try some repair attempt at home you can try to charge the cells to 3.3V each, check the fuse and try to charge the battery in the laptop again, if it's doesn't help there's nothing you can do more without the special equipment and knowledge on a subject.
            Become a Badcaps supporter
            Thanks to all supporters.​
            • Bowline
              by Bowline
              06-11-2025, 10:13 AM
            • lawrenceptrini
              Battery not charging - Dell Inspiron 3593 FD155 LA-JO81P (REV 1.0) (A00)
              by lawrenceptrini
              Hi Guys,
              I am seeking some assistance with a Dell Inspiron 3593 FD155 LA-J081P (REV 1.0) (A00) laptop
              The laptop is working fine with the adapter plugged in and also with a charged battery.
              Problem is that the laptop is not charging the battery. The battery is recognized in the bios but the
              ac adapter is listed as 'Not Installed'. So for instance, when a charged battery from another source
              loses its charge, it stays on 0%.
              Measurements taken
              Charging IC (ISL95522HRZ) 32 pins
              Voltage to ground with ac adapter only plugged in:
              1)...
              08-26-2024, 06:45 PM
            • shatteredhalo
              Dell Inspiron 15 5559 AAL15 LA-D071P battery not charging
              by shatteredhalo
              I'm troubleshooting an issue with a laptop where it doesn't seem to want to charge the battery. The laptop will run off the battery alone and use/drain the battery normally in this situation, it will run off the AC adapter alone, and it will run with both charger and battery connected, but it doesn't seem to charge the battery under any circumstance.
              At startup of the laptop, the following error message is displayed by Dell SupportAssist: "Alert! The AC power adapter wattage and type cannot be determined. The battery may not charge. The system will adjust...
              08-20-2020, 09:45 PM
            • Grucha98
              Dell Latitude E7440 battery not charging only works on AC Adapter LA-9591P
              by Grucha98
              Hi, i have problem with dell E7440, battery is not charging. Idk all story. Original Dell Adapter broken up (its not give 19V) i guess first ac adapter broken up and it broken charging circuit in laptop. Laptop has clone battery (Green Cell)
              Laptop works on clone adapter, and its not charging battery. Like on photo. I checked mosfets near battery plug. They are not shorted. But on PQ809 and PQ810 are low on diode mode (both 0.25V) I desoldered them and check on bench and they are good both 0.5V on diode mode. I checked only drain - source way. So its board circuit it should be higher,...
              09-09-2024, 11:22 AM
            • Julian Bailey
              HP ProBook 445 G8 Battery not charging
              by Julian Bailey
              Hi all
              We have in a HP ProBook 445 G8 laptop with AMD Ryzen 7 CPU. When power is connected the power LED light blinks 5 times then stops. Normally HP laptops will blink this LED 10 times as it does a self test when the AC adaptor is inserted. So there must be some sort of short somewhere.
              The battery doesn't charge, and is erratic on the MM voltage. Bench PSU LED pulsates when the battery is connected also. So the fault must be on the charging circuit?
              I have gone around the board with a MM and cant find anything
              Windows shows the battery fine,...
              10-11-2024, 10:34 AM
