GPU N17E-G1-A1 resistance
  • Dreigas
    Hobbyist
    • Feb 2023
    • 27
    • Lithuania
    I'm a pretty newbie at electronics (and English too so sorry for my English) and have some basic questions. Maybe someone can help me with this.
    I have a faulty Acer C5PRH_LA-E921P laptop motherboard.
    I got this one just for learning/test purposes and now I have some basic questions.
    I heard, that some GPUs and CPUs have very low resistance. Maybe someone has info about the CPU/GPU list and normal resistances for them?
    For example, now GTX 1060 6GB (N17E-G1-A1) has 0.1Ω (on these three big coils), is it short or just normal for this GPU? If I try to make a power injection which voltage for this GPU i should choose with an A limit to not burn it?
    And what about the CPU? I think there is I7-7700HQ and this CPU has 1.4Ω and 3.2Ω near cpu coils.
    Maybe someone knows some YouTube video, that can explain more about similar situations?
    Thank you for your time for my stupid questions.
  • natic
    • Sep 2018
    • 34
    • EU
    Re: GPU N17E-G1-A1 resistance
    Hello!
    This resistance is too low in my opinion. If I'm not mistaken the normal resistance for this type of the GPU is about 0.5Ω.
    If you have an option check your measurement with another meter.
    These resistances seems normal to me.
    What is the exact issue of this board?
    • Sephir0th
      • Oct 2020
      • 1289
      The resistance is a suspect but the final clue comes from the behaviour, respectively thenpresent voltages all over the board.
      FairRepair on YouTube
      • cind12
        GTX 1080 TI Gigabyte Aorus low resistance on vmem
        by cind12
        Hi guys, i was wondering, i've got 9Ohms on Vmem, one of the mosfet was shortet to ground, so i've desoldered hi and low mosfets nad still low res, then i removed all of the memory chips, and the resistance is still low, so did you had maybe a card with that low res on memories, and the card was working fine ?
        Removed the U1866Q and still without result, i dont have thermal cam so can't see where is hot spot when incjeting voltage.
        The resistance on core is ok 0.1Ohm ((Power 0.8V when on)
        Resistance on 12V 4K ohms (Power present when on)
        Resistance on 12V PEX 4K ohms...
        12-08-2023, 09:09 AM
      • karoliens
        820-01700 PPVCC_S0_CPU normal resistance to ground/diode reading?
        by karoliens
        I am working on this board that has some water damage though not around this rail but I measured it anyway to rule out that CPU is not fried.
        Resistance to ground on PPVCC_S0_CPU rail is 2Ohm and in diode mode it shows 0V.
        What is the normal reading on that rail?
        TIA
        09-11-2022, 12:55 PM
      • Nagy Daniel
        Lowest possible resistance on laptop motherboard rail - Guide Table request
        by Nagy Daniel
        Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
        I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
        I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
        So, I generated a table with AI so I can...
        03-04-2025, 08:24 AM
      • Instafixx
        Macbook A2179 820-01958
        by Instafixx
        Have a Macbook A2179 with liquid damage. Customer showed it some shop which has done an ultrasonic cleaning of the board.
        The board pulls 0V but doesnt turn on. No Fan SPIN. NOT IN DFU.
        I checked the Power Sequences below and found this -
        Once a valid external power source (Charger or battery) is connected, the following rails will come online.
        PPBUS_G3H: Normal voltage is ~12.6v on the charger with the battery disconnected. Produced from the ISL9240 (U7000, which uses PPDCIN_G3H as its VIN.
        PP3v3_G3H_RTC: Normal voltage is ~3.3v. Produced...
        05-20-2023, 05:19 AM
      • cook
        HP Power Supply 6632A: Fast Mode vs Normal Mode?
        by cook
        FAST MODE vs NORMAL MODE
        I have recently acquired a HP 6632A DC power supply. I am just beginning to use it and I have been reading the manuals for it. It is the first power supply I have ever owned or used. I am a very beginner hobbyist and do not have an engineering background, as may be obvious by my question...
        I can't seem to understand what the actual use is for the 'Fast Mode' or the 'Normal Mode' on the power supply. Although the manual states what the two modes do from a engineering/technical standpoint, I don't know enough to understand what it all means,...
        06-07-2020, 05:32 AM
