Zbook 15u G6 (PR/ID 4YW47AV) not charging
  • alfanikos
    • Jul 2013
    • 39
    • Greece
    Re: Zbook 15u G6 (PR/ID 4YW47AV) not charging
    Originally posted by mon2
    The DC jack measurements look to be ok to me. One is the main adapter feed and the other is an analog voltage used to gauge the power rating of the mated adapter. The EC controller (8051 based) will sample this voltage using an Analog to Digital port to determine the specs of the adapter.
    With extreme care, can you measure the voltage to ground of the ACOK (pin 24) pin on the charger IC? This is the final status of the power adapter being used. If it is a logic '1' = ~3v3 then the adapter is accepted as being OK to power this logic board.
    No we do not have the 3v3 Actually the P3V3DS is 0 Volts
    • alfanikos
      • Jul 2013
      • 39
      • Greece
      What is the voltage to ground of VRAVDD (pin 18) on the charger IC area?
      This is the voltage required to power the charger IC.
      it is 5.01 volts
      • alfanikos
        • Jul 2013
        • 39
        • Greece
        New measurement taken
        Motherboard removed and connected to Power supply without battery
        It seems that P3V3DS is missing.
        How to trigger?
        • alfanikos
          • Jul 2013
          • 39
          • Greece
          @mon2
          Can you please check the attached pdf with voltage measurements?
          Do you suspect any faulty fet so as to check the resistance between S-D, S-G and G-D?
          I understand that all measurements should be at the range of Hundred K ohms
          • mon2
            • Dec 2019
            • 14229
            Remove all power. Meter in resistance mode.
            Measure the resistance to ground of P3V3DS. Checking if there is a short on this power rail that may have stopped this rail from operating. If the resistance is ok then check the voltage to ground at the input of the voltage regulator that creates this rail from PVBAT (U60100). Also check if the enable for the same regulator is present to enable the power rail. Inspect this regulator for possible damage.
            • alfanikos
              • Jul 2013
              • 39
              • Greece
              #26
              The IN to the regulator are both
              1. EN_3V = 0 Volts
              2. #V_LP =0 Volts
              No in
              • alfanikos
                • Jul 2013
                • 39
                • Greece
                #27
                1. EN_3V = 0 Volts
                2. #V_LP =0 Volts
                No in
                See attached
                • mon2
                  • Dec 2019
                  • 14229
                  • alfanikos
                    • Jul 2013
                    • 39
                    • Greece
                    #29
                    @mon2
                    I have checked all the Mosfets and I found here below short circuited
                    Actually I have measured with Ohmmeter the resistance between (scale 200K)
                    1. ----1,2,3 (S) and 5,6,7 (D) 0.00 Ohm
                    2. ----4(G) and 5,6,7,8 (D) 0.00 Ohm
                    3. ----1,2,3 (S) and 4 (G) 0.00 Ohm
                    Furthermore it is a little discolored (overheated)
                    This is a SM3335PSQGC_TRG
                    Attached the Datasheet from Internet
                    Is there any equivalent or I shall to order that from Aliexpress.
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      #30
                      This is a P channel mosfet. You can use AON7403 as replacement.
                      • Julian Bailey
                        HP ProBook 445 G8 Battery not charging
                        by Julian Bailey
                        Hi all
                        We have in a HP ProBook 445 G8 laptop with AMD Ryzen 7 CPU. When power is connected the power LED light blinks 5 times then stops. Normally HP laptops will blink this LED 10 times as it does a self test when the AC adaptor is inserted. So there must be some sort of short somewhere.
                        The battery doesn't charge, and is erratic on the MM voltage. Bench PSU LED pulsates when the battery is connected also. So the fault must be on the charging circuit?
                        I have gone around the board with a MM and cant find anything
                        Windows shows the battery fine,...
                        10-11-2024, 10:34 AM
                      • piernov
                        Laptop battery charging circuit
                        by piernov
                        1. Some theory
                        1.1. Introduction
                        Almost every laptop has a charging circuit of some sort, that does a few things:
                        • Manages switching between AC adapter and battery power
                        • Manages battery charging and generates power rail to charge battery
                        There are 2 different designs to handle switching between AC adapter and battery power and feeding the system:
                        • Hybrid power boost (HPB) and traditional circuits without power boost (see Warning in HPB section)
                        • Narrow VDC (NVDC)
                        Texas instrument has a nice overview of these technologies with some more details at https:...
                        11-15-2020, 01:31 PM
                      • kodox
                        ThinkBook 15 G3 ACL Not Charging Battery - LA-K602P Board
                        by kodox
                        since i couldn't find schematic or boardview for this model (LA-K062P), i use closest board model found here https://www.badcaps.net/forum/troubl...-and-boardview
                        the schematic share same marking for each component, using same PD-Controller, same BQ25710, the only different is the battery cell used. LA-K061P uses 3S battery while LA-K062P use 4S battery per schematic.
                        what i've done:
                        - flashing...
                        12-29-2024, 02:49 AM
                      • Shinju
                        Razor Blade Steath 13" RZ09-01963 plugged in Not Charging (new battery)
                        by Shinju
                        Hey All!
                        Long time forum member here with a problematic laptop issue!
                        I got a RZ09-0196 with a bloated battery (still worked and charged fine) I pulled the old cell pack out and installed a new cell pack in its place.
                        The laptop would not power on with the new battery installed without the power supply being plugged in.
                        When booting into Win10 (all up to date BTW) I saw the battery icon with 49% plugged in not charging.
                        TL;Dr version, old battery worked, charged but was bloated, installed a new non OEM replacement, laptop/windows...
                        10-20-2021, 04:58 PM
                      • Iherduleikgemz
                        Asus FX505DY - Battery not charging - BQ24780S
                        by Iherduleikgemz
                        Hello everyone
                        I have been working on this laptop mentioned in the title, it initially had a shorted capacitor. After I replaced it, the thing started working again, but there is still another problem. The laptop was running off a charger, the battery was reporting 96% charge... but when I unplugged the charger, the laptop died. I've measured the battery voltage - 0V. I think it is locked. (Screenshot from batterymon, below).
                        I've ordered a new 3rd-party battery, but I think there's something wrong with it too - the laptop boots, but the battery isn't charging. Also,...
                        01-13-2025, 03:54 PM
