MacBook Air A1466 2017 Operating Very Slow
  • dellxps15
    • Feb 2014
    • 1596
    • italy
    Re: MacBook Air A1466 2017 Operating Very Slow
    cpu power ic looks perfectly clean ?
    i mean the 2 white thing near cpu coils.
    voltage on cpu coils ?
    • ACS-Repair
      • Feb 2021
      • 204
      Oh those, yes. I thought there was something else.
      Voltage is 1.80v measured on the coils and both sides of the resistors.
      • piernov
        • Jan 2016
        • 4437
        • France
        • ACS-Repair
          • Feb 2021
          • 204
          Voltage on U5540 pin 4 hoovers around 0v with the board removed from the computer. this compares to a 2015 that i have under the same conditions. Measurements compare between the two boards. The voltage does jump to about .2v when the board is powered, then drops back probably due to the missing trackpad. Again, both boards exhibit the same levels.
          I did some diode checking on the SMBuss and compared the two boards. They have very similar values so probably not an issue.
          SMBUS_SMC_1_S0_SCL .553
          SMBUS_SMC_1_S0_SDA .553
          CPUVR_ISNS1_P_R .537
          CPUVR_ISNS1_P_R .630 (both boards have this value difference)
          SMBUS_SMC_5_G3_SCL .526
          SMBUS_SMC_5_G3_SCL .529
          I thought I may have an SMC issue but it's hard to say now. My solder paste dried up so I am several weeks away before trying to replace the SMC, if I choose to.
          • Sergio Kub
            MAcbook Air A1466 EMC 3178 - 2017 Boot
            by Sergio Kub
            Could someone help me?
            I have a Macbook Air A1466 EMC 3178 - 2017, board 820-00165 and sometimes the boot interrupts with an image of a folder and a question mark.
            Could it be the BIOS?
            07-08-2025, 04:41 PM
          • Sergio Kub
            Macbook Air A1466 EMC 3178 - 2017 Boot
            by Sergio Kub
            07-08-2025, 04:12 PM
          • joeoffice12
            MacBook Air (2017, A1466, No power/orange-green light on)
            by joeoffice12
            I have a 13 inch MacBook Air 2017 that does not show any life, however, there is activity from the MagSafe light going from green to orange and staying. Normally, this battery works perfectly fine and it can actually charge the battery as if I were to leave it alone it would change to just green, however, this thing does not boot up at all, I was told the computer was at 30% and then it randomly shut off.
            Some voltages:
            PPBUS_G3H - 8.5V
            SMC_PM_G2_EN - 3.42V
            PP3V3_S5 - 3.32V
            PP3V42_G3H - 3.42V
            PPDCIN_G3H - 15.18V
            PP5V_S5 - 5.04V
            PP3V3_S5_REG_R...
            12-15-2023, 04:00 PM
          • sofles
            Macbook a1707 2017 model 820-00928 GPU issue
            by sofles
            Hello there
            I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
            I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
            11-21-2024, 05:25 AM
          • Stephen
            A1466 MacBook Air 13" 2017 Backlight issue works but then turns off
            by Stephen
            Hello, got a weird MacBook Air here
            board looks fresh and no water damage, backlight works and turns on and stays on when installing OS etc. However, when the os is installed and when the system files are loaded before the login page the backlight goes out. I have wiped it, NVRAM reset, etc and even took some other instances and this blows my mind, never seen this before. Backlight just turns off once the OS is loaded. Anyone come across this and if so what would be the cause? I am certain its a board issue since I tested the LCD on another board and it stays on. Again the backlight works...
            08-23-2023, 09:12 AM
