MacBook A1707 favor needed.
  • Robin21
    • Feb 2021
    • 46
    • the Netherlands
    I'm replacing NAND (Upgrade 256GB to 1TB) and need a favor from someone who have this motherboard – 820-00928. I haven't checked resistant to the ground before replacing chips and after I've placed new chips I've notice low resistance on L9370 (number 1 on my attached picture) next to the U9310 (S2FPS04X01). 0,3 - 0,2 Ohm.
    If someone will be so kind and could check this resistance I'll be pleased.
    Thank you in advance!
    Last edited by Robin21; 08-13-2023, 05:03 PM. Reason: I forget to add attachments.
  • Robin21
    • Feb 2021
    • 46
    • the Netherlands
    Re: MacBook A1707 favor needed.
    It was shorted SDD controller. I haven't touched it during replacing SSD chips around and glue was still there. It seems glue is changing its capacity during heating. When I've removed it there was a mess under it. Now I have high resistance on that coil, and I've measured 1,2V. But replacing SSD's wasn't success. M/B works, but there is no disk..
    • piernov
      • Jan 2016
      • 4437
      • France
      There are strapping resistors and the SSD controller for 1TB/2TB configurations has more RAM.
      • Robin21
        • Feb 2021
        • 46
        • the Netherlands
        Thank you Piernov. I'll try that. Still have SSD Controller.
        • leonemax81
          Macbook a1707 820-00281 Battery no Power
          by leonemax81
          Hi guys I have a Macbook a1707 with motherboard 820-00281, without liquid damage that behaves strangely, with the battery connected the Macbook does not turn on and the USBC meter stops at 5v in loop, when I disconnect the battery the Macbook turns on and works fine, I have already tried to replace the battery twice without success, as soon as I connect the black cable of the battery the Macbook does not turn on, it stops at 5v and in loop.
          08-23-2024, 09:24 AM
        • sofles
          Macbook a1707 2017 model 820-00928 GPU issue
          by sofles
          Hello there
          I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
          I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
          11-21-2024, 05:25 AM
        • jesi
          MacBook Pro 820-00281-A A1707 macbook
          by jesi
          hi all techs
          require some help on this 820-00281-A macbook motherboard came in dead and the pch bga U1100 (SR2NH), u5000 , Q7056 , U7000 and bios U6100 ,looks like these have been tampered with ..also the battery is swollen..
          adapter usb c 20.5v 4.7a 96w , i persume it should power on mb without battery..
          update:
          when adapter plugged in , power switch which 3.3v on it , when power button pressed both fans come on after 6 secs for about 20secs approx then goes off , nothing on the display stays as blank.. the voltage at the usbc out start from...
          08-23-2025, 02:35 PM
        • tommy97
          Apple MacBook A1707 No Audio/Sound
          by tommy97
          I'm having an issue with an A1707 MacBook Pro—there's no audio output. Initially, the MacBook came in with a no-power problem, and I found a faulty U6400, which I've now replaced. The laptop now powers on, but there's still no sound.
          I've also replaced U6300, but the problem persists.
          Here are the current voltage readings:
          • PPV18_S0: 1.8V
          • R6402: 1V
          • R6405: 1V
          • R6403: 1V
          • AUD_SPKRAMP_RESET_L: 1.3V
          • PPBUS: 12.6V
          03-10-2025, 11:22 AM
        • Cemal Odabasioglu
          MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
          by Cemal Odabasioglu
          I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
          Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
          Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
          Observations...
          01-14-2025, 03:54 PM
