A1990 MacBook Pro Burned via repair
  • jma46
    • May 2020
    • 24
    Hi I have been replacing a Touch Bar connector as the laptop had suffered liquid damage and some on the contacts have burned (A1990 MacBook Pro). Some on the connection points have disappeared (burned away) all that is left is a tiny dot to solder too. Also have another similar damaged via on the PP5V_3GS rail which is linked to a lot of rails on this board. Again there is a tiny dot which I think is the via to attach too, can these be repaired and built back up to a pad? Is it wise to dig down carefully in the layers to get a good solder connection and build back up with solder paste? just wondering if anyone has any advice or experience of doing this, thanks
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Burned via repair
    I've used a trace repair kit like this https://www.aliexpress.com/item/1005004910688781.html and soldered a pad on top of whatever is left.
    • jma46
      • May 2020
      • 24
      Yes I have a set of those but the problem is the remains of the via are below the level of the board, kind of in a hole, not sure by scraping around the edges I will damage other traces and layers. It seems almost impossible to get a solder blob to connect! Ive just ordered a t30 tip for my Hakko which I am hoping will work
      • diif
        • Feb 2014
        • 6978
        • England
        Re: A1990 MacBook Pro Burned via repair
        Yes, it will be below the surface, the tip pad has gone.
        I didn't scrape, I just tinned what was left and stuck the pad on top.
        I do have a stereo microscope so stuff like this is fairly easy.
        • jma46
          • May 2020
          • 24
          Ok thanks for your advice I will try again when new tip arrives
          • reformatt
            • Feb 2020
            • 1499
            If you still have the via, you solder jumper wire to it (like 0.02mm) then apply a dab of UV mask on the join. Then spiral the jumper on top and tin it to form a pad of sorts. You could apply UV mask on the spiral and scrape the top of it then tin it if you aren't confident.
            • jma46
              • May 2020
              • 24
              Thanks for the advice I will try the wire spiral method with solder mask. Any recommendations for decent solder mask? the stuff I have does harden but needs a good 5 minutes with the uv light even with a thin coating.
              • alfredodinolfo
                MacBook Pro 2019 (A1990)
                by alfredodinolfo
                mb code:820-01827-A;
                sn:C02Z349ALVDR;
                i9 32GB Ram 1TB
                Hi, I found short on one of 6 black nand (total 1TB).
                i removed all 6 nand ( voltages all ok) and now i want to program with JC P15 but for A1990 2019 there is only 512GB configuration.
                I try A2141 1TB configurazion with TSB4228 but the position on pcb is different ( U9300 and U9400 is no stuff on A1990 but present on A2141 and U8800 and U8900 is no stuff on A2141 but present on A1990 )
                macbook with A2141 configuration run on recovery but don't complete it.​
                anyone can help me?
                05-26-2025, 09:27 AM
              • DATATECH85
                Macbook Pro A1990 - 820-01041 Stuck at 5V / 0.02A
                by DATATECH85
                I am currently working on a Macbook Pro A1990 (motherboard 820-01041) which is not charging.
                The Macbook consumes 5V and 0.019A at USB-C. There seems to be a partial short-circuit on the PPBUS_G3H rail as I have 0V on this rail.
                I've physically separated (by removing F7000 and F7001) PPBUS_G3H and the ISL9240 charging chip to see which side the short is coming from. Removing these fuses gives me 12.6V at the output of the ISL chip (PPVBAT_G3H_CHGR_REG).
                However, I can't work out exactly why I don't have the PPBUS_G3H rail.
                Here are the values...
                07-24-2024, 06:34 AM
              • falcontech
                Macbook Pro a1990 activation locked
                by falcontech
                I received a 2018 MacBook Pro A1990 for repair, and the motherboard was replaced, presumably purchased on AliExpress. The motherboard's activation is blocked because the previous owner didn't delete it. Does anyone have a solution to this problem? I called Apple, and as expected, they asked me to activate the process with proof of purchase for the original computer, which I find very difficult, so the proof of purchase from AliExpress will be of little use. Any suggestions? Thanks.
                09-29-2025, 06:57 AM
              • Cameron Kajohn
                A1990 MacBook no power help
                by Cameron Kajohn
                I have a a1990 2018 15 inch MacBook Pro that will not power on.
                I have replaced the pch bga chip because it was heating up under my thermal camera.
                I have replaced the battery, and replaced the small ic between the gpu and cpu as it had a direct short to ground.
                the MacBook now pulls 20v 2.4amps the trackpad clicks but it does not ever attempt to power on not even fan spin. After PCH replacement I was able to get it in dfu mode 1 time and restore bridge OS, but now the MacBook will no longer go into DFU mode.
                I have also noticed L7030 gets extremely hot yet...
                01-24-2024, 12:00 AM
              • defdjamel
                Solder won’t melt on MacBook 2021 logic board – need advice
                by defdjamel
                I’m trying to remove a component from a 2021 MacBook logic board, but I’m having trouble.
                https://www.electronicsdatasheets.co...s/tlv70733pdqn
                I’m using hot air at 480 °C with full airflow and good flux, but the solder paste is not melting.
                I know there’s a lot of thermal dissipation from the board, and I suspect the copper planes are absorbing most of the heat.
                Do you have any tips for this kind of board? Would a preheater help?
                Thanks in advance!
                09-05-2025, 08:56 PM
