ACER PREDATOR G9-792 - P5NCN/P7NCN REV:2.0 - shuts down under heavy GPU load
  • ghosteb
    • Feb 2023
    • Poland
    Laptop and motherboard as described. When performing a GPU stress test (1080 FHD) or a power test running on battery alone, the laptop shuts down immediately. After about a minute, I can restart the hardware.
    The laptop at the beginning of the repair did not start. I located the burnt capacitor C8050. After replacing the device, it started working. I did some tests and it turned out that during the GPU test on the power supply, the laptop immediately turned off. The power supply was damaged (I replaced it with a new one). Then there was no battery charging: I replaced the BQ24735 chip and the battery (it had 0V). Now there is a problem with the stress test on the GPU when laptop power on battery alone - as I mentioned at the beginning. The laptop works fine on the power adapter. In the meantime, I noticed that after my tests it damaged the C8051 capacitor. I also replaced the mosfets in the charging system: Q8800 (FDS6679AZ), Q8803 and Q8804 (IRF8707PBF).
    I am worried about these damaged capacitors in the +AC_BAT_SYS line. Before the repair, it was obvious that someone had already replaced them (C8051, C8052). Looks like a problem with the power supply.
  • swammyw
    predator helios 300 shuts down under heavy 3d load, temps are fine
    by swammyw
    Hi i need help troubleshooting predator helios 300 mboard: LA-F991P
    gtx1060 6gb
    laptop shuts down when benchmarking UNIGINE 3d after 2 minutes
    and temps are normal when monitoring while running, when laptop shuts down it makes bios reset process when turned back on (i have to take battery out otherwise it wont start) otherwise it seems to work fine, rtc battery shows 2.8v
    i updated bios ,tried whitout battery ,whitout rtc battery, with another charger but it did not help with problem, anyone had similiar problem? thanks
    12-08-2022, 06:46 PM
  • huzo
    HP Omen shuts down when loading OS
    by huzo
    The model is 15ec-1061nm
    Board number is DAG3EDMB8D0​
    SO i turn the laptop on , and as soon as it starts booting from disk, from usb, windows,linux,HBCD,anything i boot it just turns off....while in bios menu or in linux boot menu it stays on normally...It's like when it starts to use graphics it shuts down...But i measured 0.72V while working on the GPU power line,no excess heat is comming from GPU or CPU, i even removed the heatsink and turned the laptop on and everything worked fine, got a bit hot, fan span to full speed, but it worked like that for few minutes in bios...
    10-29-2024, 12:05 AM
  • brav1ez
    ASUS FX505GD shuts off after POST — no BIOS, power button unresponsive
    by brav1ez
    I have an ASUS TUF Gaming FX505GD that's powering on, showing the ASUS logo for about 2 seconds with keyboard backlight, then immediately shuts off. After it shuts down, the power button does nothing until I unplug the laptop completely. No fans spin afterward either.
    I’ve tried:
    - CMOS reset
    - Removing the SSD/HDD
    - Reseating RAM (removing each stick individually stops boot completely)
    - Cleaning up recently applied thermal paste around CPU/GPU and nearby VRM components (issue persists)
    With...
    09-07-2025, 10:47 AM
  • chaos-theory
    Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
    by chaos-theory
    I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
    Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
    03-14-2025, 05:37 PM
  • baglaivlad
    A1706 820-00239 - Works, but sometimes shuts off when the charger is disconnected
    by baglaivlad
    Hello everybody!
    Have in work A1706 820-00239 model. Originally no power, shorted PPBUS_G3H because of corroded C6403, C6404. Some water damage around this components, but nothing major.
    After replacing this capacitors the laptop came back to work, I reinstalled MacOS and had no issues until I started to test Type-C ports. Sometimes the laptop shuts off immediately when some action with Type-C ports performed (charger disconnected or USB device inserted/disconnected). I checked Type-C port flexes, they are okay, but I cleaned them anyway. I can't see any signs of liquid...
    11-20-2024, 08:14 AM
