P3V3A has low resistance
    Re: P3V3A has low resistance
    Originally posted by kalilinux25 View Post
    update 3V AND 5V ic is a liitle bit warm
    U6100 -BQ24728
    You didnt answer completely. I asked you about the ACOK resistor R6024 voltage on pin1. You ignored that. I suggested you its very likely related to EC firmware or its connectivity to various resistors. Once again you didnt answered.
    I cant help if you dont answer completely or answer them in parts.
      U6100 -BQ24728
      1 - 0V = TRIP1
      2 - 0V = VFB1
      3.- 0V = VREF
      4.- 1.9 = TONSEL
      5. 0V = VFB2
      6. 0v = TRIP2
      7 - 0v= VO2
      8- 3.3v = VREG3
      9- 4.5v = VBST2
      10- 0v =DRVH2
      11- 0v = LL2
      12- 0v = DRVL2
      13- 4.1 = EN0
      14 - 0v = SKIPSEL
      15 - 0v = GND
      16- 18v = VIN
      17- 4.9v =VREG5
      22- 4.5v =VBST1
      23- 0v = PGOOD
      24- 0v = VO1
        Im so sorry i forgot, PIN1 has 3.3v stable
        Flash the ec bin only with clean me verion no light also
        note: im still using its original charger and PAD6100 is dissbaled i cut its connection
          Jumper back PAD6100.
          boardview is posted on this forum . Check connectivity of each and evry pin of U511 to its resistors/capacitors nearby specially pin5 of U511. Check resistors for value also.
            thanks ill update you
              u6100 reading
              PIN 10 - DRVH2 = VRP3V3A_HG - 100ohms
              PIN7 - VO2 = 100OHMS
              PIN11 - LL2 = VRP3V3A_PH = 100ohms
              u511 connection tested fron bios to the direction to the resistor or caps is ok
              R415= 100HMS
              R416 =100OHMS
              R777 = 103K
              R773= 99k
              R540 = 0hms
              done connecting the PAD
                Re check connection of U511,pin5 to R415 in diode mode-The meter buzzes?
                  yes correct they are conencted to each other
                    Can you post charging IC measurements?
                      U600 READING
                      TI_BQ24728_QFN_20P
                      1. ACN= 19.5
                      2. ACP= 19.5
                      3. CMSRC = 19.5
                      4. ACDRV = 25.31
                      5. ACPRES = 2.9V
                      6. ACDET = 2.6
                      7. IOUT = 0V
                      8. SDA = 3.3V
                      9. SCL = 3.3V
                      10. ILIM = 0V
                      11. BATDRV = 2.5V
                      12. SRN = 2.3V
                      13. SRP = 2.6V
                      14. GND = 0V
                      15. LODRV = 0V
                      16. REGN = 6.0v
                      17. BTST = 5.9v
                      18. HIDRV = 2.5v
                      19. PHASE = 2.5v
                      20. VCC = 18.8v
                      without CPU RAM AND CMOS BATTERY
                        R6024 is 10K? Can you lift pin35 of SIO? That requires skill and if you are not confident you may even damage the sio pin. So proceed with caution. Else remove the SIO and check ACPRES again on charging ic. You can also try removing R966 to rule out PCH issue.
                          R6024 - is 10k ok
                          R966- REMOVE
                          should I procedd with removing the SIO?
                            After removing R966, is acpres still 2.9V? If yes, then remove SIO.
                              yes its 2.9v
                              remove done
                              test
                              its now 3.3v
                                Replace SIO and test again.
                                  I will order it cant find any in my boards
