Lenovo BYG40 NM A411 No power
  • psdavid65
    • Dec 2021
    • 24
    • Ghana
    Quick question please.
    Does anyone have an idea what voltage is supposed to be on VUSB, and PD7, VUSB_OPEN and drain of PQ12.
    The schematic for the motherboard is BYG40 NM A411
  • mon2
    • 14664
    Re: Lenovo BYG40 NM A411 No power
    Vusb is based on the USB specification and should be about +5 volts. Often this power rail is enabled by a USB load switch which defines the max current draw of the mating downstream USB device. If the current draw is exceeded, the switch is expected to turn off and report this fault to the upstream USB host controller. This event then raises a pop up balloon flag in the windows task bar.
    If you are missing this vusb rail, look for a damaged USB load switch nearby.
    • psdavid65
      • Dec 2021
      • 24
      • Ghana
      Thank you for the speedy reply. I'm grateful.
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • PantherDave
        by PantherDave
        Hi all!
        05-29-2024, 02:01 PM
      • GLISIT
        by GLISIT
        01-16-2025, 02:29 PM
      • Mita99
        Lenovo Thinkpad P72 EP720 NM-B723 MB - Power disabled within 2 seconds after plugging the charger
        by Mita99
        Try to repair a Thinkpad P72 EP720 NM-B723 MB with I7-8850H processor and N18E-Q1-KB-A1 (P3200) GPU with 6GB memory. Unfortunately there is noinfo what happened to the laptop. I got it disassembled with parts missing, like keyboard, battery.
        Unfortunately I have no schematic available for me (requested in the sub porum) but got the boardview file.
        Symptom: after connecting to the charger the power led light up for one-two second and switch off. After a couple secons the power led light up for half a second and switch off. No battery, no IO board, no...
        04-27-2025, 07:20 PM
      • Dr.d
        Help please..Lenovo ideapad 5 14itl05 power and charging problem
        by Dr.d
        I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
        Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
        04-05-2024, 11:48 AM
