identifying a mosfet for asus laptop
  • madjid911
    • Dec 2016
    • 412
    • France
    HI, I discovered a mosfet in continuity, and grounded the motherboard. I would like to replace it to be able to repair the motherboard of my asus pc. I am not a big expert, can you tell me what is this mosfet?I can't find it on the internet.
    Can you help me find the datasheet and maybe tell me which mosfet I can replace? I have macbook a1466 1708 1278 donor motherboards.
    THANKS
  • kew1701
    • Nov 2013
    • 40
    • Poland
    Re: identifying a mosfet for asus laptop
    It is a PEA16BA mosfet...
      • 22182
      PE616BA .https://cdn.badcaps-static.com/pdfs/...2c64e89db5.pdf
      • madjid911
        • Dec 2016
        • 412
        • France
        Thank you so much
        • madjid911
          • Dec 2016
          • 412
          • France
          I changed it with this one, taken from the macbook a1466, the mosfets heat up enormously and the pc does not start
          https://cdn.badcaps-static.com/pdfs/...c1196d720b.pdf
          • Sephir0th
            • Oct 2020
            • 1289
            We should start with the location of the Mosfet and the circuit to which it is related to and clarify later why it possibly isn't a suitable replacement.
            FairRepair on YouTube
            • kingis85
              Asus rog flow gz301v mosfet ic identifying
              by kingis85
              Here i have asus rog flow, super powerfull and expensive tablet. The problem is that it only works with a battery. The owner had it plugged on and his dog wanted to put his teeth on the usb-c plug and well.....
              So after that it is not charging with a new asus official charger. I opened and tried to find something burned with microscope but everything looks good. I did not found any short. I did see that it does not try to take any power with usb meter, so the 5v line must be open somewhere. This board is really hard to make any sense because i can not find any kind of data sheet or info....
              11-20-2023, 05:50 AM
            • Rickkap
              Help in identifying a MOSFET - ASUS ROG GU603Z
              by Rickkap
              I have a ROG here which isn't charging and found 2 MOSFETS to be faulty with no schematics available only board view. I need help in finding a replacement (equivalent)
              The markings are G4 GUB and under this it says 2Y2701. I've tried googling this but no joy.
              Can anybody shed some light on where to get them from or an equivalent.
              04-08-2025, 02:57 AM
            • AppleLover123
              Asus X712EA 3 volts after the first mosfet
              by AppleLover123
              Hey guys,
              i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
              I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
              Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
              I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
              Now i thought something...
              12-15-2024, 07:49 AM
            • redbaron1007
              Help identifying mosfet on Razer Blade RZ09 (CH570_MB_NT)
              by redbaron1007
              I have a Razer laptop (RZ09 MB# CH570_MB_NT) that has a shorted mosfet marked BND M03 E067 that I'm unable to find anywhere online. Does anyone either know what the part number is for this mosfet or have a schematic I can find it in?
              Backstory on the whole thing the laptop was plugged into a lamp at a hotel. The lamp got unplugged while it was charging and now the system won't power on anymore. I found the caps around this mosfet shorted and when I injected voltage into the caps the mosfet got hot and my bench psu was pulling 5A. Pretty sure this is all that's wrong with the laptop...
              09-09-2025, 11:10 AM
            • Scotchmist
              Asus GA502D keeps blowing mosfet
              by Scotchmist
              I have an Asus GA502D, it had a blown mosfet which I replaced and the laptop booted into windows, a few mins later it shut off, the same mosfet was blown. I thought maybe just a bad mosfet but same thing happened again, a few mins in windows and shuts off.
              I have removed the mosfet and can run the laptop no problem
              The MOSFET is FDPC5018SG
              Can anyone point me in the direction of what could be the cause of this, could it be the controller rt3663bc?
              08-24-2024, 02:23 PM
