DELL Inspiron 15 3567 not powering with battery
  • mohamed mm
    • Nov 2022
    • 37
    • India
    Hello Everyone, I hope you are all doing well,
    I have a Dell laptop, Inspiron 15 3567, it's only powring up with the adapter not with the battery, but after it's on I can remove the adapter It works fine with the battery, so only the problem is it does not start with the battery even if its attache with the laptop.
    battery condition is excellent and the adapter is original, both are detected in the bios. ( sometimes a laptop doesn't start until I disconnect the battery and reconnect it again), I have updated the bios but nothing has changed.
    Here's my reading with pictures:
    Code:
    PQ 4416 with battery:
    1 pin: 15.9v
    2pin: 15.9v
    3pin: 0v
    PQ 4416 with adapter:
    1pin: 0
    2pin:0
    3pin: 0.4v
    PQ 4416 with adapter and battery connected:
    1pin: 16.8v
    2pin: 16.8v
    3pin: 2 v
    PQ 4415 with battery:
    1pin E: GND
    2pin B: 0v
    3pin C: 15v
    PQ4415 with adapter:
    1pin E: GND
    2pin B: 3.3v
    3pin C: 0
    PQ4415 with adapter and battery:
    1pin E: GND
    2pin B: 0V
    3pin C: 16.8v
    PD with battery:
    1pin: 0
    2pin: 0
    3pin: 0
    PD 4410 with adapter:
    1pin: 19v
    2pin: 0
    3pin: 19v
    PD with adapter and battery:
    1pin: 19v
    2pin: 2
    3pin: 19v.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: DELL Inspiron 15 3567 not powering with battery
    PQ4410 Gate voltage?
    PL4401 Voltage with only adapter connected.
    • mon2
      • Dec 2019
      • 14182
      What is the logic board number? It should be silk screened on the board somewhere.
      Check the condition of the battery mosfet that may be leaky. Also check the 2nd DCin mosfet for the same.
      Dell will usually use the BQ series battery charger IC to drive the 2*DCin mosfets. Locate it and post the topside markings.
      • mohamed mm
        • Nov 2022
        • 37
        • India
        Thank you for replaying I appreciate it,
        With adapter:
        PL 4401= 0
        PQ4410 gate: 1.7v.
        board number: vegas turis skl/kbl, 15341-1 / 91N85
        both MOSFETs are good and reading on the AD side: DRAIN= 19V. SOURCE = 19V.
        Battery side without battery: drain= 19v and source= 0.2v
        I am sorry if I missed something but there is no ic with BQ, but I took the photo for power Ic
        (I 739 HRZ W711NH)
        • mon2
          • Dec 2019
          • 14182
          Well noted. You are correct on the charger IC you have posted and the area of focus is proper for the battery / adapter select circuit.
          1) PQ4416 (PNP) may be defective. When PQ4416, pin #1 = BASE pin is 0 volts, a voltage divider is enabled to create a LOWER voltage than the emitter (pin #2) = battery input. By having a LOWER voltage @ base pin of the internal transistor in PQ4416 (PNP), the transistor should enable to pass the battery voltage onto the collector pin #3. Do not see this transistor @ PQ4416 being enabled with the measurements you have posted.
          2) See attached. Attempt this bypass method to see if this works for you.
          • mohamed mm
            • Nov 2022
            • 37
            • India
            I have checked the trace between C of PQ 4415 and B of PQ4416 and it's good and not cut.
            and I have made a bypass as you mentioned now the 16.8v passing to PD4410, but still the laptop not powering on. no 3.3v or 5v.
            Is it possible that the power ic is partially broken? Or is there another component associated with the circuit?
            Thank you.
            • mon2
              • Dec 2019
              • 14182
              Remove the power adapter. Connect the battery. Measure the voltage to ground of each pin on pd4410. Post each measurement. This dual diode must pass the battery voltage onto pin #3 to power the charger IC.
              • mohamed mm
                • Nov 2022
                • 37
                • India
                PD 4410
                pin 1= 15.8v
                pin2= 16v
                pin3=0
                • mon2
                  • Dec 2019
                  • 14182
                  Can you confirm the adapter is removed?
                  Pin #3 must output the battery voltage, if not, this diode is defective and should be replaced. Then pin #3 will power the charger IC if powered by the battery only.
                  • mohamed mm
                    • Nov 2022
                    • 37
                    • India
                    The adapter wasn't connected but I make a mistake in the order of the pins Im sorry
                    Pin 1= 0
                    pin2= 16v
                    pin3= 15.8v
                    • mon2
                      • Dec 2019
                      • 14182
                      Carefully measure the voltage to ground of the following pins on the charger IC:
                      Pin #5 - bgate that is used to enable the battery mosfet. Also confirm the voltage on each pin of the battery mosfet (source / gate / drain). When using only the battery, the battery mosfet must be enabled.
                      Pin #1
                      Pin #2
                      Pin #3
                      Pin #4
                      • mohamed mm
                        • Nov 2022
                        • 37
                        • India
                        PQ 4412
                        D= 16V
                        S=0
                        G=0
                        PQ4411:
                        D= 16V
                        S= 16V
                        G= 15.8V
                        PQ4401:
                        D=16V
                        S=16V
                        G= 0
                        IC PINS:
                        PIN 18= 15.8V
                        PIN 21= 0
                        PIN 22= 16V
                        PIN 23= 15V
                        PIN 24= 15.8V BOOT
                        PIN 25= 13.9V BGATE
                        I'm sorry if I missed something, those reading only with battery no adapter.
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          PL4401 should have voltage when only charger is connected. What is the resistance to GND on PL4401? You have not shared charging ic pins voltage specially pin1-2-3-4-14-15-19-20-29-31-32(with adapter only).
                          • mohamed mm
                            • Nov 2022
                            • 37
                            • India
                            Thank you I appreciate it,
                            PL 4401= 9.8K
                            IC PINS with adapter no battery :
                            1= 2.1V
                            2= 3.3V
                            3= 3.3V
                            4= 3.3V
                            14= 0
                            15= 0
                            19= 0
                            20= 5V
                            29= 19V
                            31= 19V
                            32= 19V
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              Pin2 should be 3.9V as per voltage divider.
                              Pin19 should be 5V as well.
                              Check continuity between pin14 & 15 to PR4443.Also check resistance value for PR4456/57.
                              Pin19-resistance to GND?
                              • mohamed mm
                                • Nov 2022
                                • 37
                                • India
                                There is continuity between pin14 & 15 to PR4443.
                                the resistance value of PR4456: 1.8M ohm
                                the resistance value of PR4457: 0
                                the resistance value of pin 19 to GND: 0.27M ohm
                                I did measurements without the battery and adapter.
                                • mcplslg123
                                  • Jun 2015
                                  • 7262
                                  • india
                                  I doubt your measurements. If PR4456 is 1.8M Ohms, then there cannot be continuity between pin15 of charging IC to PR4443,pin1. So what you write here is quite contradictory.
                                  Suggest to recheck my suggestions at post#15.
                                  • mohamed mm
                                    • Nov 2022
                                    • 37
                                    • India
                                    Im sorry I have made a mistake, There is continuity between pin14 & 15 to PR4443.
                                    the resistance value of PR4456: 10ohm.
                                    after a long search, I have found there is a capacitor missing (as shown in the picture) PC4433. so I place it from another motherboard with the same module, and I turn the laptop on it worked fine with the adapter, so I disconnect the adapter and try it with the battery alone but it didn't work (the same issue not powering with the battery). so I connect the battery and adapter together and here another problem came up, the MOSFET (PU4412) shorted, so I replace it with the same module, then the IC shorted, and again I replaced it with the same module, and I removed capacitor PC 4433.
                                    but now the laptop not powering with the adapter, there is no short at the AD side or BATTERY side, and the adapter feeds IC power & 5, 3 v IC but no output.
                                    • Bowline
                                      by Bowline
                                      06-11-2025, 10:13 AM
                                    • mkdj
                                      ASUS X571 no power : battery issue?
                                      by mkdj
                                      Mark and model: ASUS X571
                                      Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                                      Tests already made:
                                      - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                                      - I have removed...
                                      07-14-2025, 09:16 AM
                                    • techfreak9356
                                      Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                                      by techfreak9356
                                      I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                                      09-14-2023, 11:10 PM
                                      NVDC charger configuration...
                                      11-05-2024, 03:28 PM
                                    • ferah831208
                                      Strange battery present behaviour in Lenovo Legion 5-15ARH05 mb model nm-d041
                                      by ferah831208
                                      Hello guys, i need help with this problem, I have a NM-D041 mobo, it came with low impedance in 3v linear regulator rail, the cause was a damaged EC controller ITE8227e-192. I ordered a new one and replaced it. This laptop have a different chip for keyboard management and it8227e pins for programming ITE chips are not accesible through keyboard interface, I flashed it using i2c interface pins with vertyanov programmer because laptop was dead and SPI flash didn't have power (only 3v EC) so it couldn't access firmware stored in SPI memory. I read SPI and extracted it8227 firmware from original BIOS...
                                      03-18-2025, 01:18 AM
