iPhone X earpiece compatible with XS screen?
  • AJ847.63e
    • Aug 2020
    • 171
    • Africa
    Hi All,
    Has anyone tried to use a XS screen on a iphone X before? I've got a old dead iPhone XS which I was hoping to use the screen on my iphone X as the glass on it has cracked. According to google the connectors are the same but some screw holes don't line up, but I'm assuming that doesn't matter as I can use some double-sided adhesive instead. Better than spending 280 bucks on a new screen when I already have a perfectly good OEM XS one.
  • smic717394
    by smic717394
    07-25-2024, 10:16 AM
  • Ryan.man
    by Ryan.man
    02-04-2025, 12:23 PM
  • reformatt
    by reformatt
    07-31-2025, 08:37 PM
  • Chrissygizmo
    by Chrissygizmo
    02-10-2025, 12:33 AM
  • spice_disc
    Vizio TV M50-C1 reboot cycle and static on screen
    by spice_disc
    I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
    The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
    09-08-2024, 02:37 PM
