Yoga 6-13ALC6 with a broken power button
  • OrioSlinger
    • Oct 2022
    • 6
    Hello everyone! I am currently working on a Lenovo Yoga 6-13ALC6, the customer dropped the device and broke the power button, ripping one of the pads.
    Issue we run into is the button doesn't seem to be provided anywhere, tried to look for it through mouser but got nowhere in the search. Does anyone know if there is a specific part number that could be found on the part or if there's any good locations for a scrap board to salvage from?
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Yoga 6-13ALC6 with a broken power button
    Click Go Advanced below, then the paperclip, then select a photo of the switch.
    Aliexpress or ebay for the switch.
      • 21841
      Is the motherboard part number LA-K211P ,if it is there`s a schematic available with the tactile switch part number on page 27 https://www.badcaps.net/forum/showthread.php?t=118064 .Part number TCHC2QR .
      • chikineider
        • Jun 2016
        • 11
        • Uruguay
        Hi, here you have : https://www.mouser.com/ProductDetail...252By01w%3D%3D
        • themosttogain
          HP Envy 13-BA1565na with intermittent power button
          by themosttogain
          Hope someone can give me some suggestions on this because i'm at my wits end with it...
          I have an Envy 13-BA1565na here with an Intel Core i7 i7-1165G7 CPU (board is a LA-J475P Rev 1.0) which has an intermittent power button issue. The power button is integrated into the keyboard, and I have ruled out the keyboard, BIOS and battery as being the issue.
          Basically, on mains power, the power button works fairly well. The first time you come to it after leving it sitting (either on charge or not on charge), it might take 2 or 3 presses of the button, but then the laptop boots...
          07-12-2024, 03:03 AM
        • TimeRabbit07
          Asus FX517ZC charges but power button does nothing
          by TimeRabbit07
          Hi all!
          I've got an Asus FX517ZC on the bench at the moment and I just can't figure out what's going on with it.
          Here are its various numbers and identifiers:
          Model short: FX517Z
          Model long: FX517ZC-HN114W
          SN: NANRCX01S57842E
          CN: 3SDB 12M
          MFD: 2022-10
          Motherboard model: DA0NJLMBAE0 REV E
          Symptoms:
          The laptop's charge light comes on, but when the power on button is pressed nothing happens. No fan spin, no caps lock, no screen or keyboard backlight, nothing.
          History so far:
          The...
          09-04-2024, 05:48 PM
        • reessi
          Macbook Air - 2018 - A1932 - 820-01521-02 - Bootlooping if Power Button Connected
          by reessi
          With the power button connected it either boot loops with the apple logo or no display but the charging meter shows it looping on charging every few seconds.
          No corrosion any where!
          Tried a replacement power button off ebay and the same.
          Very occasionally it will work with the power button connected!
          Same results with or without the battery.
          Can it be a fault with the Audio board or the mainboard?
          The touch Id assembly connects through the Audio board first then to the Mainboard.
          Flex...
          06-26-2024, 03:31 PM
        • hoarderteks_kyriakos
          Dell Latitude E5570 - No display, turns off after a minute of pressing the power button.
          by hoarderteks_kyriakos
          Hello.
          Yesterday my mother encountered a problem with her laptop, which led to it not turning on and expressing the behaviour mentioned in the title (you press the power button and then it turns off after a minute)
          Here is what happened:
          At one point i was fixing a setting on the laptop to make the laptop properly recognize the NVMe drive i put in months ago. All worked until all of a sudden the computer blue screened. The screen said it would reboot, but it never did. So she held down the power button, powering it off. Pressing it again, the screen briefly turned...
          10-08-2025, 07:33 AM
