Dell e6500 no ram and system shutdown
  • usyusy
    • Sep 2021
    • 171
    • Pakistan
    Del e6500 power on but after a few second power off, ram voltage and vtt not generating, while 3v/5v, 1.0 Ich, 3v sus, vcore were generating
    Ram ic pin 9, 14, 15, 16 have 5v inputs, s4 enable (DDR_ON) is 2.5v, s3 enable ( 0.9V_DDR_VTT_ON) is 3.3v
    No bios yet flashed, any suggestions
    MOD Edit: Link to Schematic ---> https://www.badcaps.net/forum/showthread.php?t=121606
    Last edited by Vesko356; 07-25-2023, 06:40 PM. Reason: Attached schematic removed and replaced with link.
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Re: Dell e6500 no ram and system shutdown
    Do not attach laptop schematic and/or BV in this section please!
    Schematic Requests ONLY!
    https://www.badcaps.net/forum/forumdisplay.php?f=41
    Reminder: rules and organization of this section
    https://www.badcaps.net/forum/showthread.php?t=117483
    If you request/offer BIOS/schematics/boardviews, please post in the appropriate subsection, and you can link to it in the troubleshooting topic.
    Become a Badcaps supporter
    Thanks to all supporters.​
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Vcore unlikely to rise without ram voltage present. Re check your measurement.
      • usyusy
        • Sep 2021
        • 171
        • Pakistan
        you are right sir, but don't know what happened, DDR_on now 3.3 and ram generated, core, gfx, pltrst is present but before display, board gets-off. also dc to dc voltages are present when powered-on
        • raajkumar
          • Mar 2015
          • 354
          • Srilanka
          Did you check how much ampere is getting switched on time. and you have to observe the amp when its switch on and off.
          • usyusy
            • Sep 2021
            • 171
            • Pakistan
            when power-on, takes about 800 mA, and when off takes about 0.02A
            • Sephir0th
              • Oct 2020
              • 1289
              VCC_GFX present before the P.O.S.T succesful performed is a odd observation. Could be a hint into the direction of dead CPU
              FairRepair on YouTube
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                DRAMRST# status?
                • SuperJames
                  Dell G3 17 3779 Weird power cycling and shutdown/restart issue
                  by SuperJames
                  This one's a weird one, and still unsolved despite it having gone back to Dell once.
                  Specs
                  i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
                  Backstory
                  I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
                  10-23-2023, 04:09 PM
                • shabbir.asas
                  dell precission 7520 fan spin fast after shutdown
                  by shabbir.asas
                  dell 7520 laptop fan spin fast after shutdown ....
                  01-01-2025, 02:27 AM
                  Dell Latitude E6500 LA-4043 Laptop Schematic
                  Dell Latitude E6500 LA-4043 Laptop Schematic...
                  10-04-2024, 12:19 PM
                • Akhlz001
                  by Akhlz001
                  09-20-2025, 07:15 PM
                • master3112
                  by master3112
                  07-29-2025, 01:55 PM
