Macbook A1278 no charge
  • dclass-pro
    • Dec 2022
    • 157
    • Italy
    Hi guys, I have this macbook with 820-2936-b logic board that only turns on on battery.
    I tried changing the charging connector the SMC controller and the cairca ic but it still doesn't work. When I plug in the magsafe I have no light, as soon as I plug it in with no battery the mac won't turn on (usually all turn on).
    I did the various checks and only with the charger connected to the U700 pin I have:
    pin2 - 16V
    pin3 - 3.8V
    pin19- 5V
    pin14 - 3.3v
    PPBUSG3H have 3.4V
    absorption with bench power supply 0.07A
    do you have any idea?
  • Adogabriel100
    knowledge seeke
    • Aug 2021
    • 36
    • peru
    Re: Macbook A1278 no charge
    PP3V42_G3H voltaje?
    voltaje on pin 14 of U7000?
    voltaje of SMC_RESET_L?
    • dclass-pro
      • Dec 2022
      • 157
      • Italy
      PP3V42_G3H voltaje - 3.4V
      voltaje on pin 14 of U7000 sometimes it's 0v and sometimes it's 3.3v
      SMC_RESET_L 3,4V
      How can I check if the DCIN connector is working?
      • Adogabriel100
        knowledge seeke
        • Aug 2021
        • 36
        • peru
        Voltaje of pin 10, 11 and 13? of U7000
        • dclass-pro
          • Dec 2022
          • 157
          • Italy
          all 3.4V
          • mon2
            • Dec 2019
            • 14000
            PPBUSG3H have 3.4V
            This is not correct. Measure again the voltage of PPBUS_G3H to ground @ F7040 (check both sides of this fuse).
            Use only the official netnames (labels) used in the schematics. It will make it easier for others to review to debug your case.
            • dclass-pro
              • Dec 2022
              • 157
              • Italy
              I confirm that on both sides of F7040 I have 12.94V
              • tccyo22
                Macbook Pro A1278 intermittent orange charge light
                by tccyo22
                Hi there, I've got a Macbook Pro A1278 board code 820-2936-B in which I have a very strange charging issue.
                Backstory is when I plugged the charger in, it would give a green light and swap to orange like normal but after a few seconds would go off to no light, laptop still powered on and functioned fine.
                So naturally I replaced the ISL chip first which made no difference so I also removed and reballed the SMC. This seemed to fix the issue for about an hour until I was back to square one again.
                Decided to then take an SMC from another board, reball that...
                04-20-2023, 08:58 AM
              • Adogabriel100
                Macbook A1278 (820-2936) No power. missing SMC_BC_ACOK
                by Adogabriel100
                Hey! This is a A1278 macbook 2011.
                Problem: Not turning on / No green light
                Im using by3200s charger.
                Voltajes:
                PPBUS_G3H = 12.26v
                SMC_RESET_L = 3.3v
                PP3V42_G3H = 3.42v
                U7000 =
                Pin 1 CHGR_AGATE = 0v
                Pin 2 CHRG_DCIN = 19v
                Pin 3 CHRG_ACIN = 4.6v
                Pin 10 SMBUS_SMC_BSA_SDA = 3.3V
                Pin 11 SMBUS_SMC_BSA_SCL = 3.3V
                Pin 12 PP3V42_G3H = 3.42v
                Pin 13 CHRG_RST_L = 3.3V
                Pin 14 SMC_BC_ACOK = 0.8V
                Pin 19 PP5V1_CHRG_VDD = 5.05V
                Pin 20 PP5V1_CHRG_VDDP = 5.03V...
                04-01-2024, 01:02 PM
              • Rezendes
                Looking for 13" Macbook Pro A1278 mid 2012 820-2565-A Schematics and Board View
                by Rezendes
                Hello, I am looking for any and all files related to the mainboard for 820-2565-A (13" Macbook Pro A1278 mid 2012) schematics/board view.
                I looked through forum search results and google and was unable to find a board view file, I found a pdf of all the schematics but I don't know where the parts physically are on the board as this is my first macbook board level repair attempt.
                The macbook charger has a green light, the battery has been replaced and OS reports Normal status but Not charging. After cleaning a corroded capacitor it crumbled off the board. There...
                05-10-2024, 02:18 PM
              • pcbmaniac
                MacBook A1278 (3115) No PPBUS_G3H Issue
                by pcbmaniac
                Subject: Help Needed: MacBook A1278 (3115) No PPBUS_G3H Issue
                I'm working on a MacBook A1278 with the 3115 logic board and facing an issue with no PPBUS_G3H voltage. Here's what I've checked so far:
                1. U7000 Measurements:
                  • Pin 3 has 0V, even though R7012 shows 16.5V from PPDCIN_S5_CHGR.
                2. Resistors:
                  • I measured R7010 and R7011 with one leg disconnected, and both tested OK.
                Based on these findings, I believe U7000 needs to be replaced. However, I have a related question:
                • If I also decide to replace the SMC, do I need to order it pre-programmed,
                12-02-2024, 04:12 PM
              • reset1986
                MacBook A1278 main 820-2530b not charge, it turns on only with battery
                by reset1986
                hi, I have this macbook that works correctly with battery inserted, if I connect the power supply the light turns green but it does not charge, if I disconnect the battery and connect only the power supply the light turns green and the mac enters the ignition loop 4/5 sec, turns off and repeats itself,
                on the motherboard there are no traces of liquid or damaged components,
                I tested the 3.42 and they are constant both with power supply and with battery,
                advice on what signs I can start checking?
                the power supply indicator light never turns orange,
                power...
                10-26-2021, 02:46 PM
