HP Omen 15-dc0001nh capslock blinks 5 long and 3 short
  • Tom_x
    • Aug 2018
    • 33
    • Hungary
    I have HP Omen 15-dc0001nh (DA0G3DMBCE0 rev: E) with blinking capslock 5 long and 3 short. Fans spin constans speed.
    HP worked for 2 months after i repaired (before damaged by thunder via rj45 port) I removed LAN ic and powered on
    Now with blinking capslock:
    All voltage present on big coils, except +VCCGT (i don't know this need for booting)
    I tried re-flash bios with known firmware- same result (now i don't have spare bios chip to test spi flash failure)
    DDR4 ram is ok, tested on other laptop
    WLAN and SSD removed, only keyboard and AC adapter connected
    Parts i changed:
    PCH SR40B
    Thunderbolt controller
    MP2945A
    E6930 mosfet for VCCGT
    After power on PLTRST# signal go for a moment 3.3V and after 2.4V (that is not good)
    I use for reference NLA_CFL_N17P1.pdf schematic, because for this HP impossible to find schematic or boardview
    Maybe next week i'll have preprogrammed EC (IT8987E) chip and GD25B127DSIG bios chip
    Any idea, what i check ?
    regards
    Tom
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: HP Omen 15-dc0001nh capslock blinks 5 long and 3 short
    PCH changed this time or on last repair 2 months back?Check whether DRAMRST# is 1.2V-Can be checked on pin108 of ram slot. VCCGT is not relevant now-it'll come up under load.
    • Tom_x
      • Aug 2018
      • 33
      • Hungary
      All components changed now
      I'll check DRAMRST# and post result
      Thx
      • Tom_x
        • Aug 2018
        • 33
        • Hungary
        No 1.2V on pin 108
        DRAM VCC is good,2.5 and 1.2 volts ok.
        I think main board not wake up,only power rails on
        Any idea to continue?
        • Stevedb
          Stevedb
          • Feb 2018
          • 624
          • Belgium
          if you replaced the pch did you after did a clean me off your bios.?
          Because it is needed when you replace pch.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Ram is rest by CPU and it could be bios/cpu fault. There should be a pullup resistor for dramrst# ,try to locate it and see if other end of the resistor is indeed getting 1.2V. Visually inspect the ram area for corrossion specially on ram slot. newer HP boards ram slot are of pathetic quality. I had to replace ram slot on 2 boards within the last 15 days and both were HP. Flashing a clean me known good bios may also solve your issue. Visual inspection of whole mb should be done.
            • Tom_x
              • Aug 2018
              • 33
              • Hungary
              thanks for the suggestion
              i checked whole board with microscope, no damaged component, no corrosion, no bad soldering
              interesting for clean me bios, but i can't do it, all my utility old, or not good.
              where to upload my bios dump to ask clean me?
              • Stevedb
                Stevedb
                • Feb 2018
                • 624
                • Belgium
                Here in bios section
                • Tom_x
                  • Aug 2018
                  • 33
                  • Hungary
                  uploaded, but moved here:
                  https://www.badcaps.net/forum/showth...t=96594&page=2
                  • Tom_x
                    • Aug 2018
                    • 33
                    • Hungary
                    Finally i sorted blink 5/3.....
                    All components and voltages checked, bios image was good.
                    I removed PCH (SR40B) and approx 30 ball not connected to mainboard. The PCH come from china as new, but this is not thrue. It was used and reballed.
                    I'm cleaned PCH and mainboard, reballed PCH, checked all ball with microscope. Soldered it to mainboard, and HP power up, working perfect! All component tested, all OK
                    Thanks for helping!
                    regards
                    Tom
                    • lapfix
                      Hp 15 capslock 5 long 3 short pb.
                      by lapfix
                      Hello friends.
                      hp 15 -da009nk ...la-g07cp.
                      got this lap with capslock 5 long 3 short.
                      Try new dump f.48 still the same.
                      try another dump f.04 power on..no display..consumption 0.498..no caps lock blinking.
                      ​​​​all voltage are présent.
                      pl301/302= 3 and 5 volt.
                      pl1001 1.082v.
                      pla1 1.033v
                      plz1 vcc core 1.058v
                      plg1 0v..i think it s the Intel grpahic
                      plw1 1.373v.
                      plv 3/plv4 vga core 0.918v
                      consumption 0.498.
                      original bios version f.02..
                      any help!...
                      02-18-2025, 03:34 AM
                    • rick22deus
                      Hp G9 256 no image 5 long 3 short led capslock bliking
                      by rick22deus
                      This notebook arrived to me with this symptom described in the title, I already tried to re-record the bios with some files from the website but without success, the symptom changes sometimes starting to turn on and off in seconds but it doesn't work
                      06-29-2025, 01:39 PM
                      HP OMEN OMEN by Desktop PC - 870-180na OMEN 870 i5-6400 Specification for Upgrade or Repair
                      This specification for the HP OMEN OMEN by Desktop PC - 870-180na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-180na boardview and OMEN OMEN by Desktop PC - 870-180na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                      09-12-2024, 03:44 PM
                      HP OMEN OMEN 870-033ng OMEN 870 i5-6400 Specification for Upgrade or Repair
                      This specification for the HP OMEN OMEN 870-033ng can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN 870-033ng boardview and OMEN OMEN 870-033ng schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                      HP OMEN OMEN by Desktop PC - 870-118na OMEN 870 i7-6700 Specification for Upgrade or Repair
                      This specification for the HP OMEN OMEN by Desktop PC - 870-118na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the OMEN OMEN by Desktop PC - 870-118na boardview and OMEN OMEN by Desktop PC - 870-118na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
