HELP A1989 screen with dimmed brightness issue
  • dongthoai9xvn
    • Jul 2023
    • 6
    • Viet Nam
    Hi guys. I bought a MacBook A1989 screen assembly from Alibaba, and after replacing it, I realized that I was scammed. The screen is dim, and the keyboard backlight doesn't work. I have researched and found that there is a software called SteelLite-ervds _v3-06 LCD EEPROM Programming that can fix this issue. However, I have been unable to find a place to download or purchase this software. If anyone knows where I can download or buy this software, please kindly help me. Thank you very much.
  • mon2
    • Dec 2019
    • 14004
    Re: HELP A1989 screen with dimmed brightness issue
    Have you contacted the vendor through Alibaba for support? I would attempt this as soon as possible.
    • dongthoai9xvn
      • Jul 2023
      • 6
      • Viet Nam
      yeah, I sent support but no one replied
      • mon2
        • Dec 2019
        • 14004
        How was it paid? Through a credit card?
        If yes, file a dispute of the charge immediately.
        We are currently disputing a purchase from WCH for parts for a new product design. The parcel was never delivered due to a damaged label and is stuck in Hong Kong. Yet, AliExpress is refusing to listen and has released the payment to the store. Have an open case with the credit card company.
        • dongthoai9xvn
          • Jul 2023
          • 6
          • Viet Nam
          can you tell me where to download or buy this SteelLite-ervds _v3-06 software to fix my problem ?
          • mon2
            • Dec 2019
            • 14004
            Not sure but you can ask the stores on AliExpress. You should list the store on Alibaba that sold this bad display for others to avoid.
            Is your camera working?
            Is the display bright with the logo till the login screen? Then goes dim?
            • ZOrd_Z
              • Jul 2013
              • 80
              • Portugal
              I have exactly the same problem. New compatible screen, bright on boot then goes dim....
              Do you have a solution?
              Thank's...
              • mon2
                • Dec 2019
                • 14004
                I think this is your problem?
                https://www.ifixit.com/Answers/View/...hes+after+boot
                The LCD backlight controller is a ghetto house marked one from TI (former National Semiconductor group). Respectively, no public datasheets I could find in a quick search.
                From the schematic, this controller is configured over I2C (aka SMBUS) interface using the SCL / SDA lines.
                Have a few ideas for a fix but are 'hacks'.
                Hack idea #1 -> allow for the unit to boot with the bright screen and before logging in for the dim backlight intensity, strap eith the SCL or SDA line LOW (ground). Doing so will halt further I2C bus communication so any further attempts by the host I2C bus master to dim the display will be rejected. This is safe to do but is a hack. If you get a chance and with care, consider to test it. Post your feedback on the attempt.
                Hack idea #1 -> use an I2C bus analyzer to monitor the communication from the host to this I2C slave. Review the logs (ie. Total Phase tools are good for this) to learn how the display is being dimmed.
                Then use a low cost microcontroller (WCH has some parts for around $0.10 USD) -> they have lots of code examples + free GCC compiler -> use the I2C code example and target this I2C slave address -> apply the micro's SCL/SDA lines onto the existing ones on the logic board.
                Using a time delay or pushbutton, etc., allow for this micro controller to send out the I2C bus packets to dial up the intensity again, back to normal. The value of the backlight can be user defined.
                Personally do not have the setup to test out the above.
                • mon2
                  • Dec 2019
                  • 14004
                  Hack ideas #3 - use a low cost circuit to assert a logic low after a small power on delay. The output of this circuit will be open drain (hi-z) upon power on. This will allow for the backlight i2c circuit to drive the lcd display but the addon circuit will lock down the same settings since i2c communication will fail if the SCL or SDA line is stuck with a logic low. This idea may be best and should be under $1usd to implement.
                  • mon2
                    • Dec 2019
                    • 14004
                    Read the comments from just1ed posted here:
                    https://www.ifixit.com/Answers/View/...en+replacement
                    • ZOrd_Z
                      • Jul 2013
                      • 80
                      • Portugal
                      Thank's... Experimenting....
                      • mrhoangha
                        • Apr 2017
                        • Viet Nam
                        Any body have info about SteelLite-ervds _v3-06 ? where can buy it?
                        • FaDaWay
                          Apple Tech
                          • Apr 2016
                          • 6
                          • France
                          I have this software !
                          • mon2
                            • Dec 2019
                            • 14004
                            Please post it here to assist future repairs.
                            • FaDaWay
                              Apple Tech
                              • Apr 2016
                              • 6
                              • France
                              This is the software you are looking for !
                              In my memories this software works on High Sierra
                              I just tried it on montrey but I can't launch it.
                              • FaDaWay
                                Apple Tech
                                • Apr 2016
                                • 6
                                • France
                                It seems to works only on Mojave !
                                • roxu31
                                  • Jan 2014
                                  • Spain
                                  Hello, to solve the brightness problem do the following. Start the macbook with catalina or bigsur, open the steellite app and in the second tab change the value of the id panel to A039 then click on write to eeprom, close the steel and restart the macbook, with that the system applies the correct values at startup and the backlight level is corrected. I advise you against playing with the eeprom and its values and always make a copy of the eeprom before touching anything. Luck.​
                                  • mon2
                                    • Dec 2019
                                    • 14004
                                    Thank you roxu31 for your post on the details. Very much appreciated!!
                                    • spidey
                                      climbs
                                      • Dec 2012
                                      • 644
                                      • Cyprus
                                      hey guys. I didnt get the app work on catalina. Is there any other version of it ?
                                      • 3com
                                        • Sep 2016
                                        • 4
                                        • Argentina
                                        Is there any newer version of the software that works or is compatible with M1 DP855A, why it is compatible with Winbond DP805A
                                        • cloudy
                                          HELP - Contrast/brightness issue with subtitles on screen
                                          by cloudy
                                          Hi everybody
                                          Since day one I'm having an unpleasant contrast/brightness issue on my Asus laptop.
                                          Basically while watching movies, if subtitles appear on screen, the contrast or the brightness of the entire screen increases a lot (not sure if it'is brightness or contrast), disturbing the viewing of the movie.
                                          Last year I replaced my screen because got damaged and this contrast/brigthness issue persists. It happens only on the laptop screen, in fact If i plug an external HDMI screen the issue does not occour on it.
                                          It occours both on ubuntu and windows...
                                          01-01-2023, 05:12 PM
                                        • wizard13
                                          Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
                                          by wizard13
                                          I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
                                          I have checked the forum and the available documentation but could not find a solution specific to my issue.
                                          • Brand & Model: Dynabook Satellite Pro C50D-B-100
                                          • Part Number (P/N): PYU13E-00C00PFR
                                          • Serial Number (S/N): 22028896H
                                          • System Configuration (SC): A1PYU13E1127
                                          • Motherboard Model: IP3_ACN16_MB_V21_20211222A
                                          • Power Input: DC 19V –
                                          02-28-2025, 02:43 AM
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
                                        • ScHAmPi
                                          Samsung UE48JU7000 screen issue after backlight replacement
                                          by ScHAmPi
                                          Because of two bright spots and a couple of dark spots I decided to replace the backlights in my Samsung UE48JU7000. See attached photos:
                                          I thought all went well, but after full assembly and testing it out it turns out not all is fine. The backlights are completely fine but I have some weird issues on the right half of the screen. Since I didn't really touch the T-CON board (apart from taking out the ribbons of the display and reconnecting them on assembly) it would be weird that the issue is with the T-CON board... But based on the behavior of the service...
                                          07-15-2024, 05:41 AM
                                        • smic717394
                                          by smic717394
                                          07-25-2024, 10:16 AM
