iPhone 11Pro Max - Not Open
  • Spongebob89
    • Mar 2021
    • 24
    • England
    I have an iPhone 11Pro Max where took a sea water on it in a protective bag that I had it. When I connect it on the PC the PC doesn't recognise it at all. I opened and I saw white corrosion on the down side of the screen (at the side of the charging port). I took some measurements on the battery connector with the screen connected and without the screen connected (at the attached photos). Could you tell me if the measurements that I took are OK without the screen attached on the main board. One measurement it has to be 0,002V and it was 0V.. is that OK? Also, if the main board is OK there is a way to fix the screen or I have to replace it definitely? I want only to syncronise my contacts in the cloud and not necessarily to fix it to be for daily use again. The phone as I know from the previous owner had taken again water from the same point and then he replaced the screen and worked again.
  • wetpretzel2
    Today I learn
    • Feb 2021
    • 13
    Re: iPhone 11Pro Max - Not Open
    The iPhone 11 pro max has two battery connectors, one at the bottom as well as the one measured. There are only two active lines on that battery connector, the big one in the middle that you have a voltage read on and the one next to it with a voltage read on it. Diode values will give you a better understanding of what it going on with it. I would say, replace the charge port and screen, hook it up to a PC, back it up then get into the nitty gritty if still needed.
    • Spongebob89
      • Mar 2021
      • 24
      • England
      Thanks for your reply. With only connected the connectors 1 & 2 the current that draw the iphone is about 500mA (if I disconnect the connector 1 the current falls to zero). This current is normal with olny these connectors connected? Also, there is a way to fix the Charging Flex (if it is indeed the problem there)?
      • Spongebob89
        • Mar 2021
        • 24
        • England
        Finally I changed only the LCD screen and worked flawless.
        • Ryan.man
          by Ryan.man
          02-04-2025, 12:23 PM
        • AJ847.63e
          iPhone X earpiece compatible with XS screen?
          by AJ847.63e
          Hi All,
          Has anyone tried to use a XS screen on a iphone X before? I've got a old dead iPhone XS which I was hoping to use the screen on my iphone X as the glass on it has cracked. According to google the connectors are the same but some screw holes don't line up, but I'm assuming that doesn't matter as I can use some double-sided adhesive instead. Better than spending 280 bucks on a new screen when I already have a perfectly good OEM XS one.
          07-31-2023, 10:31 PM
        • smic717394
          by smic717394
          07-25-2024, 10:16 AM
        • Chrissygizmo
          by Chrissygizmo
          02-10-2025, 12:33 AM
        • spice_disc
          Vizio TV M50-C1 reboot cycle and static on screen
          by spice_disc
          I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
          The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
          09-08-2024, 02:37 PM
