MacBook Air 1466 Internal SSD not detected
  • ACS-Repair
    • Feb 2021
    • 204
    So, this is a continuation of an 820-3437 that i've been working on for a while. it originally wouldn't power up because of a PP3V3_S0 short, but all of that has been sorted out.
    I ran this successfully on an external flash drive while I awaited the arrived of a SSD from ebay. To my surprise the new SSD was not recognized in the computer. I found that the PP3V3_S0SW_FLT was missing from Pins 1-5 on J3700. I changed U8070 twice but realized the problem was a poor connection of C8071 (PP3V3S0SW_SSD_FET_RAMP). after fixing the trace i have PP3V3_S0SW_FLT now, and I thought I would be done.
    Even at this stage now the SSD is still not recognized at all. The SSD works fine in a 2014 Mac Mini, and I used it to install High Sierra on the drive.
    Voltages that i get on J3700:
    PP3V3_S0SW_FLT 3.3v
    PP3V3S0 3.3v
    SSD_PWR_EN 3.3v
    SMC_OOB1_R2D_CONL 3.2V
    SMC_OOB1_D2R_CONL 3.2V
    SSD_PCIE_SEL_L 3.3V
    This is the first time i've had a problem with an internal SSD so i'm not 100% sure what a couple of these values should be. I would appreciate it if someone has any thoughts on this.
  • reformatt
    • Feb 2020
    • 1501
    Re: MacBook Air 1466 Internal SSD not detected
    Apple SSD or 3rd party via adaptor? SSD_RESET_CONN_L needs to be high IIRC, so check U3740 and and SSD_RESET_L from the PCH.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      It could be a bios issue. recently i faced same problem on 820-00165A,emc 2925 board and i requested a bios in bios section but unfortunately got no response. Anyway,if you need the bios i can post it for you.First,rule out the hardware issue. In my case SSD_RESET_CONN_L was indeed high.
      • ACS-Repair
        • Feb 2021
        • 204
        Thanks for the comments guys...
        The SSD is a genuine Apple Sandisk 128GB flash drive. SSD_RESET_CONN_L measures 3.41v, SSD_RESET_L is 3.09v.
        Interesting thought about the EFI BIOS. I think there is something I can drop in just to see if it make a difference. if you have a clean ME BIOS for the 820-3437A I would appreciate getting it to try.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          I dont have one for 3437A.I have one for 00165A
          • dellxps15
            • Feb 2014
            • 1598
            • italy
            820-3437 clean me bios. replace serial number with your. piernov made a great video about it.
            https://www.badcaps.net/forum/showpo...01&postcount=4
            • reformatt
              • Feb 2020
              • 1501
              Apple did update the NVMe driver some time back in the BIOS, I think to accommodate some newer variants of SSD that were being made for them. Without that, 3rd party SSD's don't get detected. It's possible that the SSD you bought may have needed the newer BIOS.
              Unfortunately, the NVMe driver therein is not compatible with the latest Gen 3 SSD's on the market. For example, Crucial P2 drives were fine (but sadly EOL), but the P3 or later drives are not detected. Kingston NV2 drives were working up until my last shipment but are now no longer being detected with the latest revision. I doubt that Apple will do any more changes to the BIOS for the older systems other than security.
              • ACS-Repair
                • Feb 2021
                • 204
                Thank you @dellxps15 and @piernov for the clean ME EFI file. I'll give it a shot.
                • ACS-Repair
                  • Feb 2021
                  • 204
                  Installed the EFI with a clean ME after updating the serial number but the SSD is still not recognized. Good thought though and it rules out that as an issue.
                  This is stumping me. makes no sense at all. The SSD has High Sierra installed which should work on any of these without trouble.
                  • reformatt
                    • Feb 2020
                    • 1501
                    I took a look at the BIOS supplied and it is quite old (V117.0.0.0), so not sure if that one has the updated NVMe driver in it. Current version is V474.0.0.0. I'll see if I can upload a clean ME with dummy serial later.
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      Going by my experience with 820-00165A and your measurements of SSD, i'll still bet for bios.
                      • kevingill
                        • Jun 2013
                        • 152
                        • England
                        How did you format the SSD? In the Mac mini?
                        APFS or Macos Extended?
                        If the Air EFI is old it won't recognise an APFS file system.
                        • dellxps15
                          • Feb 2014
                          • 1598
                          • italy
                          yes the bios is a bit old, and i had to update bios to get appfs recognized.
                          if u can install os on another ssd and upodate bios or with a guide posted here by reformatt, or install an os version prior to big sure then update to big sure. that also update firmware.
                          ofcourse long procedure. otherwise maybe wait for newer bios version with clean me( i used that as other clean me bios ive found didnt work)
                          • Rezid
                            • Mar 2021
                            • 8
                            • US
                            I had sort of the same issue earlier this week. Same 820-3437 board wouldn't recognize any SSD I put in if I tried to boot to Big Sur, Catalina, or High Sierra installer. I ended up just using internet recovery which did detect the drive. I installed Mavericks through that then just went through the slow process of upgrading to Big Sur. I believe it was a BIOS issue and not recognizing APFS but can't really confirm that.
                            • ACS-Repair
                              • Feb 2021
                              • 204
                              So, to answer a few of these....
                              The EFI file is from November 2019, but the computer is from 2014 so I don't know if an update is required.
                              The drive is formatted MacOS Extended Journaled to install High Sierra. I know APFS formatted drives can be unreadable on an older OS. Drive utility doesn't see the drive no mater Which OS I try to use including El Capitan.
                              The drive is not detected when I load from Recovery, which loads Mavericks interestingly enough.
                              I haven't been able to master the art of doing a clean ME but I could post my original EFI if someone would do the honour of cleaning it for me. I would clear the serial number first so that it could be made available to anyone.
                              I've also done a PRAM and SMC reset but still no joy. This board originally had a PP3V3_S0 short that I could not resolve through voltage injection. I moved several caps on the line until I found the offending one. it may be that I have disturbed something and I need to retrace to see if there is something that I have caused.
                              Thank you all for your responses. I'm sure I will get this fixed one day with your help and hope it will then help others, which is the whole point of the forum.
                              • reformatt
                                • Feb 2020
                                • 1501
                                CleanME dump added here of the latest version I have (V474.0.0.0). Serial number altered to that of original but checksum updated.
                                https://www.badcaps.net/forum/showpo...&postcount=145
                                • ACS-Repair
                                  • Feb 2021
                                  • 204
                                  Thanks @reformatt. I'll give that one a try.
                                  • ACS-Repair
                                    • Feb 2021
                                    • 204
                                    Unfortunately, that EFI didn't make a difference. This is for sure no simple issue. Maybe there is a deeper fault with the PCIe bus or processor related to the internal SSD. I may take a break and go over the lines to the SSD to see what is different between an early 2013 MBA that I have. I'm considering just installing the OS on an external USB flash and running the computer that way. Not the best option but at least it would work that way.
                                    • spidertnt
                                      • Jul 2016
                                      • 34
                                      I struggled with 820-0165 Air ...liquid damage that would not see SSD ...tried clean bios etc.. gave up.
                                      Months later i had been upgrading customers to NVME using adapters . I tried using NVME on it and it worked fine ...detected and worked with no issue . Tried original Apple SSD again no go.
                                      • mon2
                                        • 14667
                                        Check the diode mode readings of the following pins at the SSD connector:
                                        PCIE_SSD_R2D_C_P<0>,
                                        PCIE_SSD_R2D_C_N<0>,
                                        PCIE_SSD_R2D_C_P<1>,
                                        PCIE_SSD_R2D_C_N<1>,
                                        PCIE_SSD_R2D_C_P<2>,
                                        PCIE_SSD_R2D_C_N<2>,
                                        PCIE_SSD_R2D_C_P< 3>,
                                        PCIE_SSD_R2D_C_N<3>
                                        • ahmarzo
                                          MacBook Air a 1466 keyboard and touch not working
                                          by ahmarzo
                                          Have a MacBook Air a 1466 with part no 820-00165-a with keyboard and touchpad not working.have tried another working keyboard and touchpad.have check the cable to board and it's good
                                          The voltage on connector j4800 is following
                                          Pin no 1-3.3v
                                          Pin no 10 3.3v
                                          Pin no 14 - 5v
                                          Pin no 15-20 all pins have 3.3v
                                          Have reballed the ic u 5000. And tried another ssd with working os .
                                          10-18-2025, 10:40 AM
                                        • NPIRES
                                          Macbook air 1466 820-00165-A SSD not detected
                                          by NPIRES
                                          Hello.
                                          Pins 1-5 of ssd conector show 0v.
                                          L3700 is ok, (also 0V on both sides)
                                          Some hints for where to check next, please.
                                          TIA
                                          02-13-2023, 06:35 PM
                                        • envym
                                          by envym
                                          Hi everyone!
                                          06-27-2025, 08:54 AM
                                        • Yosua
                                          MACBOOK AIR 1466 DEAD
                                          by Yosua
                                          HELLO FELLOW COLLECTORS, How are you doing, I hope GOD always gives us good health, I'm here asking for help to work on this MacBook Air, to be honest, this is the first time I'm dealing with a MacBook machine, and I immediately decided that the ISL 6259 IC and after I replaced it it still didn't work and I found that the CHGR_CSO_N & CHGR_CSO_P pins had a short circuit.
                                          can anyone help me guys?​
                                          02-17-2025, 02:07 AM
                                        • bibinskii
                                          Macbook Pro M1 (A2338) - Not Charging but Detected and Post
                                          by bibinskii
                                          A client showed up with a Macbook Pro M1 stating that the battery doesn't get charged (no increase in percentage) but still charge. She left me with the battery 25% and still draining. The Macbook is fully functional. I checked with coconut battery and system report. Battery health shows 85% and stating normal condition, no abnormalities. When it is charging, the system says it takes 10 hour to finish charging. I went ahead to charge it for a longer period, the battery just drains (doesn't get charged).
                                          At first, I thought that this must be a battery issue. I went to replace the battery....
                                          07-22-2024, 12:22 AM
