Macbook air 1466 820-00165-A SSD not detected
  • NPIRES
    • Oct 2012
    • 20
    • Portugal
    Hello.
    Pins 1-5 of ssd conector show 0v.
    L3700 is ok, (also 0V on both sides)
    Some hints for where to check next, please.
    TIA
  • reformatt
    • Feb 2020
    • 1501
    Re: Macbook air 1466 820-00165-A SSD not detected
    Check U8070, pin 2 and pin 5. Check for liquid damage around and under the IC.
    • NPIRES
      • Oct 2012
      • 20
      • Portugal
      You sir, are the BOSS.
      U8070 removed, pins 1 & 2 all corroded.
      After a good cleaning, ssd detected again.
      Thank you very much
      Nelson
      • ahmarzo
        MacBook Air a 1466 keyboard and touch not working
        by ahmarzo
        Have a MacBook Air a 1466 with part no 820-00165-a with keyboard and touchpad not working.have tried another working keyboard and touchpad.have check the cable to board and it's good
        The voltage on connector j4800 is following
        Pin no 1-3.3v
        Pin no 10 3.3v
        Pin no 14 - 5v
        Pin no 15-20 all pins have 3.3v
        Have reballed the ic u 5000. And tried another ssd with working os .
        10-18-2025, 10:40 AM
      • envym
        by envym
        Hi everyone!
        06-27-2025, 08:54 AM
      • Yosua
        MACBOOK AIR 1466 DEAD
        by Yosua
        HELLO FELLOW COLLECTORS, How are you doing, I hope GOD always gives us good health, I'm here asking for help to work on this MacBook Air, to be honest, this is the first time I'm dealing with a MacBook machine, and I immediately decided that the ISL 6259 IC and after I replaced it it still didn't work and I found that the CHGR_CSO_N & CHGR_CSO_P pins had a short circuit.
        can anyone help me guys?​
        02-17-2025, 02:07 AM
      • bibinskii
        Macbook Pro M1 (A2338) - Not Charging but Detected and Post
        by bibinskii
        A client showed up with a Macbook Pro M1 stating that the battery doesn't get charged (no increase in percentage) but still charge. She left me with the battery 25% and still draining. The Macbook is fully functional. I checked with coconut battery and system report. Battery health shows 85% and stating normal condition, no abnormalities. When it is charging, the system says it takes 10 hour to finish charging. I went ahead to charge it for a longer period, the battery just drains (doesn't get charged).
        At first, I thought that this must be a battery issue. I went to replace the battery....
        07-22-2024, 12:22 AM
      • Flasman90
        Macbook Pro DFU Restore Issues
        by Flasman90
        I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
        - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
        - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
        08-30-2025, 10:27 AM
