HP 14s-cr2002tu 3V3A short to ground
  • motanya
    • Nov 2021
    • 160
    • Kenya
    This laptop has a 3v short, client says he was replacing casing and on closing inserted LVDs cable while battery was connected. It never came on, I have tried to look for shorted cap or ic can't find one, is it possible the processor/PCH is dead?
  • asliyucegsm
    • Jun 2011
    • 347
    • Turkiye
    Re: HP 14s-cr2002tu 3V3A short to ground
    my friend, you can find the solution by separating the 3V3A related connections with the schematic, it is easier to find it by looking at the schematic.
    good luck
    • todenkopf
      • Oct 2014
      • 49
      • UA
      Yes, the possibility that CPU/PCH is now dead exists, but more often such manipulations kills the EC.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        In case of edp cable connected/disconnected with power source in, its more likely PCH thats shorted. Measure resistance to GND on 3V LDO(which is very likely shorted). You may need to inject voltage 1V/5A on 3V LDO to see if anything is hot.
        • playit
          450watt power supply 5v, 3.3v short to ground wire,in output rail ,connectors
          by playit
          hello everyone , working zebronics power suply 450 watts , 5v ,3.3v givin short to ground black wire, also in circuit at output, resistor was charred but shows right values , after removing resistors 39ohms, 51 ohms, there was no short , no continuity beeps with ground , but after replacing new resistors (now i am not switching it on) ,again short still exists . when i put bigger ohm resistor like 100k ohm , no short beeping sound comes , lower ohm resistor gives continuity beeps ,other big ones donest , as its a working psu , i am confused what to remove now or how to go further now .
          09-02-2023, 02:43 AM
        • MisterAIL
          820-00840 / No boot / PP3V3_G3H Short to ground
          by MisterAIL
          Firstly sorry for my english, french guy inside.
          I brought a macbook pro A1708 - 820-00840 logic board, wasn't powering on.
          History is a day, nothing happened when opening the laptop.
          Nothing special inside, no corrosion, no liquid damage, never opened.
          First, with the logicboard alone on the desk, mesures are :
          5v017 and 0.000 amp. nothing else.
          Finding a short on the PP3V3_G3H_VR, but not on the PP3V3_G3H (0.540 on diode mode), PPDCIN_G3H_CHGR_R present (5,1 volts) PPVIN_G3H_P3V3G3H around 4.1 volts. PM_EN_P3V3_G3H...
          10-13-2021, 11:42 AM
        • triplefour
          Samsung UN55ES7003 has blown fuse on TCON and short to ground.
          by triplefour
          Samsung UN55ES7003
          made house call.
          red power led comes on, blinks twice, no display, no backlight, relay clicks, repeat.
          psu has self test feature.
          disconnected from mainboard.
          determined PSU ok BL ok.
          suspect mainboard.
          disconnecting tcon has no change on operation.
          markings on mainboard:
          BN97-06531P 0151
          BN94-06123R
          found and ordered replacement on ebay https://www.ebay.com/itm/394077328633
          for 54$
          second house call:
          with replacement mainboard, tv turns on, has sound,...
          07-13-2022, 03:53 PM
        • Prott
          PS5 - long screw damage, via to ground layer short?
          by Prott
          Hello dear Badcappers,
          I came across a PS5 that was longscrewed. The screw went through the HDMI IC (which I replaced + repaired the traces it damaged), however the screw also bend the board and slightly cracked it on the other side. It still seems like it could be fixable though as the area might not have lots of traces going through it (fingers crossed).
          Can somebody, please, measure their board and tell me if my assumption of an inner short between the via and ground layer is correct? These 3 pads have almost no resistance. I would like to make sure those are not some data...
          07-27-2024, 08:54 AM
        • DynaxSC
          Extreme High Current & Low Voltage Short Killer ??
          by DynaxSC
          Hi Folks
          I'm looking for a extreme high current short killer solution for a reasonable cost.
          I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
          After taking off the socket, the shorts dissappear again.
          The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
          10-15-2024, 10:13 AM
