ideapad 3-14ITL6 Laptop - Type 82H7 repair
  • yaso143
    • May 2021
    • 49
    • philippines
    hs460 hs 560 hs 760 nm-d471
    Can anyone had an idea about this the laptop turns on power rails seems good
    but no display checked the 19v , 1.8 , 3v , 5v i have flashed a good bin file to it but still it wont display
  • DoOm86
    • Nov 2022
    • 42
    • italia
    Re: ideapad 3-14ITL6 Laptop - Type 82H7 repair
    Hello, did you solve your issue?
    Did you check with an external monitor?
    You tried the basic right? Ram, removing all the unnecessary connections such as TouchPad, keyboard, hard drive, WiFi, secondary pcb if present, battery etc..
    • yaso143
      • May 2021
      • 49
      • philippines
      no luck i have tried to power it on using bare minimum the ram was built in with the board i did add another ram just to be sure
      do you think it might be a corrupted kbc?
      • Sephir0th
        • Oct 2020
        • 1262
        Measure resistance to GND of all secondary power rails. Maybe a partial short hidden somewhere.
        FairRepair on YouTube
        • DoOm86
          • Nov 2022
          • 42
          • italia
          What sephir0th suggested is correct, can be that. I would make also sure that every single mosfet is not shorted (mind that the cpu/gpu are low resistence when check then), if the bios is talking with rest of the board (probably for that you would need an oscilloscope). Check if cpu and chipset are cracked or there are sign of burn.
          Did you also try to reset the bios after re-flash it?
          • yaso143
            • May 2021
            • 49
            • philippines
            Your Advice were really helpful i actually fixed apparently the 2r2 resistor that delivers power to the ic controller for the vccin was damage so i replaced it and it works
            • DoOm86
              • Nov 2022
              • 42
              • italia
              Well done!
              • yaso143
                • May 2021
                • 49
                • philippines
                Well done!
                ihave another question if you dont mind ihad a exact ssame unit but the issue is the lcd wont turn on i tried using a external monitor and there is a display i checked LCDVDD (3.3 present) i checked lids switch (3.3present) but the LEDVDD is missing what voltage should i get normaly on LEDVDD? and whats its pupose?
                • Vesko356
                  VIP Moderator
                  • Aug 2018
                  • 4386
                  • Bulgaria 🇧🇬
                  Check fuse FV1.
                  LEDVDD=B+=20V (main power rail).
                  Become a Badcaps supporter
                  Thanks to all supporters.​
                  • mazloum
                    laptop ideapad 3-15IML05 Laptop - Type 81WB
                    by mazloum
                    Hi, I have this laptop ideapad 3-15IML05 Laptop - Type 81WB,
                    serial number: PF3DN87L
                    MTM: 81WB010DAX
                    board: GS452/GS552/GS752 NM-C781 Rev:1.0 2019-11-25
                    the problem is it powers up for10 seconds, no fans no picture then powers off, after few seconds it powers on by itself, also no display and then off, i found u4401 burnt , i removed it because i did not find it
                    3v and 5v are both present, 3.3v is present on bios, i reprogrammed bios with no success...
                    01-16-2024, 10:31 AM
                  • hotcrossedbuns999
                    IdeaPad 1-14ADA05 Laptop - (Type 82GW) bios
                    by hotcrossedbuns999
                    First off, I saw the other thread, but that seems to be a different version (same model though), because I tried all of the linked bioses and none work. They actually cause the laptop to do nothing. At least when I use the bad bios, lights come on. (charging light, power button light, and caps lock light), but no screen.
                    Another thing is that the bios has a different name (Old thread has "e8cn36ww" and mine is "fqcn31ww") and the BIN in this thread (below) are 8mb, and the CAP file that I get is 16mb (after using innextract 1.9). I don't know how to get the BIN...
                    05-21-2025, 05:59 PM
                  • danielFAB
                    LENOVO IdeaPad 1 14IGL7 Laptop - Type 82V6
                    by danielFAB
                    Hi. i need BIOS dump please
                    IdeaPad 1 14IGL7 - Type 82V6
                    JS47R&JS57R NM-E791 REV 1.0
                    sn PF4G9WW9
                    after a windows update, 0.120A and no video
                    Thank you in advance
                    attached original BIOS​...
                    05-19-2025, 11:04 AM
                  • yaso143
                    ideapad 3-14ITL6 Laptop - Type 82H7 bios extract
                    by yaso143
                    can somebody help me extract this bios...
                    06-15-2023, 08:36 AM
                  • saisoni20
                    Yoga 6 13ARE05 Laptop (ideapad) - Type 82FN bios
                    by saisoni20
                    Hello Everyone,
                    I'm looking for bios for Lenovo Yoga 6 13ARE05 Laptop (ideapad) - Type 82FN bios.
                    I have attached bios bin file but I have no trust on this file as the laptop is dead.
                    SN: MP1ZNT1H.
                    Thanks...
                    08-31-2023, 05:13 PM
