hp 15 fan error 90b
  • OMWANA1966
    • 6
    • kenya
    hp 15 fan error 90b
    i have a core i3 hp laptop with error fan not running correctly press enter to continue or the computer will shut down-error 90b
    i have replaced the fan and serviced the air vents but the error still remains. anybody with a solution to help me out there is welcome
  • DoOm86
    • Nov 2022
    • 42
    • italia
    Re: hp 15 fan error 90b
    Hello. Do you know how to use a multimeter? Maybe you could check the voltages on the connection of the fan. If the fan is spinning regularly, probably something is wrong with the data line (the fan has 3 or 4 cable connection?)
    • luvbe3
      Chicken
      • Oct 2017
      • 154
      • JAPAN
      try to remove the battery and cmos battery.. press the power button for about 30 seconds. Reinstall it and see if that fixes the problem
      • Sus256
        HISENSE 65E7KQ PRO - no boot
        by Sus256
        Hi all!
        HISENSE 65E7KQ PRO
        RSAG7.820.13512 - chassis
        MT9618BAATAB - cpu
        RSAG7.820.12059 - power
        HD650Y3U77 - panel
        KLM8G1GETF - emmc
        Replaced emmc.
        Terminal log
        UART
        AC_ON
        E-B
        FDE enabled
        06-01-2025, 02:11 AM
      • sushilachuthan
        APC UPS error P13
        by sushilachuthan
        one of our new (only 4 year old) 1KVA APC UPS stop working and through error P13 contact customer support.
        the equipment is out of warranty , upon investigation, we found the inverter board has the fault on the output hybrid relay circuit.
        The inverter output relay is parallel by SCR/Triac to enhance the relay performance or other means.
        We replaced the SCR with new device,, but the device is not power on as expected.
        Further research on the issue found that, the error P13 (event ID 107) is latched on the UPS nvram/MCU and need to clear/reset using a service procedure....
        09-26-2025, 09:00 AM
      • Woodsworth
        PS3 CECHC03 60GB YLOD Troubleshooting
        by Woodsworth
        I have a post on psx-place for this but thought I'd try here as well in case anyone has experience or the schematics or any kind of help. Here's the original post from psx-place:
        START
        Hi, so I bought a YLOD Fat PS3 as I wanted a repair project and thought it would be a good way to get experience. I was able to solder to the RX, TX and Diag pads on the COK-002 motherboard and was able to get external access and retrieved the codes. I haven't powered it on beforehand so these should be the last ones. I did try to get internal access immediately after but kept getting scopen response...
        03-19-2024, 07:58 AM
      • Superbee_dad
        Sharp 80” long short flash backlight error - Help
        by Superbee_dad
        Hello Sharp TV experts
        Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
        > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
        > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
        01-24-2025, 11:51 PM
      • Curtissimo
        HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
        by Curtissimo
        Hi everyone.
        I have a HP Elitebook 850 G8.
        Serial: 5CG2324XM0
        ProdID 6L8D5EC#ABA
        It has a Winbond W25Q256JVEN Chip.
        I need to remove BIOS Password.
        I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
        Attached my dump.
        I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
        I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
        What I did:...
        08-26-2025, 04:42 AM
