Asus FX505G - no power to battery and won't turn on
  • CptChronic
    • Jul 2022
    • 39
    Re: Asus FX505G - no power to battery and won't turn on
    Originally posted by Sephir0th
    ACDRV is low, but not without voltage. Could point to faulty DC-IN Mosfets. Do you know howto check? Sadly we didn't this sanity measurements before...
    Well that chip has definitely fixed some of it as I'm now getting voltage on the gates of those 2 mosfets and 20V is flowing through them. It wasn't before. I've traced the voltage and it stops at 2 other mosfets and turns into 0.2V on their outputs. These are located right next to the battery connection. Pics here: https://imgur.com/a/Hi0HOqw
    • CptChronic
      • Jul 2022
      • 39
      Originally posted by mon2
      Remove the ~4k resistor that will be in series with the ACDRV pin and often is driving the gate pins of the 2 x DCin mosfets.
      Do not lose the removed ~4k resistor.
      Power up again. What is the voltage to ground now of the ACDRV pin?
      I get 0 volts with that resistor removed
      • mon2
        • 14662
        Is the battery charged?
        Remove all power from the power adapter. Use only the battery -> does the logic board power up on the battery power only?
        • CptChronic
          • Jul 2022
          • 39
          No the battery is dead unfortunately, it wasn't being charged by the circuit. I'm pretty sure it was at 10V on Friday but now it's 0V.
          After refitting the resistor I'm now getting 25V on the ACDRV pin
          • Sephir0th
            • Oct 2020
            • 1289
            That's perfect. Main power rail is fixed then. No need to look into the battery charging circuit without battery even present. The voltages you have measured there are useless and meaningless without battery.
            You're saying it still doesn't turn on?
            FairRepair on YouTube
            • CptChronic
              • Jul 2022
              • 39
              #26
              Brilliant.
              This battery is strange, I fitted it and it started reading 9.5V, it did the same once disconnected. So I put everything back together and tried again but now the battery is back reading 0V both disconnected and connected
              No it doesn't turn on either
              • Sephir0th
                • Oct 2020
                • 1289
                Okay, next step would be to confirm, whether a) 20V are still present at the main power rail and b) the EC receives 3.3V from LDO Regulator. Maybe you even get 3.3V at the Power-Button right now.
                • CptChronic
                  • Jul 2022
                  • 39
                  #28
                  I'm getting 20V upto these mosfets here: https://imgur.com/a/Hi0HOqw it's the same with or without the battery connected.
                  I can't get to the button to check the voltage unfortunately, I'm guessing it is connected to one of the pins of the ribbon that comes in through the right hinge but I've no idea which. https://imgur.com/a/1ZIgJ7e
                  I've checked the voltage on the EC though, it's an IT8987 here's the pinout: https://imgur.com/a/juTs0Bo pin 11 is not receiving any voltage. Here's some more pictures of the surrounding area: https://imgur.com/a/T2MBpcy
                  Is this the LDO here? https://imgur.com/a/PfMxyn5 it's not receiving any voltage if so. Datasheet here: https://www.google.com/url?sa=t&sour...-V6P4fyzIYnwdo
                  • Sephir0th
                    • Oct 2020
                    • 1289
                    Almost.
                    The +3VA will be most likely created from the same controller who controls the buck converter for the +3VA_DSW (or however it is called here, basically the voltage at the coil) and on some ASUS devices the +3VA_EC has to be additionally enabled from a loadswitch via PS_ON signal, a switch as you showed in your pictures, thinking it is the "LDO". You might have +3VA "Input" from the controller on one side and +3VA_EC "Output" reching the embedded controller on the other side.
                    Staying at +3VA, simply pay attention to the EC Pins 26, 50, 92, 114, 121, 127. Do measures resistance to GND of these Pins without power afterwards
                    • CptChronic
                      • Jul 2022
                      • 39
                      #30
                      Almost.
                      Sorry for the delay, I had to go home last night.
                      So I've tested all those pins, they're all receiving 0.27V and are reading 2 Ohms each.
                      Guessing that's not good?
                      Where did you learn all this stuff if you don't mind me asking? Never would of gotten this far without you man
                      • Sephir0th
                        • Oct 2020
                        • 1289
                        Youtube, Discord, Badcaps.
                        Yes, there is a short to GND and yes it is most likely the embedded controller. However, better to confirm by injecting 1Volts/1Ampere and see whether it will heat up. You are allowed to raise the current, if the board takes the full 1Amps and still nothing getting hot.
                        • CptChronic
                          • Jul 2022
                          • 39
                          #32
                          I watch alot of Sorin and a few other guys on YouTube.
                          Is it a programmed EC? Or can I just swap it out for an off the shelf chip?
                          I hate to ask but where should I inject voltage? Better safe than sorry
                          • Sephir0th
                            • Oct 2020
                            • 1289
                            You inject more or less at one of those pins where you have measured the 2 Ohms short before, or any connected point you can assume and verify by visual inspection/multimeter.
                            You might be lucky and the EC programs itself from the main BIOS flash, as on many other ASUS mobo's. But this will only work if the EC flash is "empty" and no guarantee, of course, as always.
                            • CptChronic
                              • Jul 2022
                              • 39
                              #34
                              https://imgur.com/a/8Vmc0yc
                              It doesn't heat up excessively at 1A 1V - my power supply will only give it 0.27A though no matter what I set it to. It's rated for 10A
                              • Sephir0th
                                • Oct 2020
                                • 1289
                                That's enough confirmation. Remove it and then measure the pads again which measured shorted before.
                                • CptChronic
                                  • Jul 2022
                                  • 39
                                  #36
                                  Perfect, I have now removed it and the resistance rises rather than sitting at 2 Ohms. I stopped when it got to 90K.
                                  Ill get one of these chips ordered and will update you once it arrives. Fingers crossed it programs itself like you said
                                  Thanks again for all the help buddy!
                                  • CptChronic
                                    • Jul 2022
                                    • 39
                                    #37
                                    Got the new chip fitted today, the battery is now receiving 3.3V when plugged in and the black lit keyboard lights up but that's about it. The charging light isn't even lit up. The red output wires from the battery are still on 0.228V, I've managed to get that upto 9.XV by poking around the mosfets, I guess I turned one on by the gate but it made no difference and didn't stay that way for long.
                                    The cpu is getting warm.
                                    Do you think this is because the EC needs to be programmed? I've done a load of reading and watched some videos and apparently when they're new they shouldn't need to be programmed but I haven't a clue. I'm gutted, was really hopeful this was going to fix it
                                    • Bowline
                                      by Bowline
                                      06-11-2025, 10:13 AM
                                    • dhenion
                                      Asus VivoBook F510UA-AH51 won't run on battery after motherboard replacement
                                      by dhenion
                                      I'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
                                      The original board was:
                                      ASUS X510UNR REV 3.0 A
                                      The replacement board is:
                                      ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
                                      It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...
                                      01-30-2024, 01:45 PM
                                    • julianmustofa
                                      Asus x453ma only turn on when plugged in (battery was fine)
                                      by julianmustofa
                                      Hi all
                                      Iv'e been working on asus x453ma that only turn on when the ac adapter connected
                                      The battery itself was fine
                                      So this is what happen
                                      -plugged ac adapter
                                      -trigger power button
                                      -laptop turning on
                                      -unplug the ac adapter
                                      Laptop still on with battery
                                      -without ac adapter
                                      And nothing happens
                                      Have no idea what is going on
                                      Charging sistem still works when laptop is turning on
                                      And also when battery reach 100% the charging indicator still red. It should turn white/green...
                                      10-18-2023, 01:48 PM
                                    • Iherduleikgemz
                                      Asus FX505DY - Battery not charging - BQ24780S
                                      by Iherduleikgemz
                                      Hello everyone
                                      I have been working on this laptop mentioned in the title, it initially had a shorted capacitor. After I replaced it, the thing started working again, but there is still another problem. The laptop was running off a charger, the battery was reporting 96% charge... but when I unplugged the charger, the laptop died. I've measured the battery voltage - 0V. I think it is locked. (Screenshot from batterymon, below).
                                      I've ordered a new 3rd-party battery, but I think there's something wrong with it too - the laptop boots, but the battery isn't charging. Also,...
                                      01-13-2025, 03:54 PM
                                    • mkdj
                                      by mkdj
                                      Mark and model: ASUS X571
                                      Tests already made:
                                      - I have removed...
                                      07-14-2025, 09:16 AM
