Macbook A1708 - 5V/0A -no power- liquid damage.
  • martyjelen
    • Mar 2023
    • 127
    • Czech republic
    Hello, I have macbook a1708 with some liquid damage on PCB.
    I alredy tried to clean PCB with IPA. Stuck at 5V/0A
    PPBUS_G3H is missing > 0V
    I removed fuse F7000 to check voltage, but it's still the same > 0V.
    Diode reading on pad 1 is 576
    Diode reading on pad 1 is 460
    What should I check now? Thanks
    Martin
  • mon2
    • 14334
    Re: Macbook A1708 - 5V/0A -no power- liquid damage.
    Review the 2nd case here:
    https://repair.wiki/w/A1708_2016,_20...ar_MacBook_Pro
    • martyjelen
      • Mar 2023
      • 127
      • Czech republic
      Thanks for reply. There is no short on PP3V3_G3H.
      • mon2
        • 14334
        Review each LDO rail on each cd3215. @Piernov and gang wrote an article on how to achieve the 20v negotiations. There is a flow chart on logiwiki.
        • martyjelen
          • Mar 2023
          • 127
          • Czech republic
          Originally posted by mon2
          review each ldo rail on each cd3215. @piernov and gang wrote an article on how to achieve the 20v negotiations. There is a flow chart on logiwiki.
          u3100
          pp20v_usbc_xa_vbus - 5v
          pp3v3_upc_xa_ldo - 3,3v
          pp1v8_upc_xa_ldoa - 1,8v
          pp1v8_upc_xa_ldod - 1,8v
          pp1v1_upc_xa_ldo_bmc - 1,1v
          u3200
          pp20v_usbc_xb_vbus - 5v
          pp3v3_upc_xb_ldo - 3,3v
          pp1v8_upc_xb_ldoa - 1,8v
          pp1v8_upc_xb_ldod - 1,8v
          pp1v1_upc_xb_ldo_bm - 1,1v
          • rilley
            MacBook Pro 13inch 2017mid (A1706 820-00923-A) - liquid damage - USBC and Display short circuit
            by rilley
            I am new into this, sorry to post it here. I want to make this as a pet hobby project, as this mac is not urgent.
            I have (Macbook Pro 13inch 2017mid) A1706 820-00923-A
            My mac had liquid damage a long time ago, the connector from J8500 is damaged on pin 46 (PP5V_S0_ALSCAM_F), I guess the LCD/display panel is in short circuit, as I saw the connector from the LCD burned as well.
            And the resistor L4004 is literally burned.
            From what I see from the schematics, it does not affect any other rails, only the connection to the display...
            07-10-2024, 01:57 AM
          • mitchw
            MacBook Pro 16 M1 Pro Liquid Damage (820-02100)
            by mitchw
            Got a MacBook Pro M1 Pro 16'' to rescue immediately after liquid accident - I got it in less than 30 minutes after the spill.
            It got spilled from behind when the laptop was closed. It mostly affected the rear of the mainboard and the bottom of the LCD.
            I quickly took it apart and washed the liquid residue off the mainboard.
            The area around the UP800 had some light corrosion, but it just washed away with some IPA. Other areas looked undamaged.
            The mainboard got a thorough cleaning, as did the top case and LCD connectors / cables.
            Now the laptop...
            07-16-2025, 07:55 AM
          • Jenzo
            MacBook A1989 overheating after liquid damage
            by Jenzo
            Hey everyone,
            Had a MacBook pro 13" 2018 (A1989) come in for liquid damage. The only liquid damage was all around UB400. It was most likely soda, so there wasn't that much corrosion. I reflowed the UB400 and the QB chips with some flux, and replaced the caps/resistors that were in bad shape. Seemed to be working fine at first, but the next day when testing it again, the laptop charges and boots fine, the CPU would overheat, and U7210 would get to 70 degrees Celsius as well. I'm testing with only screen and battery connected at this point.
            I can't figure out how...
            05-13-2023, 07:58 AM
          • MrBojangles
            MacBook Pro A1989 liquid damage
            by MrBojangles
            Hi!
            First post here...
            MacBook Pro A1989 (820-00850-A) with liquid damage showing 5V.
            I clean the board with alcohol and I get 20V. Fans spin but no chime or image.
            I then check the board with a thermal camera and see a component, Q7030, that is hot. I clean extra around this area and now I'm back to 5V.
            So... that means it's time to learn how to use schematics and boardview and what I've learned so far is that PPBUS_G3H is the "always on" power mode.
            I've checked multiple components pertaining to PPBUS_G3H...
            07-31-2024, 02:00 AM
          • dbuergi
            Macbook A1708 with water damage and problems after removing U2800
            by dbuergi
            i got a A1708 with water damage. I cleaned everything and the board started normal. But the next day i got 20v but no booting. Thermal cam showed over 160c (never had a chip getting this burning hot before) in U2800 and some shorts on the caps around it. After removal shortages were gone and i installed a donor U2800 which worked before.
            Sadly now the device stays at 5v, 0,4a and 1,9w and i don't find the problem.USB ports worked fine before....
            03-17-2025, 06:27 AM
