MacBook Pro A1989 liquid damage
  • MrBojangles
    • Jul 2024
    • 49
    • Sweden
    Hi!
    First post here...
    MacBook Pro A1989 (820-00850-A) with liquid damage showing 5V.
    I clean the board with alcohol and I get 20V. Fans spin but no chime or image.
    I then check the board with a thermal camera and see a component, Q7030, that is hot. I clean extra around this area and now I'm back to 5V.
    So... that means it's time to learn how to use schematics and boardview and what I've learned so far is that PPBUS_G3H is the "always on" power mode.
    I've checked multiple components pertaining to PPBUS_G3H and they are showing 5V which tells me that the problem is not there.
    I need to check the "next level" of power and this is where I'm totally lost.
    My questions is: Which components should I look at and what exactly am I looking for?
    My guess is that I'm looking for a component which doesn't have the voltage it's supposed to have but I'm not clear on knowing what the voltage should be and how to identify the faulty component.
    Sorry for the long post but as you can see I'm quite new to this
  • mon2
    • 14664
    Hello. Welcome. The designs with USB Type C are power delivery (PD) designs. Respectively, the external power adapter must be PD compliant and ideally should be the original adapter sold by the vendor for this target machine. Not impossible to use good quality 3rd party adapters with suitable e-marked PD cables rated @ 100W or higher.
    Once this setup is correct, there is a communication that will occur between the external power adapter (PD type) and a local PD controller ('ACE') onboard this logic board. Each power usually is fitted with its own PD controller. Each such controller has local firmware to offer the PD controller stack (software / firmware) to request the PD contracts (voltage & current) from the external power adapter. The 5 volt PD contract is a power up default. The PD adapter will share a list of supported contracts from which the ACE controller (CD3215 / 3217 / 3218, etc.) will select the best choice to power the machine. Usually it is the 20V contract.
    You are at 5 volts only. Study the ACE controllers and confirm the LDO rails are present for the connector you are testing. The dual mosfet you are observing may be defective and/or the ISL9240 is defective. The ISL9240 is a buck / boost regulator. When 5 volts is used at the input, the ISL9240 should boost this voltage to a higher one (~12 volts - check the repairwiki to confirm). After all is well, the ISL9240 will further boost this boosted voltage to ~13 volts. That is, once the board is operational, 20V will be used as the input voltage and this ISL9240 will shift into buck regulator operation (ie. high voltage in / low voltage out rather than boost mode).
    You do need the ISL9240 to be working for the 20V to be created. Review the document by piernov on how 20V is selected on such boards - it is important.
    CD3215 Bootup Sequence - LogiWiki
    • MrBojangles
      • Jul 2024
      • 49
      • Sweden
      Thank you for posting this. There's a lot of new stuff in here and I will have to research more in order to understand all the terms but I will that there is enough info here to help me.
      • MrBojangles
        • Jul 2024
        • 49
        • Sweden
        I did nothing but this time when I put the connector in I get 20.25 V and 0.5 A. One fan is spinning, the other is intermittently trying to spin. No chime, no display.
        The following components are getting hot,
        2R7
        R47
        U8160656 (Intel chip)
        U810C656 (Intel chip)
        • Jenzo
          MacBook A1989 overheating after liquid damage
          by Jenzo
          Hey everyone,
          Had a MacBook pro 13" 2018 (A1989) come in for liquid damage. The only liquid damage was all around UB400. It was most likely soda, so there wasn't that much corrosion. I reflowed the UB400 and the QB chips with some flux, and replaced the caps/resistors that were in bad shape. Seemed to be working fine at first, but the next day when testing it again, the laptop charges and boots fine, the CPU would overheat, and U7210 would get to 70 degrees Celsius as well. I'm testing with only screen and battery connected at this point.
          I can't figure out how...
          05-13-2023, 07:58 AM
        • mon2
          A1466 Macbook Air (Liquid damage repair)
          by mon2
          Hi. Recently serviced a damaged A1466 Macbook Air. Thought to post the issues and resolution for each.
          Macbook AIR Model A1466 Diagnostic 09-01-2021
          Issue: Liquid damaged (beer spill) Macbook AIR will not power up.
          Problems & Resolutions
          1) Attached Apple magsafe power adapter. No green / no orange light. This confirms the absence of the PP3V42_G3H voltage rail. The PP3V42_G3H rail is the primary voltage rail necessary to communicate with the magsafe power adapter to report the green or orange light status to the end user....
          09-01-2021, 09:31 AM
        • rounin
          MacBook Pro A2442 (Board No. 820-02443-05) – Liquid Damage Repair Assistance
          by rounin
          Device Information
          • Model: MacBook Pro 14” M1 Pro (A2442)
          • Logic board number: 820-02443-05
          Original Issue
          The device suffered liquid damage, causing a short circuit on the logic board.
          Near the audio jack area, the CR852 capacitor pad was severely burned, creating a clear short-circuit path. The board could not power on properly.
          Work Performed
          Removed the short circuit by drilling through the board (bypassing the short path) in the CR852 area.
          Current Status
          • When powered on, the screen shows support.apple.com/mac/restore....
          10-20-2025, 11:15 PM
        • rilley
          MacBook Pro 13inch 2017mid (A1706 820-00923-A) - liquid damage - USBC and Display short circuit
          by rilley
          I am new into this, sorry to post it here. I want to make this as a pet hobby project, as this mac is not urgent.
          I have (Macbook Pro 13inch 2017mid) A1706 820-00923-A
          My mac had liquid damage a long time ago, the connector from J8500 is damaged on pin 46 (PP5V_S0_ALSCAM_F), I guess the LCD/display panel is in short circuit, as I saw the connector from the LCD burned as well.
          And the resistor L4004 is literally burned.
          From what I see from the schematics, it does not affect any other rails, only the connection to the display...
          07-10-2024, 01:57 AM
        • mitchw
          MacBook Pro 16 M1 Pro Liquid Damage (820-02100)
          by mitchw
          Got a MacBook Pro M1 Pro 16'' to rescue immediately after liquid accident - I got it in less than 30 minutes after the spill.
          It got spilled from behind when the laptop was closed. It mostly affected the rear of the mainboard and the bottom of the LCD.
          I quickly took it apart and washed the liquid residue off the mainboard.
          The area around the UP800 had some light corrosion, but it just washed away with some IPA. Other areas looked undamaged.
          The mainboard got a thorough cleaning, as did the top case and LCD connectors / cables.
          Now the laptop...
          07-16-2025, 07:55 AM
