Lenovo b450 LA 14 no power up 13mA
  • maxsim86
    • Apr 2014
    • 21
    • malaysia
    hi ..have a lenovo B450 no power Up. have 19v,3.3 v,5 volt but 5volt drop to 4.5v
    L15 = 1.5 K Ohm
    L6 = 34 K Ohm
    L30 = 7.4 OHM
    L7 = 18MOHM
    L8 = 15.6OHM
    L9 = 15.5OHM
    L17 = 1.7KOHM
    L16 = 18.6OHM
    Schematic: https://www.badcaps.net/forum/showth...54#post1244154
    Last edited by Vesko356; 06-03-2023, 01:35 AM. Reason: Attached schematic removed and replaced with link.
  • mon2
    • Dec 2019
    • 14369
    Re: Lenovo b450 LA 14 no power up 13mA
    Where are you measuring this 5v rail?
    Measure the voltage to ground at U20 mosfet. Measure each pin of interest.
    Source (1-2-3)
    Gate (4)
    Drain (5-6-7-8)
    For any rail that is not matching the schematic value, remove all power, meter in resistance mode. Measure the resistance to ground to confirm there is no partially shorted part on the rail.
    • maxsim86
      • Apr 2014
      • 21
      • malaysia
      Originally posted by mon2
      where are you measuring this 5v rail?
      c258 = 4.5v
      u20 resistance mode value :
      pin 123 = 45kohm
      pin 4 = 9kohm
      pin 5678 = 4.6 M Ohm
      • mon2
        • Dec 2019
        • 14369
        From the linked schematic, c258 = M_VCCA_DPLLA
        Is this correct? That is not a 5v rail but is 1D05V_S0.
        • maxsim86
          • Apr 2014
          • 21
          • malaysia
          I am wrong C528, not c258...c528 is 51125_VBST2
          • mon2
            • Dec 2019
            • 14369
            Measure the voltage to ground at L6, pin #2. This is 5V_PWR.
            Then also L15, pin #1. This is 3D3V_PWR.
            Post each measurement.
            • maxsim86
              • Apr 2014
              • 21
              • malaysia
              L15 and L6 = 0volt
              • mon2
                • Dec 2019
                • 14369
                Measure the voltage to ground of DCBATOUT_51125 (pin 16) on this IC. This is the high dc voltage used as the input to this dual switching regulator.
                For safety, it will be easier to measure the same power rail at U28 (pins 5-6-7-8).
                • maxsim86
                  • Apr 2014
                  • 21
                  • malaysia
                  found 19v at this point . here i list on ic u47:-
                  1) 1.4v
                  2) 0v
                  3) 2.0v
                  4) 2.0v
                  5) 0v
                  6) 1.3v
                  7) 0v
                  8) 3.3
                  9) 4.5
                  10) 0v
                  11) 0v
                  12) 4.9v
                  13) 1.48v
                  14) 3.3v
                  15) 0v
                  16) 19v
                  17) 4.9v
                  18) 0v
                  19) 0v
                  20) 0v
                  21) 0v
                  22) 4.5v
                  23) 0v
                  24) 0v
                  • mon2
                    • Dec 2019
                    • 14369
                    This regulator is remaining OFF due to ENTRIP1 & ENTRIP2 pins being logic low. Respectively, PGOOD is a logic low since both of these rails are not within specifications.
                    (netnames are 51125_ENTIP1 & 51125_ENTIP2)
                    L15 and L6 = 0volt
                    Remove all power -> meter in resistance mode -> measure the resistance to ground of L15 and then of L6.
                    reference - regulator datasheet:
                    https://cdn.badcaps-static.com/pdfs/...abc8077401.pdf
                    • maxsim86
                      • Apr 2014
                      • 21
                      • malaysia
                      L6 = 1.27kOhm
                      L15 = 420 ohm
                      • mon2
                        • Dec 2019
                        • 14369
                        To me, these are both low resistance values for these power rails.
                        Do you have hot air tools? If yes, flux and hot air L15 to lift one leg. Then check the resistance to ground again on each side of L15 pcb pads. Be patient to apply enough heat and time to melt the solder.
                        Which side is with the low resistance? Is it the regulator (producer) side or the consumer (downstream) side?
                        • maxsim86
                          • Apr 2014
                          • 21
                          • malaysia
                          yes i have, here a result of L15 1.41kohm and another side is 1.29kohm. if i put black probe at ground the result 1.69kohm and another side 2.0kohm
                          • mon2
                            • Dec 2019
                            • 14369
                            This is the same coil that was reporting 420 ohms earlier?
                            • maxsim86
                              • Apr 2014
                              • 21
                              • malaysia
                              yes L15,or i am doing something wrong?
                              • PantherDave
                                by PantherDave
                                Hi all!
                                05-29-2024, 02:01 PM
                              • GLISIT
                                by GLISIT
                                01-16-2025, 02:29 PM
                              • Mita99
                                Lenovo Thinkpad P72 EP720 NM-B723 MB - Power disabled within 2 seconds after plugging the charger
                                by Mita99
                                Try to repair a Thinkpad P72 EP720 NM-B723 MB with I7-8850H processor and N18E-Q1-KB-A1 (P3200) GPU with 6GB memory. Unfortunately there is noinfo what happened to the laptop. I got it disassembled with parts missing, like keyboard, battery.
                                Unfortunately I have no schematic available for me (requested in the sub porum) but got the boardview file.
                                Symptom: after connecting to the charger the power led light up for one-two second and switch off. After a couple secons the power led light up for half a second and switch off. No battery, no IO board, no...
                                04-27-2025, 07:20 PM
                              • Dr.d
                                Help please..Lenovo ideapad 5 14itl05 power and charging problem
                                by Dr.d
                                I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
                                Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
                                04-05-2024, 11:48 AM
