problem with a macbook pro m1
  • Panino1996
    • Jun 2023
    • Italy
    Hi everyone, I'm new and proud to join the group.
    i have a problem with a macbook pro m1. in practice following a fall (from inside the backpack) when starting the macbook no longer takes wifi and also the keyboard and trackpad no longer work.
    can you give me some advice?
  • rounin
    MacBook Air A2337 (820-02016) USB-C Port Issue โ€“ Only Works in One Orientation (CC Line Problem?)
    by rounin
    I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck โ€” hoping someone here can shed some light.
    ๐Ÿ›  Original Issue
    The machine initially wouldn't negotiate 20V over USB-C โ€” stuck at 5V.
    โš ๏ธ New Problem: One USB-C Port Only Works in One Orientation...
    04-19-2025, 01:18 AM
  • psdavid65
    Macbook Air A1466 820-3437-B Booting Problem
    by psdavid65
    I received a 2013 Macbook Air A1466 820-3437-B motherboard with serial number C02L6GQ9FSV8 that came in WITHOUT a bios chip. I got a new bios chip and reprogrammed it. Macbook now powers on but doesn't boot the SSD. I've flashed a ton of bios but still same problem. Windows installation works with this Macbook but never a mac installation. Unfortunately, since I didn't receive this macbook with a bios chip, I don't have the original bios. What can I do now?...
    06-20-2024, 12:27 AM
  • Skrndelj
    Apple Macbook Air M1 A2337 Trackpad problem
    by Skrndelj
    Hello all,
    I am repairing a Macbook A2337 and i have a problem
    The Macbook is stuck in restore as someone before me tried a DFU restore and bricked the device, now i can't do a restore as AC2 throws error 1 which is related to the trackpad.
    When i turn on the device i get the trackpad click for a few moments and then nothing, i tried 7 trackpads and 7 trackpad flats, i know all 7 are functioning okay, especially one as i use it for testing and DFU restore.
    I inspected the whole board and everything seems fine.
    Can anyone help me as i didn't fiddle with trackpad...
    06-11-2024, 04:26 AM
  • sdogs
    Macbook Air 2020 A2179 820-01958 battery problem?
    by sdogs
    I have a MacBook Air A2179 in my hands that had power problems (5V to the USB-C port intermittently).
    After a first inspection I could see that the D3302 protection IC was burnt out, so I replaced it but the problem was not solved, it seems like intermittent 5v input.
    I then replaced the two u3200s (CD3217B12ACE) and now I have stable 20 volts and the macbook has turned back on.
    Unfortunately I have a further problem, it works very slowly and the fan runs at maximum and if I disconnect the charger it turns off, it's as if the battery was disconnected.
    02-08-2024, 08:00 AM
  • brockauly
    Macbook M1 A2337 EMC 3598 weird battery charging problem
    by brockauly
    Hi guys,
    If I unplugged the battery and the charger, then plug the battery then the charger, it charges without problem.
    Then if I unplug the charger and plug it back, it won't charge anymore.
    In the first case, main voltage is regulated at ~12.5V and charges the battery.
    After unplugging the charger, main voltage drops to battery voltage at ~11.5V.
    After replugging the charger, main voltage stays at ~11.5V and won't go up to ~12.5V again.
    I found C520A (2.2ยต after current sensor from USB-C source) completely burnt and removed it properly. I cleaned...
    02-05-2025, 10:51 AM
