Msi GT72 - MS-17851 V1 board no power
  • mikay786
    • Aug 2014
    • 765
    Trying to figure out why I have no power on this board.
    I’ve got power coming in from original charger fine, 1st 2nd mosfets seem fine.
    I’ve got no voltages on the bios chip on any of the pins including the vcc
    I’ve got 3.3v on the power button connector and does drop to 0 when pressed
    I’ve noticed at a pair of mosfets I have got 19v at drain but nothing on the opposite end so kind of thinking I have a issue here
    The mosfet after that has 100ohm resistance between drain and source.
    Just wanted to make sure I’m on the right track and anything else to check
  • mon2
    • Dec 2019
    • 14094
    Re: Msi GT72 - MS-17851 V1 board no power
    Yes, you are.
    Link the schematic if available in the schematic forum.
    The mosfets you are referencing are likely the usual DCin mosfets. Which charger IC is nearby? Perhaps the BQ series? Share the topside markings of the same.
    If yes, measure the voltage to ground of each pin on this mosfet. If N-channel mosfets, gate should be ~25 volts to enable.
    Update - never mind - found the schematic in my paid database.
    The charger IC is indeed BQ series but the ACDRV pin is not used. Instead, your DCin*2 mosfets are P-channel.
    So gate pin must be LOWER than the source / drain pin voltage to enable.
    The low resistance you have observed is not a good sign is often means the mosfet is leaky.
    See attached for the partial schematic of this region.
    Proceed to measure the source / drain / gate pin voltage to ground of each of these DCin mosfets.
    Post each measurement.
    • mikay786
      • Aug 2014
      • 765
      The low resistance was on the mosfet near the ram with the red arrow.
      PQ1
      • G - 9.78
      • S - 19.75
      • D - 19.75
      • RESISTANCE S & D is 15 MEGA OHMS
      PQ2
      • G - 8.31
      • S - 19.75
      • D - 19.75
      • RESISTANCE S & D 32 KILO OHMS
      PQ7
      • G - 0
      • S - 0
      • D - 19.75
      • RESISTANCE S & D 14 KILO OHMS
      PQ8
      • G - 0
      • S - 0
      • D - 0
      • RESISTANCE S & D 100 OHMS
      • mon2
        • Dec 2019
        • 14094
        PQ2 is showing a very low resistance across source & drain.
        Suggest to flux it and carefully remove this mosfet and then check it's resistance again once it is cool and on your work table.
        • mikay786
          • Aug 2014
          • 765
          removed all 4 mofset
          pq1&2
          red probe drain / black on source both read about 5.6 M ohm
          and 0.l when i flip the probes, why is this?
          pq7
          black prove drain red on source = 8.5 m ohm
          0.l when probes reversed
          pq8
          black prove drain red on source = 6.3 m ohm
          on the empty pads board
          pq2
          red probe drain / black on source read about 0.47 M ohm
          reversed 0.47 m ohm and climbing slowly
          pq1
          red probe drain / black on source weird reading jumping 0.l & 2.6 k ohm on off
          reversed 76 k ohm
          • mikay786
            • Aug 2014
            • 765
            Do the mosfet reading look normal?
            And the board readings where the mosfets were?
            • mon2
              • Dec 2019
              • 14094
              PQ1 measurements do not.
              • mikay786
                • Aug 2014
                • 765
                Possibly another component like a capacitor nearby causing issues?
                  MSI Gaming GT72-6QEG81 Dominator Pro G Notebook GT Specification for Upgrade or Repair
                  This specification for the MSI Gaming GT72-6QEG81 Dominator Pro G Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GT72-6QEG81 Dominator Pro G boardview and GT72-6QEG81 Dominator Pro G schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                  09-06-2024, 05:30 AM
                • Nagy Daniel
                  Lowest possible resistance on laptop motherboard rail - Guide Table request
                  by Nagy Daniel
                  Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                  I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                  I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                  So, I generated a table with AI so I can...
                  03-04-2025, 08:24 AM
                • BlackScreen_22
                  Harman Kardon sub TS11 (ds15 amplifer) blows fuse and mosfets
                  by BlackScreen_22
                  Hi, I'll start by saying that I'm not an expert and I've reached a point where I don't know what to try/do anymore...
                  Starting from the beginning: I opened this subwoofer for the first time with a very strong smell of burnt electrical components, I realize that on the amplifier board there is a hole between V+ OUT and GND about the size of a finger, the damaged components were the shorted mosfets, two damaged zener diodes and two capacitors. I bought everything, I fixed the hole by cutting the pcb and putting a piece of a perforated board.
                  I had no problems connecting mosfets and capacitors,...
                  08-27-2024, 12:46 PM
                • kotel studios
                  Intel D865PERL - no Vcore after replacing MOSFETs and MOSFET drivers
                  by kotel studios
                  Finally got time to fix this board up.
                  At first it didn't give any POST codes. Turns out it was an unsupported Celeron D cpu. After dropping in an Celery 2.6gHz the CPU came out of reset with clock signal, but still no post codes. For a while it did work when I applied pressure to the ADP3168 chip, but on next reboot the MOSFETs started to burn. Then I left it as is for months.
                  Now I came back prepared. Replaced the bad MOSFETs and the ADPxx18k drivers. Now I don't get any MOSFETs blowing up issues anymore. But sadly, the Vcore is missing. The whole VRM isn't...
                  04-22-2025, 05:08 AM
                • cind12
                  GTX 1080 TI Gigabyte Aorus low resistance on vmem
                  by cind12
                  Hi guys, i was wondering, i've got 9Ohms on Vmem, one of the mosfet was shortet to ground, so i've desoldered hi and low mosfets nad still low res, then i removed all of the memory chips, and the resistance is still low, so did you had maybe a card with that low res on memories, and the card was working fine ?
                  Removed the U1866Q and still without result, i dont have thermal cam so can't see where is hot spot when incjeting voltage.
                  The resistance on core is ok 0.1Ohm ((Power 0.8V when on)
                  Resistance on 12V 4K ohms (Power present when on)
                  Resistance on 12V PEX 4K ohms...
                  12-08-2023, 09:09 AM
